TRD off Road shock upgrade or no?
Discussion in '4th Gen. Tacomas (2024+)' started by Wahhabm, May 2, 2025.
  1. May 2, 2025 at 8:59 PM
    Wahhabm
    Wahhabm [OP] Well-Known Member
    Monther
    I have the TRD off Road with 18 in wheels. 265/70/18 stock from factory. I don't know if there is a lift kit or not? I honestly feel it is high enough and I don't do serious off rd. Is it necessary to upgrade any suspension components? Bilstein shocks?
  2. May 3, 2025 at 5:00 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    do you not like the ride quality ?
  3. May 3, 2025 at 5:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Would recommend just driving it. Deal with any potential upgrades when you wear out the OE bits.
    Wahhabm[OP] and gmtech like this.
  4. May 3, 2025 at 6:31 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    This. Also if you add bigger tires the truck feels higher and lifted.
  5. May 3, 2025 at 6:44 AM
    Wahhabm
    Monther
    It feels fine to me. I just read about all these suspension upgrades that talk about improving ride quality.
    TacoTuesdai likes this.
  6. May 3, 2025 at 7:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    For 4g models?
    TS4x4 likes this.
  7. May 3, 2025 at 11:34 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Read less, drive more.
    Bogeypro, rybern, TS4x4 and 12 others like this.
  8. May 4, 2025 at 4:40 AM
    Taco Ji
    New Jersey
    Good advice lol
  9. May 4, 2025 at 3:51 PM
    TacoTuesdai
    TacoTuesdai Member
    Leonard
    Sandy Eggo
    2024 iForce Max TRD Off Road
    I have had my 2024 TRD Hybrid for six weeks. It came off the lot with Bilstein shocks. The ride is pretty nice going over some rough streets with road damage. If it isn't broke, I am not gonna fix it. LoL. When I hit some off road traveling, I will see how it goes, but I am sure these shocks are going to work out.
    Wahhabm[QUOTED][OP] likes this.
  10. May 4, 2025 at 7:30 PM
    Wahhabm
    Monther
    That is exactly what I have TrD off Rd Hybrid with bilsteins
    TacoTuesdai[QUOTED] likes this.
  11. May 4, 2025 at 7:45 PM
    TacoTuesdai
    TacoTuesdai Member
    Leonard
    Sandy Eggo
    They are good shocks. I have installed a few sets on Toyota's and the customers loved them. That doesn't mean you will like them, but I think they will be good unless the shocks prove me wrong.:rolleyes:
  12. May 5, 2025 at 10:26 AM
    IIIAWOLIII
    IIIAWOLIII Well-Known Member
    Jim
    Florida Space Coast
    2024 TRD Offroad Hybrid
    Same setup as both of you, and felt the suspension was 90% there but needed a little something.
    Decided to put the AllDogs springs up front to preserve the ride and remove all but about .5" of the rake. This will create a slightly taller and more level appearance - just about perfect for me.
    The rest of my setup (TRD front skidplate, Canadian OEM mudflaps, and ARB rear recovery points) will be all I need for the amount of time I spend on trails. I'm not interested in rock crawling.
  13. May 5, 2025 at 10:27 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Best advice, even.
  14. May 5, 2025 at 2:08 PM
    TacoTuesdai
    TacoTuesdai Member
    Leonard
    Sandy Eggo
    Right on. Enjoy!!:broccoli:
  15. May 5, 2025 at 3:03 PM
    Taco Ji
    New Jersey
    Make sure to adjust your tire pressure to 30-35 psi. Most dealers set their tire pressure to the maximum at 50 psi and when new owners drive off the lot they are worried about how harsh the ride is.
    FunknNasty and TacoTuesdai like this.
  16. May 5, 2025 at 4:00 PM
    desertrun
    desertrun Member
    What
    2024 tacoma
    I’ll be the pain in the neck - I put 33s on mine, no lift no change of shocks, and I bottom out frequently. I also have the add front bumper, warn evo 10 winch, and a 20 inch s8 from Baja Designs and my front sags pretty bad.
    if you’re not doing all that, I bet it would ride pretty well on just 285/70/17s
  17. May 5, 2025 at 4:52 PM
    Taco Ji
    New Jersey
    This is obvious but… If you’re adding all that weight then you need to change your suspension set up along with it.
    TacoTuesdai and CrispyTacoLover like this.
  18. May 5, 2025 at 7:24 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    The TDR OR already comes with Bilsteins. They're upgraded over the ones on the 3rd Gen - which were a little puny. The 4th Gen's Bilsteins are 46mm - on par with 5100s.
    They'd be the shocks I'd put on a 4G that didn't come with them, and a main reason I picked the OR.
    Bottom line: You already have the good suspension.
    Curveball30 and TacoTuesdai like this.
  19. May 5, 2025 at 8:20 PM
    TacoTuesdai
    TacoTuesdai Member
    Leonard
    Sandy Eggo
    Mine had 50 psi in them when I drove it off the lot. They are at 37 now just to see how they feel. Probably dial them back to the spec of 32.
    Why do they set them at 50? Is this so they don't have to check them as much on the lot?
    JollygreenFE likes this.
  20. May 6, 2025 at 3:42 AM
    Taco Ji
    New Jersey
    That is my thought. I actually think it is either done at factory or at the port. Dealers are too lazy to inflate every single car and truck that arrive at their lots.
