TRD Pro 17” wheels with Wildpeaks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mntaco21, Jul 14, 2021.
  1. Jul 14, 2021 at 7:28 PM
    mntaco21
    mntaco21 [OP] New Member
    2019 Tacoma Off Road
    Hi, I just recently installed 17” TRD Pro Wheels and 265/70r17 Wildpeak tires on my 2019 Tacoma Off Road. They look great, but there is some rubbing. I have spent a lot of time researching and thought I would be able to install these without any issues. I am looking for any options to prevent this. I would like to avoid cutting or trimming anything if I could. Perhaps a spacer? Leveling kit? Thanks!
    Mattman72 likes this.
  2. Jul 14, 2021 at 8:27 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Do you have mud flaps?
    If so remove them, they can rub. I ran this setup for 50K miles and had no issues other than the flaps. Others run it here and have no rub period. You should not have to lift or chop anything (other than flaps of course) to run this setup.
    Here was my truck non lifted with the exact same wheel/tire setup as you describe.
  3. Jul 15, 2021 at 2:42 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Get an alignment, I run 265/70/17s on 4Runner Pro wheels and no issues rubbing anywhere. Tried my friends 4Runner Pro wheels and 285s and again no issue. I'm lifted 2 inches in the front but lift makes no difference. I have the OEM mud guards too.
