TRD OR front hooks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supralight, Mar 12, 2011.
  1. Mar 12, 2011 at 9:59 AM
    supralight
    supralight [OP] Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Could anyone enlighten me on why there are 2 types of hooks on the front of my tacoma TRD OR?
    So far, I have used only the smaller ''U'' shaped one for taking people out the ditch or unstuck them. Even once, a guy was so deeply stuck in the snow, that I had to violently rock his vehicle out, also using the ''U'' shaped hook, and it held very well the abuse.
    So, if the ''U'' shaped hook does the job and is solid enough, why do I also have a bigger ''L'' shaped hook on the other side?
  2. Mar 12, 2011 at 10:35 AM
    JKD
    JKD Well-Known Member
    The "U" shaped 'hook' is supposed to be a tie-down point for the truck for transport. Everything I've heard here and in the owner's manual says that it's not supposed to be used for recovery purposes.
  3. Mar 12, 2011 at 12:54 PM
    supralight
    Dan
    Earth
    Oops!!! Thank you for the warning.
    Anybody know if that is for security purpose or frame damage purpose?
  4. Mar 12, 2011 at 1:08 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    In reading these forums I have seen several threads where people have ripped them off using them for recovery.
    I'd use the passenger side.
  5. Mar 12, 2011 at 1:09 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I doubt it would cause frame damage, but there is a danger of that loop breaking, since it isn't made for recovery.
    If you want a reliable front recovery point there is a thread somewhere on here to buy a really beefy one, but I cannot find it.. :(
  6. Mar 12, 2011 at 2:27 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    The OR has a recovery hook on the front passenger side. It is heavily built and securely bolted to the frame. The one suggested by StandingCow is one that a forum member built for the Sport. As has been suggested elsewhere, if you're going to pull another vehicle which is stuck, you're better off pulling in a forward direction, not in reverse. If you don't already have one, get a shackle mount for the rear hitch.
  7. Mar 12, 2011 at 4:56 PM
    supralight
    Dan
    Earth
    Excellent advice about the rear mount, I'll pass by my local trailer retailer a d get one of those.
  8. Mar 12, 2011 at 5:26 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
  9. Mar 12, 2011 at 5:34 PM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
  10. Mar 13, 2011 at 1:10 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    You can get the OR tow hook. If you look um my name and tow hook or recovery or something, you'll find the part number.
    Nothin like OEM.
