TRD Offroad & Sport Differences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Austin Taco, May 1, 2009.
  1. May 1, 2009 at 12:58 PM
    Austin Taco
    Austin Taco [OP] Well-Known Member
    Pflugerville, TX
    08, TRD Sport, double cab, long bed
    I have an 08 2WD TRD Sport. It has posi tract...tow package and is nicely equipped.
    What is the difference between the TRD Off Road and the TRD Sport? Is it just the Off Road is 4WD?
  2. May 1, 2009 at 12:58 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Hood scoop and locker are the biggest differences
    2008 was the last year that the TRD Sports came with an actual LSD.
  3. May 1, 2009 at 1:00 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    he nailed it^^. Also you have 17" alloy rims and the off road comes with 16" alloys
  4. May 1, 2009 at 1:04 PM
    Austin Taco
    Pflugerville, TX
    Sorry....I also have the hood scoop. What is LSD. Well...I know what LSD is but in the LSD you referenced what does it mean?
  5. May 1, 2009 at 1:07 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    sport has the scoop and a limited slip differential. The off-road has no scoop and the locker.
  6. May 1, 2009 at 1:19 PM
    Austin Taco
    Pflugerville, TX
    So what's the locker and the difference between it and the limited slip.
    Sorry for the questions...I'm a newb to Taco's.
  7. May 1, 2009 at 1:26 PM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    The locker will have both wheels in the rear spinning the same time and the LSD will have one wheel pick up for the other wheels loss of traction
  8. May 1, 2009 at 1:29 PM
    Austin Taco
    Pflugerville, TX
    OK...that's what I thought so here's where my confusion comes in.
    The other day I tested this out. I was in a sandy area and spun the rear wheels. Afterwards I looked at the tracks I made and both wheels spun the same distance and what appeared to be the same depth.
    If it was limited slip wouldn't the tracks have looked differently? Or am I just reading too much into this and need to shut up?
  9. May 1, 2009 at 1:46 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It should look pretty equal. The big difference in how a locker and LSD perform is what happens when one wheel comes off the ground. The LSD will send most of it's power to the wheel off of the ground because it is spinning freely. The locker will continue sending 50% to each wheel.
  10. May 1, 2009 at 1:53 PM
    Russ
    Russ Member
    05 Reg Cab 4x4
    I to am new to TW, but i recently bought a 07 TRD sport. Do all TRD Sports come with the LSD or is that something extra?
  11. May 1, 2009 at 1:57 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Up until 2009, all TRD Sports came with the LSD.
  12. May 1, 2009 at 2:11 PM
    Joe B
    Joe B Well-Known Member
    Sport's come with painted bumper,grill surround,side mirrors....
  13. May 1, 2009 at 3:27 PM
    bobder41
    bobder41 Active Member
    Bob
    Florida
    2023 Tacoma Limited SB
    Just got an email back from Toyota on my 2009 TRD Sport 2wd DB LWB. It has the limited slip diff. According to Toyota of America the limited slip was dropped fro the standard models
  14. May 1, 2009 at 5:49 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    all 2009's have the auto-lsd....prerunner, 4x4, sport, OR, all hav the auto lsd....only difference is the OR also has the locker since the auto lsd isnt in the rear diff
  15. May 6, 2009 at 6:07 PM
    bobder41
    Bob
    Florida
    Jhodge83,
    Is Toyota using the brakes as a limited slip device?
  16. May 6, 2009 at 7:23 PM
    The_Hodge
    SC
    yep....the auto lsd is completely controlled by the computer and braking
  17. May 7, 2009 at 7:46 PM
    bobder41
    Bob
    Florida
    thanks for the info but that sucks would much rather have clutch pack, Toyota also said that the feature od
    of lsd was dropped fom the 4 cyl base models
