TRD OR Locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SeanDub, Aug 3, 2017.
  1. Aug 3, 2017 at 10:56 AM
    SeanDub
    SeanDub [OP] Well-Known Member
    Sean
    Morgan Hill, CA
    2017 TRD Off-Road
    Icon Stage 4
    Has anyone published what it would take to allow us to lock up in 2 wheel or 4hi?
    I tried searching but didn't turn any results.
  2. Aug 3, 2017 at 10:57 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Air lockers probably tbh
  3. Aug 3, 2017 at 11:11 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I don't think anyone has successfully "hacked" the 3rd gen yet to run it in 2wd or 4hi.
    SeanDub[QUOTED][OP] likes this.
  4. Aug 3, 2017 at 11:24 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I'm waiting too.
    Matter of time hopefully by someone smarter than me.
  5. Aug 3, 2017 at 1:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Someone previously mentioned that it could be done with a software hack. Smart guys??? Where are you????
  6. Aug 3, 2017 at 1:53 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    It's an e-locker...unless there is more than "on/off" functionality built into the actual locker - i.e. a microcontroller of some sort, then you should technically just have to supply the proper voltages over the wires....should be easy. You would just be bypassing everything else and would probably not get the indicator light, etc. And then if the truck doesn't know it's on, traction control could go haywire and screw something up I suppose.
  7. Aug 3, 2017 at 2:02 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'm more so curious for a hack on the MTS. so I can use that in 4hi.
    The snow/mud setting would be great for the winter driving here. 4hi was fine last winter and probably will do fine, but still would be cool to use mts in 4hi as well.
    Even on trails I don't alwas need 4lo.
    SeanDub[OP] likes this.
