TRD Pro 16” rim tpms question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kytacotrd, Feb 12, 2021.
  1. Feb 12, 2021 at 8:38 AM
    Kytacotrd
    Kytacotrd [OP] Well-Known Member
    2003 Tacoma TRD xtra cab
    Thanks in advance for any information. I have a 2019 sr and recently bought 16” trd pro rims. I think I need new tpms sensors, because I currently have steel wheels. Does anyone have experience with this change and know what sensor I need. thanks
  2. Feb 12, 2021 at 9:13 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Yes, you will need different TPMS sensors. Can't tell to the P/N, but I do know that the angle of the sensor is different.
  3. Feb 12, 2021 at 10:23 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Clone your steel wheel OEM sensor IDs to new aluminum wheel Autel or other brand sensors and off you go.
    Hooper89 likes this.
  4. Feb 13, 2021 at 10:31 AM
    Kytacotrd
    Thanks everyone. I appreciate the responses. The more I think about it, the more I think I’m just gonna say forget the sensors and deal with the light. Other than the light, I’m good without them. I might make one of those pvc containers. Thanks again.
  5. Feb 13, 2021 at 10:43 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I’d pay the 100-200 for new sensors because I’d feel stupid putting black electrical tape over a warning light on a new truck. In my old shitbox I didn’t care though.
  6. Feb 13, 2021 at 12:36 PM
    406Tacoma
    406Tacoma New Member
    Larry
    2021 TRD Offroad 4x4
    Following. I have a 21TRD OR that I will be putting new wheels with snow tires on next winter. These stock Goodyear Wranglers suck in snowy highway driving.
  7. Feb 13, 2021 at 12:54 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I hope you got the whole wheel and not just the rim. :thumbsup::thumbsup:
    The angle of the sensor is different for aluminum vs steel which is why you need new ones. Your steel wheels use 20 degree sensor vs 40 degree for aluminum. Technically they would work, but you risk snapping it off when the tire is being installed or removed. If you are buying 4, aftermarket is the way to go. You can get a set of 4 off Amazon for $50 or so.
  8. Feb 13, 2021 at 1:00 PM
    Kytacotrd
    Yeah unfortunately I just got rims, lug nuts and junk tires. Previous owner kept the sensors for his new set up. I have looked. Which brand you recommend, part number would be awesome if you happen to know.
  9. Feb 13, 2021 at 1:13 PM
    Sungod
    St Augustine
    Rim is part of the wheel. Think about a bicycle. You have the rim which is the outer part, then you have spokes, and a hub. Same thing for vehicles except we usually don't have spokes. Flatbillers are mostly responsible for the slang calling them rims. Sorry, just a pet peeve of mine.
    In any case I got these about a year ago, but the price has gone up - Amazon.com: BOXI Qty(4) Tire Pressure Sensor TPMS for Lexus Gx460 16-17/Lexus Rx350 15-18/Lexus Rx450h 15-18/Toyota Avalon 16-18/Toyota Camry 15-18/Toyota Tacoma 16-17 4260748010 PMV-C015 (Pack of 4): Automotive I paid $62 for them. These should work Amazon.com: AUTOKAY Set of 4PCS TPMS Tire Pressure Sensor for Toyota Camry Tacoma Avalon Electric Gas: Automotive I would be a touch nervous about going with ones with no ratings. I'm sure they will work, and Amazon has a great return policy, but it is a major hassle. Whatever ones you get, take them to a tire shop and have them programmed BEFORE they mount them. They will bitch and complain telling you it isn't necessary, but if they don't work it is better to know before they install them and put them on your truck.
  10. Feb 13, 2021 at 2:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I already stated which brand.
    But you need to go to your local tire shop and ask them what aftermarket TPMS sensors they setup and use. Bringing any sensor to them isn't going to work.
    You need to have a tool that reads the OEM sensors, can copies their OEM ID numbers, then clones the aftermarket sensors with the OEM IDs to the aftermarket sensors. Then take your Pro wheels off the truck, roll them out of the way, install your winter set, read and follow your owner's manual on how to reset the TPMS sensor readings, and drive.
  11. Feb 13, 2021 at 4:57 PM
    Kytacotrd
    Great info. I really appreciate all the help. Thanks
  12. Feb 15, 2021 at 5:51 AM
    Sungod
    St Augustine
    I'm no fan of multipurpose sensors. I would stick with sensors that are designed to mimic OEM. You can program the codes from the sensors into the TPMS ECU either via the handheld device or techstream. The reason I don't like the universal sensors is that they don't always fit the wheels properly. Not to mention that with the programable sensors, they can lose their programing. I would use them if I had a second set wheels that I used occasionally such as winter tires. That way you don't have to reprogram the ecu when you swap them.
