TRD Off Road Tow Hook Torque Value...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GerhartCss, Jun 16, 2011.
  1. Jun 16, 2011 at 11:37 AM
    GerhartCss
    GerhartCss [OP] Well-Known Member
    Harrisburg, PA
    08 TRD Sport
    Pioneer AVIC-X710BT w/ PAC SWI-PS, Leaf Spring TSB
    Just like the title states, can someone with a Haynes manual or something similar tell me the correct ft/lbs torque for the Tow Hook. I need to know because I purchased the tow hook from another member recently.
    Thanks,
  2. Jun 16, 2011 at 1:26 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
  3. Jun 16, 2011 at 2:12 PM
    shane100700
    shane100700 Look'n like a fool with your pants on the ground..
    Fort Dix, NJ (MT born and raised)
    08 Off Road, DC
    Kenwood 6140 w/nav/BlueTooth/backup cam/ Focal Components/ Alpine PDX-5/ JL 10", rear storage lock mod, tint, Snug Top xtra vision, OEM running boards, XD Spy 18x9, Nitto Terra Gripper AT's, AFE pro dry, Ultra Gauge
    Sorry its not in the Haynes (yes I checked!)
    You can look at the radial lines, however our tow hook bolts only have 2 lines not the typical none or 3 (SAE). Nor are there any grade marking which is typical for metric. Your next best bet is measure the threads and diameter and "google" a bolt grade chart or something similar to see what would be rated based off the threads. Bolt torque specs are determined by material, thread, thread pitch, diameter, and grade (all of which play factors into "torque" specs).
    I would probably just call a Toyota service center and ask, or stop by on the way home from work if I was concerned enough to worry about it.
  4. Jun 16, 2011 at 3:44 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
