TRD offroad shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeeptec, Aug 13, 2018.
  1. Aug 13, 2018 at 10:23 PM
    jeeptec
    jeeptec [OP] Active Member
    Eric
    2018 Metallic Grey 4door
    I size up tire
    Are The front Bilstien shocks used on the TRD offroad package do they have a the adjustable c ring to raise the truck? I'm going from the stock Goodyear 265/70/16 tire to Falken wildpeak 265/75/16 that's 1 inch overall diameter increase. I also had a Lear shell put on my truck and now it sits almost level. I would like to raise it 2 inches front. 1.5 rear.
  2. Aug 13, 2018 at 10:28 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Stock front TRD OR shocks aren’t adjustable.
  3. Aug 13, 2018 at 10:55 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Get Bilstein 5100s all around. Keep your stock front springs (set spring perch for desired lift) and add a leaf for your rear height gain. You will not regret it one bit, and it’s relatively innexpensive. Stock TRD OR Bilstien shocks are terrible with a canopy. I suffered for over a year but didn’t realize I was suffering. I was convinced Toyota knew best. I was hitting the bump stops all the time, not to mention uncertain handling a brake dive. 5100s cleared it all up and are smoother, less harsh as well. Just all around better. There are lots of more expensive options but this worked great for me.
  4. Aug 14, 2018 at 1:38 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Those tires will fit the truck with no lift. If you want lift, get some sort of shock upgrade. 5100s are adjustable and common. But lots of options based on what you do and want the truck to do.
  5. Aug 14, 2018 at 1:46 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Yup. I ran duratrac 265/75r16 in c load no problem before I lifted.
    And I think they still look fine after the lift.
  6. Aug 14, 2018 at 4:06 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Sorry bud, stock shocks are not adjustable.
    Like mentioned above, you'd have to upgrade shocks/springs to achieve lift
