TRD pro fox springs
Discussion in 'Suspension' started by notbryon, Mar 5, 2022.
  1. Mar 5, 2022 at 1:42 PM
    notbryon
    notbryon [OP] Well-Known Member
    Bryon
    Steelton, PA 17113
    2017 TRD Sport AC
  2. Mar 16, 2022 at 12:50 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Might just be the picture but that coil spring looks messed up. In any case, what do expect to gain by installing those without the trd pro shocks?
  3. Mar 16, 2022 at 12:54 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    That's because it's two coils in a single box. And no they won't fit the sport suspension. The inside diameter of those springs is ~2.5"
    JFriday1 likes this.
  4. Mar 16, 2022 at 12:56 PM
    gudujarlson
    Minnesota
    Ah ha! Thank you. Lol
  5. Mar 16, 2022 at 1:00 PM
    gudujarlson
    Minnesota
    Are you saying the sport shocks won’t fit inside a 2.5” inner diameter coil spring? That doesn’t seem right to me.
  6. Mar 16, 2022 at 1:06 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Yes that's what I'm saying. The Pro coilovers have a 2.5" shock body. The sport and OR coilovers have smaller shock bodies.
    edit: actually yeah they'll fit inside the 2.5" ID spring. all the way inside and will pass right over the spring seat
  7. Mar 16, 2022 at 1:07 PM
    gudujarlson
    Minnesota
    Ok, so the smaller diameter shock should fit easily. Yes?
    Or is it the points that the coil attaches to the shock that is the problem?
  8. Mar 16, 2022 at 1:08 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    At this point I'm pretty sure you're just trolling me. I'm trying to keep OP from buying springs he can't use. Do whatever you want bro
  9. Mar 16, 2022 at 1:09 PM
    gudujarlson
    Minnesota
    Im not trolling you. Im honestly trying to understand what you are saying.
  10. Mar 16, 2022 at 1:10 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    the inside diameter of the spring needs to be approximately the same as the outside diameter of the shock body. putting a 2.5" ID spring on a 2" OD shock body will not work.
  11. Mar 16, 2022 at 1:12 PM
    gudujarlson
    Minnesota
    You aren’t explaining why, but I’m guessing the issue is the connection points (top hat and whatever the bottom point is called) of the smaller diameter shock are not big enough for the larger diameter coil spring, thus the shock would be unable to compress the spring.
  12. Mar 16, 2022 at 1:16 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Go outside and look at your coilovers. Now imagine that those springs' inside diameter was larger by .5". How well would they fit?
  13. Mar 16, 2022 at 1:21 PM
    gudujarlson
    Minnesota
    Sorry I’m just not following you. An extra 0.5” of inner diameter would give the coil springs 0.5” more clearance with the shock body. What’s wrong with extra shock body clearance? Some how we are not communicating
  14. Mar 16, 2022 at 1:24 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I truly don't know how else to put this. A shock body with a 2" OD requires a spring with ~2" ID. They are expressly designed to work together. A spring too large will not seat properly, and may pass over the spring seat entirely depending on size and design
    gudujarlson[QUOTED] likes this.
  15. Mar 16, 2022 at 1:28 PM
    gudujarlson
    Minnesota
    Yes that’s what I was saying above about the connection points. The shock body diameter is not important unless it is larger than the inner diameter of the coil spring.
    In any case, I think we are both telling the OP that this a misguided adventure.
  16. Mar 16, 2022 at 1:30 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    most of the 2.0 springs don’t/won’t have a spring seat that was designed for a 2.5” ID spring.
  17. Mar 16, 2022 at 1:31 PM
    gudujarlson
    Minnesota
    Yes that’s what I meant about the connection points. Spring seat is possibly a better term.
    hyrule_trd[QUOTED] likes this.
  18. Mar 16, 2022 at 1:33 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I think you're discounting how precise these things need to be. For instance the 2016-19 Pro springs won't work on the 2020+ Pro model shocks due to a difference in spring seat design even though they are identical in shock body size and manufacturer.
  19. Mar 16, 2022 at 1:34 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    That makes sense. All just trying to help!
  20. Mar 16, 2022 at 1:35 PM
    gudujarlson
    Minnesota
    Yes I was discounting that. I’m asking questions to educate myself and also to clarify/elaborate what you are saying for the wider audience.
