TRD OR AC 4x4 hesitation when pulling out in traffic on full accelleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Outlier, Aug 29, 2016.
  1. Aug 31, 2016 at 4:09 AM
    #101
    Outlier
    Outlier [OP] I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    Were you making a right or left turn? Mine does not do it either if i am headed straight. Let me know and thanks for the input.
    smitty99 likes this.
  2. Aug 31, 2016 at 9:58 AM
    #102
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    My tires will not chirp. Maybe if the roads were wet from the rain, or if there is a little bit of gravel under them... haven't tried either of those conditions yet. I know, it's a truck. Only truck I've had or driven that won't spin the wheels though.
    Understand the pulling out from a stop thing (I've had the issue). Also a tremendous, yet intermittent lag sometimes when passing.
  3. Aug 31, 2016 at 10:12 AM
    #103
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    These comments make me think the automatic transmission is failing to quickly shift. You punch it and the transmission is struggling to shift into that lower gear... if the RPMs raise and you aren't accelerating the transmission is without question not fully engaged in a gear. Think about the lag people experience when shifting from park to drive, drive to reverse, etc and then apply that into your scenario... sound familiar? Once it finally gets in gear the revs are already high so it launches.
    My 2 cents. I only read the first 2 pages. Perhaps this has already been discussed in later pages.
  4. Aug 31, 2016 at 10:20 AM
    #104
    mcmmotorsports
    mcmmotorsports Well-Known Member
    Michael
    2016 MGM Tacoma TRD OffRd Access Cab
    I am tempted to pull this 6spd Auto out and replace it with a damn OG TH350.
    Outlier[OP] likes this.
  5. Aug 31, 2016 at 11:05 AM
    #105
    Outlier
    Dallas GA
    This is taking place from a stop... The truck should already be in the appropriate gear.
  6. Aug 31, 2016 at 11:06 AM
    #106
    Outlier
    Dallas GA
    And a 350 Crate motor. MPG's would probably be better too...
  7. Aug 31, 2016 at 11:14 AM
    #107
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    I have experienced something similar, and in my case it happens when I am turning left onto a busy 4-lane road with a 45mph speed limit (which means 55+ in Texas). It accelerates fine to get across the 2 lanes closest to me, but when I turn left after crossing the median, and punch it, it just sits there for a second before it suddenly goes like crazy up to 3-4000 rpm. My assumption has always been that it was a problem with the computer trying to upshift too quickly. When I am crossing the 1st two lanes under load, it stays in a lower gear, but as soon as I lift off the pedal to turn left, it senses the lighter load, assumes I have reached the speed I want and upshifts. When I get back into the gas, it is in the wrong gear, has to sit and think about whether it can generate enough torque, before it finally decides to downshift. Meanwhile, my foot has continued to push the pedal further and further down while my nethers pucker up watching the cement mixer bearing down on me. Finally, the downshift happens and the truck launches like a Taco Bell burrito after a hard night of drinking.
    I haven't tried it with the ECT on, but I bet it will help, since the truck isn't so quick to upshift with ECT engaged.
  8. Aug 31, 2016 at 11:20 AM
    #108
    Outlier
    Dallas GA
    That could definitely explain it from a crawl or from a 'start and then let off' situation like when i turn left out of my subdivision on to the divided hwy. Would make a lot of sense. I am still really puzzled about why it happens turning right from basically a dead stop at other times.
    Thanks for your input!
  9. Aug 31, 2016 at 11:25 AM
    #109
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I was able to get both to break free after disabling traction control and turning hard right out of stop sign. But it was pretty weak.
  10. Aug 31, 2016 at 11:25 AM
    #110
    Doggman
    Alabama
    2017 TRD OR MT
    Could be a torque converter issue. You aren't really in 1st until it locks up which doesn't happen until you are rolling out. The fact that RPMs are raising and you aren't accelerating indicates a transmission issue to me. It's not properly in gear when that happens whether it be because of a delayed shift or malfunctioning torque converter. I suppose it's possible the ecu is misrepresenting RPMs on the tach and the engine isn't actually revving but I imagine you'd be able to listen and hear if the engine is actually revving or not.
  11. Aug 31, 2016 at 11:26 AM
    #111
    txags92
    Well, the posters speculating about traction control have me wondering as well. When I have it happen, it is usually when I am turning left into the near lane of the two lanes going right to left. Turning into the far lane doesn't seem as difficult (but also may just be because I can do that when traffic is lighter and I am not trying to immediately accelerate hard). The way the median is setup there makes for a pretty sharp turn to stay in the left lane, especially since I have a DCLB. I just assumed I was letting off the gas a little more for the tighter turn and encouraging the upshift. But now, I am wondering if the sharper turn is causing the traction control system to sense a disparity between the speed of the two rear wheels and cutting the power to avoid spinning them. That would explain it happening if you were making a sharp right turn out of your subdivision as well. I may go out and try it a few times with ECT on and then a few times with traction control off over the next couple of weeks and see if I can see a difference.
  12. Aug 31, 2016 at 11:33 AM
    #112
    Outlier
    Dallas GA
    In my particular case, there are no raised RPM's during the lag period, it's like the f*cker is dead. RPM's only raise right before i sh*t all over myself and it finally takes off.
  13. Aug 31, 2016 at 11:36 AM
    #113
    Outlier
    Dallas GA
    After 22K miles, I am now most positive that the traction control was not meant to control the raging power of the gutless wonder 3.5 on dry pavement from a standstill.... FACT!
  14. Aug 31, 2016 at 11:41 AM
    #114
    AZTruckin
    AZTruckin Well-Known Member
    Arizona
    17 TRD Sport DCSB 4X2
    When the TSB came out for the tranny, were the dealers supposed to automatically update all the Tacomas? Salesman I spoke with said that only do it if you come to them complaining of the problem.
  15. Aug 31, 2016 at 11:45 AM
    #115
    jdiru
    jdiru Well-Known Member
    Jeff
    southern NH
    2016 Taco DCSB TRD OR- MGM
    It seems like the torque converter is still locked up when you rolling to a stop or going slow in traffic... mines does it in traffic in this situation. Also I do think the atkinson cycle issue could also have something to do with how fast it changes over to give it more supposed power.
    Overall I'm disappointed in this engine and tranny. I guess I should have got a full size if I wanted real power.
  16. Aug 31, 2016 at 11:45 AM
    #116
    Outlier
    Dallas GA
    I had to ask at my current servicing dealer. That was after my truck sat in the shop for three days at another dealer while they scratched their heads and told me mine was normal and that they had had no other owners complain about any of the tranny issues. That was before the TSB was released.
  17. Aug 31, 2016 at 11:47 AM
    #117
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Coming from a full size Chevy that did the same thing cause of electronic transmissions. The ones that did it the least were the F150's.
    Basically this truck has power but it's specific about where you can make it, the Chevy did the same, unless you hit the tow/haul mode, then it was a beast.
    If you don't need the extra towing and hauling and interior room...which I no longer do, the size and agility of a smaller truck is so much nicer. It's just a matter of opinion.
    However, I felt as you did with my 2011 Tacoma, and that's why I bought a V8. I got that out of my system and now we are back here where I truly am happy to be. If you feel you need, you really need to try it, so you can know for sure. Sounds like you're on the fence, and it truly sucked to be there...I was there a few years back.
  18. Aug 31, 2016 at 11:51 AM
    #118
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Also, regarding TSBs, the dealer won't do a TSB automatically. That's a recall. The TSBs are like a tool they can use to address a specific issue. If you're not complaining about the issue, they aren't going to do it.
  19. Aug 31, 2016 at 11:54 AM
    #119
    AZTruckin
    Arizona
    Alright thanks!
  20. Aug 31, 2016 at 1:09 PM
    #120
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Yeah I would say about two seconds, it did not take off like a bat out of hell but power did resume after the pause. Love my truck so far but this one thing made me think WT? $.02
