TRD Power Inverter
Discussion in 'Technical Chat' started by HighPlains, Dec 26, 2008.
  1. Dec 26, 2008 at 8:48 AM
    HighPlains
    HighPlains [OP] Well-Known Member
    Has anyone else with the TRD package that includes the in bed power inverter found it to be totally useless? 100w-400w?! I guess you could run a charger from it but not much else in my estimation.
    So here is the question: Has anyone attempted to replace the stock one with a larger wattage unit? A search of the threads revealed that the stock unit is underneath the center console. Would the wiring and related hardware require upgrading?
  2. Dec 26, 2008 at 8:59 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It really depends on how big you want to go. You could probably upgrade to a 600 Watt inverter and you wouldn't have any issues with wiring in between the outlet and the inverter, but I would want to run a fresh power going directly from the battery and install a relay going to a dash switch. I think that there was a 600(it might have been 800) watt coleman that would fit in the OEM location.
  3. Dec 26, 2008 at 9:32 AM
    HighPlains
    Are you suggesting the existing wiring and switches/relays are not spec'ed high enough for the larger wattage inverter? I have the worthless stock one now. I have somewhere if I can find it, a 750w Black and Decker inverter. When I first saw the inverter on the TRD trucks, I thought "how innovative is that?". I thought up at least 100 uses. Only later did it occur to me that 400w is only good enough to run very few of the things I dreamed up.
    Thanks.
  4. Dec 26, 2008 at 9:46 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    One of my concerns is the way they switch between 100/400 Watts and Off.
    You also need to realize that the 400W inverter requires roughyl 33 Amps, and the 750W inverter could require as much as 62.5 Amps. Those wires are probably going to need to be about 12 (OEM) and 8 gauge, respectively.
    Stan_Twizzly and JAL4 like this.
  5. Dec 26, 2008 at 10:02 AM
    Ahaszard
    Ahaszard Active Member
    St Augustine, FL
    08 Black TRD Off Road Rugged Trail
    I use my inverter all the time. I use it for my ARB Fridge/Freezer and it works great!
  6. Dec 26, 2008 at 10:40 AM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    Nice
    Ive only needed to use mine for charging batteries
  7. Dec 26, 2008 at 10:58 AM
    sonjay
    sonjay Well-Known Member
    I got one for christmas to run my vaporizer when I'm camping
  8. Dec 26, 2008 at 11:04 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    :confused: I got one too, but I'm planning on running my foot massager and makeup mirror.
  9. Dec 26, 2008 at 12:38 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    So you do a lot of voguing on the trail?
  10. Dec 26, 2008 at 12:42 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'll come up with a response when you come up with a doggy zoolander. :D
  11. Dec 26, 2008 at 1:26 PM
    Evil Monkey
    Robert
    Escondido, CA
  12. Dec 26, 2008 at 1:41 PM
    famousfernando
    famousfernando Well-Known Member
    oregon
    2007 tacoma trd package 6" fabtech l
    so how does the inverter work i never used it do you have to have the truck running or do you just have to have the key turned on?:confused:
  13. Dec 26, 2008 at 1:57 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    those were the days...they used to give out blow for free.
    pepperhead71 likes this.
  14. Dec 26, 2008 at 4:19 PM
    HighPlains
    Yeah, I did not think about the system switching between 100w to 400w and how all that works. I just wish they had made the capacity a little higher. I don't really have anything in particular in mind. I just want to know that if I want to charge my proton pack away from home, I can do it.
    Thanks for the input.
  15. Dec 26, 2008 at 4:43 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Another wonderful thing... Last year I found out the hard way when on a project out of town, that 12v DC to 120v AC inverters will create reproduced sin wave issues. This will prohibit you from using certain chargers and other sensitive devices from the inverted power source. Doubt this would be of issue for most applications, but it sure did screw my work schedule that weekend.
    stvhwrd likes this.
  16. Mar 27, 2009 at 10:30 PM
    LEDtoma
    LEDtoma Keep 'em smiling
    Stanfield NC
    05 TRD Sport Pre-runner
    Bed Lights w/Cab & bed switch Inverter in Cab : dual plug, continuous 12V socket & USB power port Anytime driving/fog light OEM DRL install w/on-off Parking light Mod Borla cat-back Fresh air cab filter Engine compartment light Hbeam enable Garage door opener
    I also found that the 400w output (in park) was too low. I go camping alot and needed more power so I installed an 800W Inverter and mounted under the drivers seat. I then extended all wiring to the rear of the center counsel and re-mounted the switch, LEDs and plug. The inverter I choose had a USB output that I also extended to the counsel strictly for the kids to charge their toys. I have since installed a 12V power outlet wired/fused directly to the battery for continuous power.
    Although I take credit for my labor I can't take credit for the know how.
    Please see link below for some awesome ideas/mods.
    http://www.cardomain.com/ride/832238
    Meet Kramer. He loves to ride and I think he loves my truck more than I do...
    Scubasteve.tn likes this.
  17. Sep 16, 2014 at 8:43 AM
    AnewKINDofFEELIN
    AnewKINDofFEELIN Active Member
    Billy
    Baton Rouge, LA
    2013 Double Cab SR5 4x4
    Does anyone know if non-TRD models are pre-wired for an inverter? I'm considering adding one for camping and tailgating, but I''m trying to get an idea of what's there before I go reinventing the wheel.
    2013 TSS. Speaking of which, I need to find a good way to remove those decals.
  18. Oct 9, 2015 at 2:23 PM
    TacoTodd78
    TacoTodd78 Well-Known Member
    Todd
    Arkansas
    2014 PreRunner TSS
    Windows tented. Badges, Bumper and Wheels Plastic dipped. 3" Lift-Level ProComp ProRunner Baja Rack ARB 2500 Awning.
    anybody?
  19. Dec 19, 2016 at 8:42 AM
    ColoradoPacific
    ColoradoPacific Custom Title
    Centennial State
    Silver TuRD
    ***COMPLETED MODS*** SUSPENSION -Total Chaos UCAs -King 2.0" RR Coilovers w/650# springs -OME Dakar leaf pack -King 2.0" RR shocks -Archive Garage Shackle Flip -Front Range Off Road U-Bolt Flip Kit DRIVETRAIN -URD Short Shifter ARMOR -Pelfreybilt Front Bumper, Steel -Pelfreybilt Full Skid Set, Aluminum -Adventure Off Road High Clearance Rear Bumper -Front Range Off Road E-Locker Skid LIGHTING -Rigid Dually Fog Lights -Rigid 40" SR-2 -Rigid SRQ Backup Lights -AntiDark Underhood LED Strip ACCESSORIES -Safari snorkel -SLEE dual battery tray w/ 2x Interstate MT7-75DT -BajaRack -Custom Bed Rack (Adventure Off Road) -Rubber bed mat (Toyota) -Fender flare delete -Center console 120V outlet -Center Console Vault (TruckVault) -CB Radio -Ham Radio -YETI Bottle Opener -WaterPort shower system -MaxTrax -Hi Lift ***FUTURE MODS*** Re-gear to 4.56 Nitto Ridge Grappler 35s Magnusson Supercharger VIAIR onboard air system 20 gal aux fuel tank
    My guess would be that yes, they are wired for it. Most manufactures use a common wiring harness for all trim levels, and just add the necessary connections for the features that are purchased. It's much cheaper than having different wiring harnesses for each possible option. You would probably need to buy the connectors, and possibly wire up the requisite fuses, but the harness *should* be there for you.
