TRD OR AC 4x4 hesitation when pulling out in traffic on full accelleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Outlier, Aug 29, 2016.
  1. Aug 29, 2016 at 4:52 PM
    #61
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    Testing some marketing slogans for our trucks. Thoughts?
    Toyota
    Going places - when we get around to it...
    Toyota
    Going places - just gimme a couple of seconds over here!
    Toyota
    Going places - after a brief pause for some calculations...
    I'm here all night people. :D Just kidding I'm logging off soon. I've had the lag before as well. Only 3 times so far, and mostly when I'm making a left turn across three lanes of oncoming traffic. :annoyed:
    uvedoneitnow and Kilokato like this.
  2. Aug 29, 2016 at 5:00 PM
    #62
    mcmmotorsports
    mcmmotorsports Well-Known Member
    Michael
    2016 MGM Tacoma TRD OffRd Access Cab
    I have a hesitation/stutter issue when accelerating, half to 3/4 throttle. It is very annoying. I really thought the transmission TSB would've fixed it, but it didn't. It is definitely not a characteristic of the Atkinson cycle engine as I have a Prius and have no problem at all with that. I am in the process of trying 93 octane fuel but want to give it a tank or two. I really want to love this truck, I really do.
    busticator likes this.
  3. Aug 30, 2016 at 4:09 AM
    #63
    Outlier
    Outlier [OP] I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    Great! Driving advice... Now THAT answers my question. Silly me. Shouldn't you be in the 2nd Gen playroom?
    Kilokato and hastingsrussell like this.
  4. Aug 30, 2016 at 4:11 AM
    #64
    Outlier
    Dallas GA
    Thank you sir! Same exact scenario that i have experienced. I'll bring it up at my 25K service and see what the fine folks at Cobb County Toyota think.
  5. Aug 30, 2016 at 4:12 AM
    #65
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Atkinson is only ran during light load cruising. so this would not be your problem
  6. Aug 30, 2016 at 4:13 AM
    #66
    Outlier
    Dallas GA
    Thanks Frank!
  7. Aug 30, 2016 at 4:14 AM
    #67
    Outlier
    Dallas GA
    Light does not flash in this instance.
  8. Aug 30, 2016 at 4:17 AM
    #68
    Outlier
    Dallas GA
    The topic of this thread is an acceleration issue i am having from a dead from a dead stop but thank you for your input.
  9. Aug 30, 2016 at 4:19 AM
    #69
    Outlier
    Dallas GA
    Thanks for reading guys..... THIS HAPPENS FROM A STOP!!! NOT A MERGING WHILE CRUISING ISSUE!!!
  10. Aug 30, 2016 at 4:21 AM
    #70
    Outlier
    Dallas GA
    No. Total power loss like it's starving for air or fuel.
  11. Aug 30, 2016 at 4:32 AM
    #71
    Gutt Pile
    Gutt Pile Well-Known Member
    2016 Blazing Blue TRD Offroad
    Had this happen 3 times. Two of them going up my driveway which is a very steep hill. I attributed it to me treating the throttle like a traditional SUV/car and not punching it hard enough , nannying it. If I drive my wife's pilot the way I drive my truck I will wreck it. The SUV is just that much more responsive. Lesson learned from a 12 hour road trip. Use ECT to get on the highway or to pass. It works. If there was a way to just leave it on I would. The mileage difference is almost negligible if not slightly better with it on/depending on driving style.
  12. Aug 30, 2016 at 4:36 AM
    #72
    Outlier
    Dallas GA
    Nice. Thanks. Once again, not talking about being on the freeway. This is from a dead stop but thanks for chiming in.
  13. Aug 30, 2016 at 4:38 AM
    #73
    Outlier
    Dallas GA
    It doesn't help my problem from a dead stop any... but i have turned it on every time i drive for the last two tanks of fuel and went up 1 MPG of both tanks! Funny since the manual states it will lower fuel efficiency!
  14. Aug 30, 2016 at 4:55 AM
    #74
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    This might be a far reach but on the Eco cars some have been known to actually get stuck in eco. For example my dads Honda Pilot is a v6 but opens the valves on eco mode for 3 pistons eccentrically running on three pistons. My dad just had to get the head pulled and replace 3 piston rings after 50k miles... the 3 rings that shut off during eco mode. Then my dads friends actually has had his 3 three pistons not come back after it went into eco mode causing it to drive like a dog.
    Your truck might be experiencing a bug when you accelerate from 1/2 to full peddle where it will not switch out of atkinson cycle. If the issue wasn't present before the TBS update might have caused another bug which is known to happen in programing. The atkinson cycle actually only performs in a very narrow range on the rpm band after that the lack of compression hinders and acceleration and/or performance.
  15. Aug 30, 2016 at 5:00 AM
    #75
    TacoRD16
    Houston, TX
    I also get better mpg driving in 5th or with the ECT pressed. For me I work, work out, eat and etc all with in a 5 mile radius so the stop and go is not ideal for the atkinson cycle since it only performs in a limited rpm range. The atkinson cycle hinder my performance and drops my mpg quite significantly.
  16. Aug 30, 2016 at 5:44 AM
    #76
    Outlier
    Dallas GA
    My sincerest apologies for coming off "a little like a jerk". Hopefully there has been no permanent damage to your safe space. Maybe i should put a trigger warning on this post for fragile souls.
    There, now i am a total jerk. Mission accomplished.
  17. Aug 30, 2016 at 6:16 AM
    #77
    TacoRD16
    Houston, TX
    Instead of apologizing and fixing his first post he just insults further. Don't worry its just his way of coping for his mistakes.
    Kilokato, 2016_dbag and DesertTaco4x4 like this.
  18. Aug 30, 2016 at 7:11 AM
    #78
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Any way you can have someone film your RPM's and speed from a stop while you press the gas down hard?
    Might help others determine if theirs does the same.
  19. Aug 30, 2016 at 7:37 AM
    #79
    Outlier
    Dallas GA
    My friend, if i make a mistake i OWN it and make it right. Coping is for chicks and little boys who let WORDS hurt them.
    DesertTaco4x4 likes this.
  20. Aug 30, 2016 at 9:02 AM
    #80
    TacoRD16
    Houston, TX
    Who says anyone was hurt? Did you not ask for help and did not update the first post after the 1st time you had to correct your statement? Is that not a mistake?
