TRD Off Road lockers and 4Lo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JEBsTaco, Apr 13, 2025.
  1. Apr 13, 2025 at 2:08 PM
    JEBsTaco
    JEBsTaco [OP] Member
    Middle Tennessee
    2018 Off Road
    2.5 Eibach Pro 2.0 Coilover Lift Kit
    My push button rear lockers do not lock all the time. And most of the time it takes a couple of minutes or more before they do. Also, 4Lo takes a while before disengaging. Anyone else experience this? Is there a reason and/or solution?
  2. Apr 13, 2025 at 2:31 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Use it more often and turn the wheel left and right as you are moving forwards. That should do the trick.
    Chew and JEBsTaco[OP] like this.
  3. Apr 13, 2025 at 2:38 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Where you in 4hi first, Then switch to Neutral before going to 4low?
  4. Apr 13, 2025 at 3:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Shift from 4lo to 4hi while stopped with transmission in neutral. Shifting should be very quick. If you are doing the above correctly and it's still slow, either wrong fluid or a failing actuator is the likely culprit.
