TRD OFFROAD Hood Vinyl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sliderule01, Jan 23, 2018.
  1. Jun 9, 2020 at 2:48 PM
    #981
    ac8888
    ac8888 Active Member
    Alan
    2017 silver tacoma TRD offroad
    replace head light with Morimoto LED.mounted tyger rock slider
    post #132 in page7
  2. Jun 12, 2020 at 7:47 AM
    #982
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I called around nobody would install it. I give up.
    anyone want to buy this from me? I bought back in august 2019 if I remember correctly.
  3. Jun 12, 2020 at 8:07 AM
    #983
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    What style/size?
  4. Jun 12, 2020 at 8:36 AM
    #984
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    You don’t need steady hands. It’s a giant piece of vinyl that ‘floats’ until you squeegee it into place. IE, super easy and user friendly install. Don’t let the scale intimidate you. If you have some legit physical hindrances, I understand. Otherwise, sac up and get after it.
    Also, while the rapid-tac stuff is probably great, it’s not mandatory. I find a clean surface and a good solution of water/baby soap works just fine.
    boston23 likes this.
  5. Jun 12, 2020 at 11:28 AM
    #985
    Kamille.bidan
    2017 Blue TRD OR MT
    I bought the largest one and professional application was recommended. I have a heat gun and it’s cold today. Maybe I should
    Just do it.
  6. Jun 12, 2020 at 11:31 AM
    #986
    backcountryj
    Jonathan
    GA
    Sounds like you fall into the ‘otherwise’ category.
    FWIW, mine is/was the largest option as well. Installed solo. Easy peasy
  7. Jun 12, 2020 at 11:37 AM
    #987
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    If you decide to sell let me know.
  8. Jun 24, 2020 at 10:05 AM
    #988
    thetimegivenus
    thetimegivenus Member
    Tennessee
    2016 White TRD Off-Road
    Just got mine in. Any special weather concerns regarding installing it? Obviously wouldn't want to do it in the rain, but it's been super hot here in TN and I'm not sure if that will effect things. I know some vinal is more or less heat activated but I've got the Rapid TAC fluid so not sure if that stops the heat from effecting things.
    Thanks
  9. Jun 24, 2020 at 1:12 PM
    #989
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Better to do it on a cool hood and not in direct sunlight. I had my hood very wet with lots of solution until I was happy with the placement then started the squeegee process to remove bubbles.
  10. Jul 1, 2020 at 9:27 AM
    #990
    sliderule01
    sliderule01 [OP] Well-Known Member
    Jersey Shore
    2020 DCLB TRD OR QS
    Absolutely DO NOT try install in direct sunlight, particularly when the hood is hot. The vinyl is very thin, and any manipulation will stretch the material and ruin it. You need to lubricate the hood and "float" the decal around until it's in the right spot. Then patiently squeegee the air bubbles out starting from the center.
  11. Aug 1, 2020 at 7:47 PM
    #991
    pandonsf
    pandonsf Well-Known Member
    Brandon
    Millbrae, CA
    2019 Tacoma TRD Off-Road
    I have a extra wide with logo that I decided not to install if anyone is looking for one.
  12. Aug 2, 2020 at 9:33 AM
    #992
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    How much?
  13. Aug 2, 2020 at 9:47 AM
    #993
    pandonsf
    Brandon
    Millbrae, CA
    $80 shipped
  14. Aug 2, 2020 at 6:51 PM
    #994
    TacoLoco2017
    TacoLoco2017 Member
    2017 Cement Tacoma TRD Pro
    I’ll pick it up if it still available
  15. Aug 2, 2020 at 7:17 PM
    #995
    pandonsf
    Brandon
    Millbrae, CA
    Yup, shoot me a pm
  16. Aug 3, 2020 at 6:01 AM
    #996
    TacoLoco2017
    TacoLoco2017 Member
    I just sent you a pm.
  17. Nov 14, 2020 at 11:22 PM
    #997
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    Tried something different...
    twolane and hwntaco20 like this.
  18. Feb 5, 2021 at 11:28 AM
    #998
    Dmwood1984
    Dmwood1984 Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    Anyone know if these are still being made? Got one a few years ago and it’s starting to peel a bit from the weather, looking to order again and replace
  19. Mar 21, 2021 at 8:17 PM
    #999
    Mammothbound
    Mammothbound Active Member
    2012 Tacoma TRD 4x4
    Just Beginning
    Does anyone know where I can get this decal for a 2012 Tacoma?
  20. Apr 18, 2021 at 8:54 AM
    #1000
    fkLymphoma
    fkLymphoma Well-Known Member
    Seth
    2020 Cement Tacoma OffRoad
    Who do I contact to order ?
