trd offroad e-locker off 09 question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lepedog23, Jul 2, 2010.
  1. Jul 2, 2010 at 10:36 AM
    lepedog23
    lepedog23 [OP] Taco Rookie
    Frank
    Huntington Park
    Wrecked 2002 4Runner 4x4 trying to rebuild ***Sold2001 DC Tacoma. Stock. Salvage Title MOD.
    Wrecked 2002 4Runner 4x4 ***Sold 2001 Tacoma, Salvage Title MOD. ***Sold 2010 Tacoma doublecab prerunner
    hey guys have a question about a factory elocker. i want to buy a rear axle with e-locker to put in my 2010 taco, since i didnt get it when i bought truck in january.
    i found a 09 taco trd offroad with rear locker. i heard that only the 05-08 tacos have an actual mechanical locker, and 09+ dont. is that true?
    dont want to waste my money on the rear axle with locker if it wont work.
    i saw the dash and it says rr diff lock, so it does have a locker but should i go for an 05-08 or are they all the same?:confused: thanks for looking.
  2. Jul 2, 2010 at 10:40 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    No, you have them confused with the mechanical (05-08) vs. electric (09-present) Limited Slip Differential. The e-lockers are the same from 05-10 however the axles may have different sensors for Atrac and such.
  3. Jul 2, 2010 at 11:32 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I've read a few write ups of guys swapping out axles for the e locker, and it seems like a lot to do. There's more to it than just the axle, I dont know the specifics, but you have to do something with switching the computer control (or whatever its called) for the locker as well. Maybe look into the ARB locker as another less involved option.
  4. Jul 2, 2010 at 11:37 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can wire it up without that.
  5. Jul 2, 2010 at 11:39 AM
    lepedog23
    Frank
    Huntington Park
    but its still a locker right from the 09. it will work on my 2010 right... i have lsd now. so is that what you meant by mechanical and electric? are all lockers mechanical? or did they switch to electric 09+ but still does the job right, just want it incase i get stuck.
  6. Jul 2, 2010 at 11:41 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    ahhh tacomaville i knew it was something.. just the LSD's then.
    yes you can wire it up without the ECU but your ABS will be on,if that matters to you(i havent tried this way though)
  7. Jul 2, 2010 at 11:42 AM
    lepedog23
    Frank
    Huntington Park
    yeah 12voltguy.com makes a harness...
  8. Jul 2, 2010 at 11:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    A locker from an 09 will work in your 10, yes. The LSD you have is electrical. All lockers (in re TRD) are mechanical. The engagement is control via an electrical switch that activates a drive motor which engages the mechanical portion of the locker.
    Remember, just because you have a locker doesn't mean you will not get stuck or unstuck for that matter. It's only as good as the driver that knows how to properly use it. Personally, I would leave the LSD axle in there, but it's your truck.
  9. Jul 3, 2010 at 12:13 AM
    lepedog23
    Frank
    Huntington Park
    really? why... i dont know i think ill need it as i start building my truck for offroad use....
    what is the difference between lsd and locker? and why is one better than the other?
  10. Jul 3, 2010 at 12:40 AM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    I have the 2006 Tacoma 4x4 TRD Sport Long bed which has the LSD. It has not let me down so far when I'm off roading, but I will say that the idea of a locking rear Diff has crossed my mind a few times already. Not sure if it would be worth all the work unless I put a solid axle up front. I may do that in the near future, not sure.
    From your album:
    BigRubbers4X4.org
  11. Jul 4, 2010 at 3:47 AM
    lepedog23
    Frank
    Huntington Park
    but you have 4x4... im pretty much a 1x2 right now since i only get power out of one wheel all the time... atleast if i got trd e-locker ill have power out of 2 wheels when i need it.... what do u think????
  12. Jul 5, 2010 at 12:39 AM
    lepedog23
    Frank
    Huntington Park
  13. Jul 5, 2010 at 12:45 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    you should be able to do the "break" LSD fake technique and fake locker like conditions.
    However, your rear is not a 'real' LSD as it uses braking to transfer power instead of clutches in the diff to transfer power. The 09+ trd off-road e-locker diff is the same diff as the other 6 luggers with the added e-locker.
    For the costs of getting the computers, button, wiring, ect... a stronger ARB locker that you can engage any time you want, damn near any speed you want is a better bet for the cash. Plus, you'll now have on-board air for re-airing up tires when your done with the trails. On a 4x2... you'll need to be airing down a lot no question.
  14. Jul 5, 2010 at 6:27 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    You wanna put a locker in a 2wd truck? lol.
    Dude, nothing can replace 4WD, not even a locker. You need 4WD first, then worry about a locker.
  15. Jul 5, 2010 at 7:37 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    A locker will make the vehicle more capable than it currently is. This holier than thou 4x4 crap is really getting old.
    My prerunner with the e-locker did way more than I thought would be possible. At the time, the prerunner was all I could afford, and for a daily driver it still had the ability to have some fun out in the desert with the locker. Sure it wouldn't climb rocks but it was still a capable, perfectly fine vehicle for my needs. When it came time to get another I did get a 4x4 because I knew I actually would use it now. It all depends on the owner's application, their needs, and their wants.
  16. Jul 5, 2010 at 8:01 AM
    pauldotcom
    Paul
    MA
    "4x4 holier than thou" lol.
    Dude you DONT need a 4x4 if you are not going off-road, its what its designed to do.
    You NEED 4x4 if you are going off=road, it is what it is designed to do. I am not putting anyone down, I'm just saying if you are going off road the first thing you need to consider is 4X4 before ANYTHING. You cannot replicate the push/pull by installing a locker.
  17. Jul 5, 2010 at 11:16 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    If you read my statement, I just said you need it for certain applications, not all off-road. Not everything is mudding, rock crawling, and massive suspension flexing crawling. Locked 2WD's do just fine in higher speed desert running and upwards of most class 3 trails (if pre-runner or lifted).
    Let the man enjoy his truck.
  18. Jul 5, 2010 at 1:02 PM
    pauldotcom
    Paul
    MA
    Your right a 2WD is great for high speed desert runs. If I lived anywhere south of North Carolina, I would own a Pre-runner! The only reason I own a 4WD is because of weather conditions where it is needed. But, I will still stand by my statements, even with mild off roading, 4WD is a much bigger benifit then a locker is.
  19. Jul 5, 2010 at 5:31 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    It all depends on the application. I do not do any serious 4 wheeling, but a regular 2wd truck has problems out running around the hunting grounds. This is where a rear locker or LSD would make the biggest difference. I'm not looking for 4x4 capabilities - I didn't buy a 4x4 - I'm just looking to not get stuck so easily. Like the OP, I'm looking around at sticking a locker or LSD in my PreRunner.
  20. Jul 7, 2010 at 11:52 AM
    lepedog23
    Frank
    Huntington Park
    yeah i dont need 4x4 since i wont be doing mud i want it for desert running, plus im in socal lol. so i heard 2wd are better for desert running(its what i heard, no one get offended, lol) i didnt know anything about tacomas when i bought mine in january so i just went with cheapest. im getting the locker for a great deal so thats why i want to jump on it since they arent cheap, i plan on keeping my truck for along time to just want to get some more capabilities out of it. plus this is probably the last thing im going to put into my truck this year since my bank account has slowly dropped... :0( its never wasted money when its going into the tacoma. but yeah going to put this locker on and save to get my coilovers, ucas and spindles next year. thanks for your input guys.
