TRD off road locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dumprat, Apr 13, 2017.
  1. Apr 15, 2017 at 8:58 PM
    #61
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Can all of those be used in 4hi?
  2. Apr 15, 2017 at 9:11 PM
    #62
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Optional, non-Toyota lockers can come on in any gear, 2WD or 4WD.
    Thunder Fist likes this.
  3. Apr 15, 2017 at 9:32 PM
    #63
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Sure. The only thing preventing the Toyota e-locker from being used in 2 or 4hi is the way Toyota wired the controls.
    Thunder Fist[QUOTED] likes this.
  4. Apr 16, 2017 at 7:29 AM
    #64
    Shroom4x4
    Shroom4x4 Active Member
    2016 TRD Sport ACLB 6MT
    Yeah, wheeling anything is how expensive trucks are broken, no matter if it's just mud or sand or light water crossings. You're going to cause more wear and tear and have to do more maintenance. Some people like this but I'd rather buy a cheaper, older solid axle vehicle that I don't have to worry about destroying.
    I just wanted something that wouldn't get stuck in normal driving, which around here, depending on the season, can get a little hairy. Plowing through 100 yards of 1.5foot snow with ice/rock/dirt underneath, up a 10% grade is about usual. Can't crawl through it and 4lo overpowers the wheels too much because you can't get to a higher gear to stop the tires from breaking loose. Can crawl over ruts and rocks, yes. I've done lots of that too and also broken lots of parts in the past too. This truck is too nice so I just avoid it...
    I used to have the "I want to 4x4 everything nao!" bug but I worked through that shit in my 20's over 6 different 4x4's and spent a crapton of money. I feel older and wiser now. Maybe in 5 years I won't feel the same way and I'll eat my words here. :)
    JayRolla[QUOTED] likes this.
  5. Apr 16, 2017 at 9:26 AM
    #65
    David K
    Hmmm, I have had 4WD most of my 42 driving age years and I wanted 4x4 to get to the exotic places safely and without getting stuck where I would need help because I rarely traveled with others. To me, having 4WD prevents breaking and does not cause that to happen. Have double traction (4WD) means no need to gun it and risk breaking things.
    JayRolla likes this.
  6. Apr 16, 2017 at 9:31 AM
    #66
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    We are on same page. Having 4x4, lockers, trac just makes everything easier and less chance of breakage.
    I wheel quite a bit. Some 7-8 out of 10 rated trails. They say 35s and lockers needed but I've completed them open diffed and on 33s.
    Only thing that's failed me on the trail was a broken sway bar link in 6 years.
  7. Apr 16, 2017 at 10:05 AM
    #67
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    A lot of people don't realize how much difference an experienced driver makes. No amount of gear or tech is going to turn a noob into an off road hero.
    JayRolla[QUOTED] and Spare Parts like this.
  8. Apr 16, 2017 at 10:29 AM
    #68
    David K
    Amen that... and lowering tire air pressure!
  9. Apr 16, 2017 at 11:04 AM
    #69
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Depends on the surface. Where I am I'm always in 4lo with locker on. Haven't found a useful application for MTS yet.
  10. Apr 16, 2017 at 1:14 PM
    #70
    David K
    I think, like me in 2009 and 2010, you get the Off Road for the locker and discover what A-TRAC is by testing it. Yes, it is different than a locker, there is some delay as the tires automatically lock. But, when you realize it is on all four tires and not just the rear, it is kind of exciting because the truck really climbs and crawls like a tank and can't get stuck (so far).
    As I understand MTS, it is just different levels of A-TRAC based on the surface conditions you set it for.
    I would like you and other 3rd Gen Off Road owners who have been using the locker in L4, to not. Use MTS and try skinny pedal as well as heavy pedal and see. Use the locker only if you actually get stuck or exhausted trying the different settings of MTS.
    I think it could be very valuable as my extensive 2010 A-TRAC posts have been.
    Thank you!
  11. Apr 16, 2017 at 1:34 PM
    #71
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    I know what it does, and I'm sure in some situations it is better. But I'm trying to figure out what those situations are. I'm in a lot of mud, and it doesnt help with that. Probably something like a loose rocky incline would be great for it, but I don't ever encounter anything like that around here. What types of situations do you think it performs best in?
  12. Apr 16, 2017 at 1:44 PM
    #72
    David K
    I have used it in sand, mud, snow, steep-rocky and rutted grades, pulling 2WDs...
    Snow and pulling others is where I think adding the locker in addition to A-TRAC is where I perceived an improvement. A-TRAC only is active under 3 mph with the locker on.
