TRD Pro Grill and TSS Relocation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tjb1, Aug 18, 2021.
  1. Aug 18, 2021 at 7:12 AM
    tjb1
    tjb1 [OP] Well-Known Member
    2021 Tacoma TRD Sport
  2. Aug 18, 2021 at 8:53 AM
    WRREGL
    WRREGL Well-Known Member
    North Alabama
    2018 TRD sport
    Work in progress
    Have zero issues with my after market garnish just FYI. Lots of them around. And the issues that I’ve read were easy fixes.
  3. Aug 18, 2021 at 9:08 AM
    tjb1
    Where did you get your grill and garnish?
  4. Aug 18, 2021 at 9:22 AM
    WRREGL
    North Alabama
    2018 TRD sport
    Work in progress
    Ebay. Just looked for one that wasn’t coming all the way across the ocean. No issues and I’ve compared it to others and you can’t tell the difference. I put it off for awhile but I’m pleased with it
  5. Aug 18, 2021 at 10:08 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I wouldnt buy that before trying out the aftermarket garnish first. I have aftermarket and it works just fine.
  6. Aug 18, 2021 at 12:21 PM
    tjb1
    It's not so much it working that I'm concerned about. I've seen some pictures of the one from Taco Garage and it wasn't even close to matching the grill.
  7. Aug 18, 2021 at 12:22 PM
    WRREGL
    North Alabama
    2018 TRD sport
    Work in progress
    None of them look good as far as matching goes.
  8. Aug 18, 2021 at 12:23 PM
    5nahalf
    Erik
    Minnesota
    None of them match the grill. Even the oem one doesnt match.
    The garnish is gloss black with silver lines printed on it, the grill is flat black
  9. Aug 18, 2021 at 12:25 PM
    tclavell
    Troy
    Phoenix, AZ
    G70
    don't use the garnish if you don't want to. If you live in an area with good weather and debris free roads, you may be ok without it. However, as mentioned, even if you go OEM garnish and grille, they won't match.
  10. Aug 18, 2021 at 12:29 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Embrace the garnish!
    Heynongman likes this.
  11. Aug 18, 2021 at 12:59 PM
    WRREGL
    North Alabama
    2018 TRD sport
    Work in progress
    I’ve often wonder if a clear piece of plexiglass on the inside of the grill over the sensor would work.
  12. Aug 19, 2021 at 12:40 AM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    you can vinyl cover the garnish without it affecting the sensor. Xpel Stealth film is satin/matte and will cut down on the silver while still maintaining the design, or you could just flat black the whole thing.
  13. Aug 19, 2021 at 1:25 AM
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    I switched to an aftermarket pro grill and aftermarket garnish, zero issues. Then lifted it 1.5”/1” and added wheels/taller tires, zero issues.
    Also, I tinted the garnish. Easy to do and helped it be a lot less noticeable.
    My4thTacoma likes this.
  14. Aug 19, 2021 at 1:36 AM
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    If you're worried about the garnish not matching, check out c_mento_taco_808 on Instagram. He does some pretty cool custom vinyl pieces for both the pro garnish and the toyota emblem cover.
  15. Aug 19, 2021 at 1:50 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    You can get an OEM grill under $200 if you use the part # for the pro grille that comes with the TRD lift kit. Still need the garnish.. I found out about this after I had installed my grill from Tacovinyl with no issues with TSS.
    https://www.sparksparts.com/oem-parts/toyota-trd-pro-grille-insert-tacoma-pt22835200aa
    Note: It does ask for a PRO VIN for the order form. Just find one online, they are everywhere.
    This dealer site doesn’t seem to need a vin. Both places are legit Toyota, Ive ordered many parts from both.
    https://parts.passporttoyota.com/p/...Inner-Front-Grille/97495920/PT2283520020.html
  16. Dec 7, 2021 at 4:24 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    This is very helpful...I'm still waiting for ship status for my order from Empyre. It's been 8 days ago today since I ordered.
    Ed
