TRD Off Road - Suspension is stiff
Discussion in '4th Gen. Tacomas (2024+)' started by CJBiggs, Jun 19, 2025.
  1. Jun 19, 2025 at 2:41 PM
    CJBiggs
    CJBiggs [OP] Well-Known Member
    2024 4th Gen Tacoma OF Hybrid
    Hey Everyone.
    Anyone else think their Bilstein suspension on their TRD Off Road is a bit too stiff? It handles great on the road, but man...I swear I could tell if a quarter was heads or tails.
    This is coming from a guy who previously had OME BP-51's on my well setup 4Runner.
    I keep eyeballing the OME MT-64's thinking they will be more plush. I could care less about on-road handling.
    Anyone?
    taco terror and gmtech like this.
  2. Jun 19, 2025 at 3:01 PM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    A lot of people report tire pressure being too high from the dealer so that could be a factor.
    I came from a 2nd gen with the TRD baja suspension or bilstien 6112's and I have to say that those coilovers made for a much nicer ride than the stock TRD suspension on my 4G.
    So its most likely a case of us just being spoiled by having used higher quality components.
    But check the tire pressure- it might help
    When you take it to the dealer every 5k miles they like to pump them up to 39-40lbs when they rotate them and the ride is much better at 32-33lbs
    shakerhood and JB_TN like this.
  3. Jun 19, 2025 at 4:17 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    Not at all. I keep my tires at 32psi.
    LN13 and CJBiggs[OP] like this.
  4. Jun 19, 2025 at 4:55 PM
    lvmusicman
    lvmusicman Well-Known Member
    As per door jam info should be 30psi
    Bucci likes this.
  5. Jun 19, 2025 at 6:38 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    My TRD OR feels great… rides better than family’s lexus
    Tire pressures are correct
  6. Jun 19, 2025 at 6:41 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Once you come from a performance biased suspension, everything feels different. It's that issue of "once you know"... Something like that MT64 will address a lot of that harshness, and have a profile similar to the BP51s. Shameless plug, but let me know if we can help over here at Hotshot Offroad. We can get you all set up!
  7. Jun 19, 2025 at 7:27 PM
    dneal
    MidMO
    24 TRD OR 6M
    I'm well aware.
    I keep mine at 32.
    Ryan's Taco likes this.
  8. Jun 20, 2025 at 5:32 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    I keep mine at 32-33 as well they had them set to 30 last week when I got new tires but when it drops to 29 my light comes on
  9. Jun 20, 2025 at 5:57 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    You can set the pressure that TPWS considers "good".
    Settings-vehicle settings-TPWS Setting-Setting Pressure (p538 in manual)
    This sets the "good" pressure. Warning should come on if pressure drops %25 from that.
    Ryan's Taco[QUOTED] likes this.
  10. Jun 20, 2025 at 6:53 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    The structure is stout, but too many road imperfections are transmitted through the body versus the old OR’s setup, which was dialed to roll, pitch, and plow. Now the ride feels similar to Ranger, but not as bad as Frontier.
    This was Toyota’s first rodeo combining a Tacoma with rear coils, so I give them a mulligan on suspension tuning that feels like a work in progress. Knowing Toyota, they’ve probably taken copious notes and are already quietly testing different suspension tuning mules for the eventual refresh. If so, I’d be very interested if some of those tweaks can be applied to earlier models.
    taco terror, BearWithMe and gmtech like this.
  11. Jun 20, 2025 at 7:08 AM
    dneal
    MidMO
    24 TRD OR 6M
    There's a lot of internet confusion on tire pressure. A lot of folks think you look at the max pressure rating on the side of the tire, and use that. That's not a good idea. It makes for a harsh ride, increases wear to the center of the tread, and leaves little room for error and possible tire failure.
    Vehicle manufacturers put a sticker inside the door with the recommended pressure, which they calculate based on the general estimated weight figuring passengers and load. lvmusicman isn't wrong. That's the pressure you should generally use. The baseline, so to speak.
    The OEM tire on my OR is 265/70R17 115S. That's 265mm wide, 70% aspect ratio, 17" wheel, 115 load index and S speed rating.
    The load index tells you max load. For a 115 rating, it's 2679lbs. If you look at a load inflation table for that size metric tire, you'll see:
    PSI/Load
    26/2061
    27/2116
    28/2149
    29/2238
    30/2326
    31/2359
    32/2414
    33/2502
    34/2546
    35/2590
    36/2679
    The GAWR for the front/rear axle is 3480/3275lbs (1740/1637.5 per tire). Each of those pressures above is more than sufficient, and there are circumstances where you might choose one over the recommended 30 psi. Driving in sand and running a lower pressure is one example (and why Toyota offers an onboard compressor, to increase the pressure you might have intentionally reduced). You won't get any benefit over 36psi, as you've reached the max load. I chose 32 for improved fuel economy (I get 1-2mpg better mileage), with no perceived impact to ride quality.
    GTGallop and shotgunbilly420 like this.
  12. Jun 20, 2025 at 7:16 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    What should the tire pressure be for my BF Goodrich KO3s ??? They are 265/70/18 load E.
  13. Jun 20, 2025 at 7:21 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    39 psi would be what maintains the stock load.
    If you were basing it off of dneal’s choice to run 32 in his, then the adjustment for yours would be 42 psi.
  14. Jun 20, 2025 at 7:26 AM
    CrispyTacoLover
    How is 39 calculated? I looked but could not find definitive information.
    I’ve been running them at 37.
  15. Jun 20, 2025 at 7:31 AM
    BLtheP
    Plano, TX
    A tire pressure calculator helps, but you have to know how to use it and differentiate between the different types of tires (flotation (LT inch), P-metric, euro-metric (no P), and LT metric) The tire pressure calculator calculates what your stock tires are capable of at the factory recommended pressure, and then it finds where the new tire reaches the same point, and it suggests a PSI based on that, assuming it's not outside the limits of the new tire.
    Start by entering all the stock info on the left side. For this example I used a stock OR 4th gen with the 265/70R17 SL 115T tires. They are not P265/70R17, so you would choose the normal metric, not p-metric.
    So choose metric, then fill out the size details, and choose SL at the end, then 30 psi.
    Then fill out the new info, since the KO3 is a load E, it is an LT and is LT265/70R18. Choose load E, then calculate.
    Pretty easy, just have to know how to use the calculator. People mix up P and euro-metric all the time, and that throws off numbers and causes tons of confusion. If there is no P in the size, then it's not a P-metric. People don't seem to understand that not everything that isn't LT, isn't necessarily a P either.
    Something that may not make sense at first, is that non-LT tires (P-metric and euro-metric) include an overage of 10% because of the weaker relative strength of the tire. So you are actually always 10% over inflated. So when converting to LT pressures, you remove that 10% of load capacity, which is why in this case, we take the 2302 lbs the SLs are capable of, and match them with only 2116 lbs from the LTs.
    For your use, 37 isn't going to cause any trouble. It is still close enough and more than capable of carrying the truck. Have to keep in mind that the manufacturers don't always recommend pressure for tire life, they often add in some extra for mpg and less rolling resistance. Almost all factory recommendations are still over inflated to some degree.
  16. Jun 20, 2025 at 7:32 AM
    dneal
    MidMO
    24 TRD OR 6M
    Load index tables. They're different for metric, P-metric, LT, etc...
  17. Jun 20, 2025 at 7:37 AM
    Pappy Jon
    Pappy Jon Well-Known Member
    RZN60LV
    3RZ
    This is good to know. I run weight in the rear of my Tacoma full time. Bumper with swing-outs (gas/tire), and a camper. I'm getting the truck weighed next week specifically for this reason.
    On my Gen1 4Runner I have lots of weight too, and run more than the recommended pressure on the rear axle.
  18. Jun 20, 2025 at 7:38 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    An extra 2mpg, 12K miles/yr @$3.5/gal = $190/yr. Additional tire wear with an extra 2psi is probably minimal, so the savings would more than make up for slightly more tire wear. I used to run 35psi in my old Tacoma and noticed a solid 2mpg difference but the Pro suspension feels better at 30 (and way better than the as delivered 40psi).
    Play around with the psi. If you can't notice the difference in your seat, you will in your wallet (in a good way).
  19. Jun 20, 2025 at 7:48 AM
    CrispyTacoLover
    Thank you. I’ll bump them to 39 psi in the next few days.
  20. Jun 20, 2025 at 7:58 AM
    dneal
    MidMO
    24 TRD OR 6M
    Another thing to keep in mind is that a couple of pounds difference (within the "safe" range, of course), don't really matter.
    You gain/lose about 1psi for every 10 degrees difference in ambient temperature. Late winter/early spring where it's 20 in the morning and 60 in the afternoon? That's 4psi difference, even if you didn't move the vehicle.
    My truck is parked outside, with the passenger side facing east. In the morning once the sun rises, the two passenger side tires are 1-2psi higher than the driver's side. In the afternoon, that's reversed.
