TRD Off-road Suspension help
Discussion in 'Suspension' started by eastonyit, Jul 1, 2023.
  1. Jul 1, 2023 at 12:30 PM
    eastonyit
    eastonyit [OP] New Member
    Easton
    Missouri
    2018 TRD Off-Road
    I have been dealing with some loud squeaking/creaking for the past few months, would come and go but has been worse recently. Thought I had it tracked down to a LCA bushing but took it to a shop and they're saying "Front strut worn causing noise". Currently have the Fox 2.0, was thinking about going to the Billstein 5100 with OME springs. Should I stick with the Fox and order all 4? Where do you guys like to order from? Should I order the whole 5100 set if I go that route pre-assembled or are the parts off the Fox shocks able to be switched with the billstein struts?
  2. Jul 1, 2023 at 12:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If the problem is only with the front coilover(s). I would replace only the front pair. I would get all new hardware, e.g., springs/coils, bushings, bolts etc. Which brand you get is as much fashion as necessity. If you mix brands keep the system balanced.
    Side note: A lot of vendors are doing 4th of July sales.
  3. Jul 1, 2023 at 12:50 PM
    mauctopa
    mauctopa Well-Known Member
    Foxes are rebuildable no ?
  4. Jul 1, 2023 at 12:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    5100s will not perform as well as the Fox units.
    Ricardo13x likes this.
  5. Jul 1, 2023 at 1:48 PM
    eastonyit
    Easton
    Missouri
    2018 TRD Off-Road
    Have also looked into rebuilding, have not found anyone who does it locally. Not sure how to get away with having to send them off without getting another pair of shocks anyway.
  6. Jul 1, 2023 at 2:18 PM
    mauctopa
    If it helps you any I have a set of 4 oem bilsteins yellow like new you can have. I dont have the coil springs tho
    BadCo07$$ likes this.
  7. Jul 11, 2023 at 11:17 AM
    BadCo07$$
    BadCo07$$ New Member
    Houston, TX
    2007 Toyota Taco 4x4 Crew
    Rust
    @mauctopa I'll take those OEM Bilsteins if you have them!!
  8. Jul 14, 2023 at 2:48 PM
    Matte Black burnt rust
    Matte Black burnt rust Well-Known Member
    2020 Tacoma TRD Off Road
    It could be mud or dirt. Try a good pressure washing and run them until they fail.
    davep2012 likes this.
  9. Jul 14, 2023 at 2:50 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  10. Jul 14, 2023 at 8:34 PM
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    Matte Black brings up a good point. I would do as he suggested and also get a can of silicone spray and spray all of the rubber bushings on the front end, controls arms/sway bar bushings a couple of time and then make a decision on replacing struts.
  11. Jul 14, 2023 at 8:56 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Have you checked the front body mounts
  12. Jul 17, 2023 at 11:24 AM
    eastonyit
    Easton
    Missouri
    2018 TRD Off-Road
    Yes took that apart yesterday and checked them out, they are in good shape. Have tried silicone spray on all the bushing in that area too.
  13. Jul 17, 2023 at 11:31 AM
    eastonyit
    Easton
    Missouri
    2018 TRD Off-Road
