TRD OR MT vs TRD SPORT MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cin_Lowap, Oct 27, 2020.
  1. Oct 28, 2020 at 10:01 AM
    timred93
    timred93 Never too old to Tacoma
    Tim
    NW AR
    2013 Spruce Mica TRD Sport
    Predator Tube Steps, Fuel Hardline Wheels, 265/70 R 17 Nitto Ridge Grapplers, 2 inch Rough Country Leveling Struts, Undercover Armour Flex Hard Folding Tonneau Cover, Pop and Lock Tailgate Latch With Key Lock.
    Sport for the win!
    CygnusX191 and Junkhead like this.
  2. Oct 28, 2020 at 10:10 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That..... I have no idea.
  3. Oct 28, 2020 at 10:21 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Both the Sport and Off Road have Brake Boosters but the OR has the Electric Booster while the Sport has the traditional style vacuum booster. You would be correct that the Sport has the hill start assist to hold the truck and the OR does not.
    CygnusX191 and daveeasa[QUOTED] like this.
  4. Oct 28, 2020 at 10:24 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Thanks for that clarification :cheers:
  5. Oct 28, 2020 at 10:35 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    You guys are making me want to go test drive an OR with all this talk about how stiff the Sport suspension is. I've had a 2016 Sport and now a 2020 Sport and cannot stand how soft the suspension is. Nosedives like hell when you accelerate and brake. Its so annoying especially with an MT and shifting while being bounced around. I am planning of an AAL and 5100's to stiffen up the ride!
  6. Oct 28, 2020 at 10:37 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Keep in mind the electronic locking diff on the OR is only able to be engaged in 4LO and not 4HI. This is one reason I did not see the benefit in buying an OR compared to my Sport.
  7. Oct 28, 2020 at 10:46 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Well they are both trucks, but the sport is tighter and stiffer and the OR (which I have) could be described as more "floaty". I don't think 5100s will stiffen it more than a sport but you will likely see some improvement overall in dampening bumps. I have Sumo springs in the back to prevent sage from my ARE topper and permanent gear in the bed from some tools etc. That stiffens my back end and reduces body roll in turns but the front is soft. I don't brake hard so I don't notice dive much in the front.
  8. Oct 28, 2020 at 10:55 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    You will be totally fine with the Sport, I’d go 2017 low miles vs 2016.
    CygnusX191 likes this.
  9. Oct 28, 2020 at 10:55 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    There are two types of Tacoma “packages”:
    1) ones with lockers
    2) ones without
  10. Oct 28, 2020 at 11:14 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    COVID has caused a
    I would be also using the 5100 to lift the truck so should end up at least stiffer than OE. I have a manual transmission so downshifting is usually where I see the most nosediving.
  11. Oct 28, 2020 at 11:14 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Weird, mine wasn't soft at all. Currently have the bilstien 4600 from an OR on my fronts and it still doesn't feel soft but it's ever so slightly better at low speeds off-roading.
  12. Oct 28, 2020 at 1:24 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Neither ...try to get dealer to get a new 20 in a manual from another dealer . they can do a dealer swap and you don’t have to buy used .
    shakerhood and CygnusX191 like this.
  13. Oct 28, 2020 at 2:23 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I think the Sport is a better deal based on the kms. I like the tires on the Off Road, but the manual will work the same in both. I have a 17 Sport with a 3" lift and 265/70-17 Duratrac tires on rims, and it does everything I need it to do no problem. Measure your ATV to see it it'll fit, my old 2009 LT-Z400 (fairly wide, maybe not as wide as your ATV) fit in my 2007 Sport, and it should fit the same in the 17.
  14. Oct 28, 2020 at 2:33 PM
    jetspeed
    jetspeed Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    -SOUNDS- to me like the SPORT for what you would use it for everyday.
  15. Oct 28, 2020 at 3:10 PM
    #35
    shakerhood
    Southern Ohio
    The Off Road MT will have the A-TRAC System in place of Crawl Control and a Sunglass compartment overhead.
  16. Oct 28, 2020 at 3:21 PM
    #36
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sunglasses?
    I was storing Tacos up there....
    shakerhood[QUOTED] likes this.
