Trd offroad stuck in the mud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EHam, Jan 27, 2019.
  1. Jan 27, 2019 at 10:36 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I saw that but...apparently he wheels enough to get stuck in the mudrpyqxrxKyMXHnavCpZzV.gif just pointing out that if OP wants to wheel occasionally AND he might encounter this again, M/T's might not be a bad idea...;)
  2. Jan 27, 2019 at 11:13 AM
    Muddinfun
    Muddinfun Well-Known Member
    This right here. That truck had no business going in there. Also, with standing water, you have no idea if the ruts were made with 33s or 44s.
    Since to OP has a TRD OR, at least he has a halfway decent place to hook a tug strap. A much better attachment point is something that you can hook a shackle to. It amazes me when people go out wheeling in serious mud with no attachment points.
    Also, NEVER EVER EVER use a chain or cable as a snatch strap. I once saw a broken chain go through the back window of a truck and busted open a girls head. They rushed her to the hospital. I don't know what the outcome was.
  3. Jan 27, 2019 at 11:16 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I use and have used "tow straps" you can get them with the loops too and not just the hooks. Have you ever seen a snatch strap break? It acts like a giant rubber band and when they break WOW! it's like a giant rubber band. Both can be extremely dangerous and you should use caution and common sense around all recovery efforts.
    TacoTRD78 likes this.
  4. Jan 27, 2019 at 11:17 AM
    fe650
    fe650 Well-Known Member
    Wow. Like call the police on the guy.
  5. Jan 27, 2019 at 11:19 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    All our trucks have a decent tow/recovery point in the front on the DS it's welded to the front. I've used the crap out of this point on my truck and others. The rear is a different story if you have the receiver that's your recovery point.
  6. Jan 27, 2019 at 11:23 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    I'd have kept a short strap already connected to my front and just draped it over my driver mirror If I was just going to commit to it.
    And have counted on a friend
  7. Jan 27, 2019 at 11:33 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Shoot since he doesn't want to get into the M/T world there are a lot of good more aggressive hybrid/ A/T tires that will do better than K02. I am not a fan of those either I think they are over hyped and from what I've seen not nearly as good as some others on the market.
  8. Jan 27, 2019 at 11:42 AM
    Muddinfun
    OK, I confess. I dug those ruts.
    whatstcp, bax, EHam[OP] and 2 others like this.
  9. Jan 27, 2019 at 11:42 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It is all part of learning how to drive off road and learning your, and your trucks limitations.
    Grey 2015 likes this.
  10. Jan 27, 2019 at 11:44 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Shovel and traction pads will help here. May take a while. Good luck OP
  11. Jan 27, 2019 at 3:06 PM
    EHam
    EHam [OP] Well-Known Member
    Eric
    Charlotte, NC
    2011 DCSB TRD Off-road
    That mud hole was just deeper than i thought. I should have gotten out to check before hand but here we are. I think i would have been fine if i would have stayed out of the ruts and carried more speed...lesson learned. I have Wildpeak at3w's. Theyre great tires but definitely no m/t's. First thing im doing is purchasing a pressure washer then replacing the diff fluid. Ill keep an eye on the brake fluid as well.20190127_173639.jpg
  12. Jan 27, 2019 at 3:26 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Glad you got out!!!!
    EHam[OP] likes this.
  13. Jan 28, 2019 at 2:34 AM
    fe650
    That's how the fun begins and glad you're investing in a power washer. Toyota makes a solid truck/SUV, I have used them in many different countries, environments and situations.
    If you drive in locations with a lot of standing water, do the differential breather relocation mod.
    EHam[QUOTED][OP] likes this.
  14. Jan 28, 2019 at 3:28 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    In order to activate the ATrac you must be in 4lo and in park. If you activate the A trac plus the rear diff lock your truck will have a lot more traction however this doesn't help with deep ruts. Assessing the situation and picking the right line will help significantly. As far as recovery gear goes a Hi-lift is nice but make sure you read and understand how to use it also keep it clean and well lubed. Kinetic ropes are also a great tool and so is a shovel.Oh and do a rear diff breather mod you dont want to get any of that mud nasty in your diff
  15. Jan 28, 2019 at 4:23 AM
    #35
    EHam
    Eric
    Charlotte, NC
    I agree i dont think ATRAC would have helped me but id like to know its working correctly. Ill have to go back out there, prepared this time, and check it out. I was always meaning to do the diff breather mod but never got around to it. Is there a mod for the front as well?
  16. Jan 28, 2019 at 5:05 AM
    #36
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I believe the front breather in stock form ends up almost the same height as the top of the engine cover so it's already pretty high up if I recall correctly.
    The rear is the main one you would want to worry about, I re located it in my gas door area myself. Nice looking truck btw.
    TacoTRD78 and EHam[QUOTED][OP] like this.
  17. Jan 28, 2019 at 6:38 AM
    #37
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Let us know if there was any water in there without the diff breather mod, just wondering.
    I ran mine up to the storage compartment on the DS of the bed.
  18. Jan 28, 2019 at 6:59 AM
    #38
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Nothing like being framed to feel helpless. I had a buddy call me from an undeveloped section in our community. TRD OR but none of the fancy bells and whistles help when your sitting on your frame.
    Having good tires is also a night and day difference with clearing out the lugs for the slick mud :thumbsup:
    Skyway, TacoTRD78 and whatstcp like this.
  19. Jan 28, 2019 at 7:06 AM
    #39
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    What happened to your hitch?
  20. Jan 28, 2019 at 7:46 AM
    #40
    EHam
    Eric
    Charlotte, NC
    Thats just caked on mud. The only damage i could see so far is the chain safety eyelet is bent from being pulled on. Without a shovel, thats the only hookup point i could get to.
