TRD off road locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dumprat, Apr 13, 2017.
  1. Apr 15, 2017 at 2:49 PM
    #41
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Yes that is how it works. The only thing to add is the elsd is always activated so you don't have to turn it on
    JayRolla[QUOTED] likes this.
  2. Apr 15, 2017 at 3:11 PM
    #42
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    It is super hairy like I can't even pay attention to the locker now
  3. Apr 15, 2017 at 3:18 PM
    #43
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Cool. Thanks. I will have to test it out. Normal open diff you pretty much done when tires start to lift.
  4. Apr 15, 2017 at 4:14 PM
    #44
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Just have to pick the right line
  5. Apr 15, 2017 at 4:26 PM
    #45
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Some of the trails here you will be on 3 wheels even if you pick the right line. Pick the wrong line and you'll flop over. Just depends on the kind of wheeling you want to to. I would not attempt donkey trail in a sport without at least a rear locker. It's a lot steeper the the video makes it look.
    https://youtu.be/32YCW02wS3o
  6. Apr 15, 2017 at 4:40 PM
    #46
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Add shift to neutral between a and b and it's pretty quick.
  7. Apr 15, 2017 at 4:45 PM
    #47
    JayRolla
    Colorado Springs
    True. And sometimes you have to try a few lines. At least with a locker you can get through the trail quicker.
  8. Apr 15, 2017 at 4:48 PM
    #48
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    They they definitely make life nice. And there are situations where there are no lines open diff will work on too
  9. Apr 15, 2017 at 4:50 PM
    #49
    JayRolla
    Colorado Springs
    I have yet to find a situation like that. I usually cheat at that point. Just hook up my winch. Haha.
  10. Apr 15, 2017 at 4:56 PM
    #50
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Lol. I hate winching. Takes alot of time
    JayRolla likes this.
  11. Apr 15, 2017 at 4:57 PM
    #51
    JayRolla
    Colorado Springs
    That's what co pilot is for. I never get muddy that way either. Lol.
  12. Apr 15, 2017 at 5:16 PM
    #52
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Yup, this is why I would like to put a Detroit TruTrac up front. Its a helical gear LSD for the front. No its not as awesome as a locker but requires no attention from the driver, no electronics, switches, airlines or compressors, and easier to steer. The kicker is that when a wheel in the front is off the ground TruTrac redirects torque to the wheel with more resistance (opposite of open dif) however if the wheel spins too fast it wont redirect so people have to use a brake technique. The beauty of it is that Toyota electronics already attempt to brake spinning wheels which plays right into the hand of how the Trutrac is supposed to work, instead of depending on software to do everything you have software assisting mechanical gears.
  13. Apr 15, 2017 at 5:49 PM
    #53
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If the truck is an '09 or newer, it has A-TRAC as well as the locker. Use the A-TRAC always in L4 and the locker only in an emergency as it was designed for. A-TRAC stops spin on the front and rear but allows easy stearing on the trail, unlike a locker. I have owned Tacomas with just the locker and since 2009 with A-TRAC. The A-TRAC is superior as it is locker-like traction on all 4 wheels and doesn't affect steering.
  14. Apr 15, 2017 at 8:08 PM
    #54
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    oh yeah, left that part out.:anonymous: just assumed people knew stop, put in neutral.
  15. Apr 15, 2017 at 8:19 PM
    #55
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Zip is another option for air lockers. There are also cable actuated lockers like Ox and electric lockers like Eatons that don't require on board air. All of them work well.
    Thunder Fist[QUOTED] likes this.
  16. Apr 15, 2017 at 8:33 PM
    #56
    JayRolla
    Colorado Springs
    I've been thinking of doing something like this in the rear of my 4runner. A lot more road friendly and cheaper than an arb.
  17. Apr 15, 2017 at 8:35 PM
    #57
    JayRolla
    Colorado Springs
    So my base sr5 4x4 2012 has atrack? Or only the trd models. I saw some saying I had trac but not a trac since I don't have the a trac.
  18. Apr 15, 2017 at 8:37 PM
    #58
    David K
    Can't be sure as there was a lot of talk about beeping. The light blinks anytime you press the RR Diff button and it doesn't engage, often because you aren't in L4 for 4x4s. It beeps only if you don't go into Neutral when you switch into or out of L4.
  19. Apr 15, 2017 at 8:39 PM
    #59
    David K
    The locker was mentioned as a good idea for 4 wheeling. As the locker only comes on the Off Road TRD, then 2009+ has A-TRAC as well.
  20. Apr 15, 2017 at 8:47 PM
    #60
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Your base does not have ATRAC. That is only offered on the Offroad model.
    You do however have trac.
