TRD Pro front broken coil spring
Discussion in 'Suspension' started by rattlesnakelorax, Nov 6, 2022.
  1. Nov 6, 2022 at 8:36 AM
    rattlesnakelorax
    rattlesnakelorax [OP] Member
    Brian
    2017 Tacoma TRD Pro
    none
    I have a 2017 Tacoma TRD Pro with less than 25K miles and my right front coil spring broke and I found the broken section on the floor of my garage after returning from a drive all on interstate and highway. It has never been offroad and only driven on paved roads. Does anyone have experience with this issue and what they did about it? Will Toyota cover the repair? I should replace both front coil springs probably as the other one may fail at any time?
  2. Nov 6, 2022 at 8:48 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    :worthless:
    DRob likes this.
  3. Nov 6, 2022 at 8:49 AM
    eurowner
    eurowner Duke Sky
    Scoty
  4. Nov 6, 2022 at 8:49 AM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Nov 6, 2022 at 8:56 AM
    Xero
    Mark77, cryptolime and DRob like this.
  6. Nov 6, 2022 at 9:02 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I guess Eibach makes the springs on the TRD foxes. Eibach aftermarket springs seem to break for what ever reason. The springs don't seem to hold up as well to the elements as OEM toyota springs, or most likely other OEM springs that have a more robust coating. Eibach springs are probably a softer compound than OEM springs, since they are a performance spring.
    Eibach might make Toyota's springs for all I know.
    I know the Pro is marketed and sold as an out of the box performance model of the Tacoma. I would not expect the shocks and springs to last as long as what the SR is equipped with. TRD Bilsteins seem to have a greater failure rate over the Hitachis. Never seen a picture of a blown Hitachi shock.
    The Pro offers more performance, and requires more maintenance.
    MGMDesertTaco likes this.
  7. Nov 6, 2022 at 11:27 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I bet his looks just like the others. :pccoffee:
  8. Nov 6, 2022 at 12:10 PM
    Xero
    Probably but that’s still an assumption.
  9. Nov 8, 2022 at 2:57 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Toyota won't do anything about it as you are long out of warranty.
  10. Nov 8, 2022 at 3:02 PM
    MGMDesertTaco
    SR-71A likes this.
  11. Nov 8, 2022 at 3:26 PM
    rattlesnakelorax
    Brian
    2017 Tacoma TRD Pro
    none
    Eibach told me they do not offer replacement springs only lift springds.
  12. Nov 8, 2022 at 3:29 PM
    rattlesnakelorax
    Brian
    2017 Tacoma TRD Pro
    none
    Working with a Toyota dealer to see if Toyota will cover it. Even though my vehicle is out of warranty it should not break a coil spring at less than 25000 miles.
  13. Nov 14, 2022 at 8:32 AM
    rattlesnakelorax
    Brian
    2017 Tacoma TRD Pro
    none
    Surprise Surprise. Toyota is covering my broken coil spring both part and labor.
    Gearheadesw, Mark77, Xero and 2 others like this.
  14. Nov 14, 2022 at 8:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  15. Nov 21, 2022 at 7:41 PM
    rattlesnakelorax
    Brian
    2017 Tacoma TRD Pro
    none
    Now I found that the other front coil spring is broken and waiting for response from Toyota. I will never again buy any Toyota with the Fox suspension. I never took my Tacoma offroad and not even on gravel roads and both front coil springs broke at less than 25k miles. This certainly needs to be a recall situation as I have found other owners who have had the same problem with TRDPro Tacomas and 4runners.
    kate-n likes this.
  16. Nov 21, 2022 at 7:45 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i wonder if Hitachi makes springs
  17. Nov 22, 2022 at 4:40 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    My 4-runner broke both springs. As you now know, it’s quite common. The spring design and lower perch on the Fox shocks (and the older Bilstein replacements) was changed to a pigtail design and that should alleviate the issue.
  18. Nov 22, 2022 at 5:09 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Well, good to hear you have resolution. I was gonna offer up my pro springs off my 2020 since I changed them out for toytec.
  19. Nov 22, 2022 at 9:20 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    We are still waiting for pics.
    eurowner likes this.
  20. Nov 22, 2022 at 7:49 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Wait a second..........
    Now take your OEM FOX Tacoma Pro front and rear suspension off, replace them with a brand of your choice, and sell the Fox; done.
    That's not how a recall works.
