TRD Pro Grill Garnish Installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mikeaesq, May 8, 2019.
  1. May 8, 2019 at 6:20 PM
    mikeaesq
    mikeaesq [OP] Well-Known Member
    TRD Off-road 4x4
  2. May 8, 2019 at 6:46 PM
    PizzaTaco4x4
    PizzaTaco4x4 Well-Known Member
    Very hard to do by hand, buy some rubber washers and it hold it in place. Can't remember the size though. I did this trial and error.
  3. May 8, 2019 at 6:57 PM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Push in as far as it will go then use a needle nose plier to push it flush to the grill. Check around the garnish and grill to make sure it's all even all around.
    It should sit flush evenly.
    If you want to go a step further and not get error from snow or rain, you can use a thin strip of foam around the garnish to keep moisture from seeping into the sensor. I've yet to get ANY error from heavy downpours.
    You can't see the foam unless you look for it. I'm a bit OCD so it has to look clean.
  4. May 8, 2019 at 9:13 PM
    azerathis
    azerathis Well-Known Member
    Tacoma 2019 Offroad 4x4 dcsb quicksand
    ARE hd shell
    The lock washers are pretty easy to install if you hold the garnish and use a small socket to push the washer onfrom the other side. As far as errors the dealership tss repair looks like a huge flap of rubber/foam that just hangs over the sensor on the back
  5. May 8, 2019 at 9:26 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    For as much as they charge for the garnish they don't come with the necessary hardware to install it??? :eek:
  6. May 8, 2019 at 9:36 PM
    azerathis
    ARE hd shell
    The washers were like ¢10 each but yeah they should've come with the garnish
    KY_Rob likes this.
  7. May 8, 2019 at 9:47 PM
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    I bought my pro with 12 miles on it and it didn't have those washers installed on the garnish. I questioned why it was loose before I signed and they told me it was normal. I laughed and said I'd fix it myself. A quick search here showed how and I took it back and had them do it. That was a mistake. I asked the service mgr. to make it so it was flush with the rest of the grille and he gives it back to me all angled to the sky.
    KY_Rob likes this.
  8. May 8, 2019 at 11:30 PM
    Kauai_Tacoma
    Kauai_Tacoma Well-Known Member
    2016 Tacoma sport
  9. May 9, 2019 at 6:08 AM
    mikeaesq
    TRD Off-road 4x4
    Appreciate the help guys. The responsiveness and altruism here is unparalleled.
    shotgunbilly420 likes this.
  10. May 27, 2019 at 1:06 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I’ve got an OEM Pro Grille waiting to be installed. It’s the 2016-2017 version, but has the TSS sensor opening. When I install the separate garnish, it also looks angled to the sky when pushed in all the way. If I “make it flush”, there’s barely any washer stud poking through the holes at the top. Not sure what to do about this yet.
  11. May 27, 2019 at 1:08 PM
    KY_Rob
    Rob
    North East Ohio
    Where can I find these washers for a dime? Amazon has OEM washers for $4.00 EACH!
  12. May 27, 2019 at 1:17 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Use a longer 7mm socket push them on, deeper is better, shallow and it won't go down all the way. I think that's what it was. With the washer having the tabs pointing up, I'd point them towards the front/garnish. I did mine with the tabs pointing towards the engine and mine is loose and rattles around. I'm going to pull it off and try to flip them. Some have said that's how their's was and some of the PRO's on dealer lots were. I think it just depends on who assembled it.
  13. May 27, 2019 at 1:19 PM
    bonifacio
    Central PA
    Nope. They assume it's a replacement part, so you'd just reuse the old ones or whoever replacing them (shop) would have them on hand. Probably save money and make more money in the long run.
  14. May 27, 2019 at 1:28 PM
    KY_Rob
    Rob
    North East Ohio
    For the thread and answering my own question, these washers are M6 internal star lock push on washers. Should be available at just about any hardware I would think.
    The plastic “studs” at the top of the inside garnish are just under a 1/4” diameter. Should be able to use 1/2”x1/4” rubber washers if desired.
    I’m thinking my garnish is going to end up being custom fit with all of the above, plus a little epoxy to keep things from rattling around. No way do I want it not sitting flush with the outside of the grille. Damned thing looks bad enough as it is.
  15. May 27, 2019 at 1:32 PM
    bonifacio
    Central PA
    I think a thin rubber washer and star washer would be perfect. I wouldn't use epoxy just to in case.
    KY_Rob[QUOTED] likes this.
  16. May 27, 2019 at 1:42 PM
    KY_Rob
    Rob
    North East Ohio
    Yeah, you’re probably right on the epoxy. I just hope there’s enough garnish stud for washer to grab and keep things flush on the outside.
  17. May 27, 2019 at 2:37 PM
    hazey
    hazey Active Member
    2019 DCOR MGM
    Do you really need to order the washers? I just used the silver washers from my off road and it fit great.
  18. May 27, 2019 at 2:50 PM
    bonifacio
    Central PA
    There's definitely enough. If the socket is too shallow, the nub won't go far enough into the socket to seat the star washer.
  19. Dec 26, 2020 at 4:38 PM
    Darthkevyn
    Darthkevyn Well-Known Member
    Kevin
    Washington State
    2020 Cement TRD Off Road
    HAM radio installed, Kenwood head unit installed, tinted windows, TRD pro tail lights, MESO laser etched (topo) blacked out emblems and steering wheel cover, MESO dome and map lights, 3rd bed rail installed, MESO skip button installed, Puddle lights, bed lights, MESO over head rack, Kicker speakers, JL Audio stealth Box subwoofer, Alpine amp, 3TPAM installed.
    Do you have any pictures of how you did the foam? I live in washington state and want to limit the amount of moisture so hopefully I won't have to replace a sensor or something
  20. Dec 26, 2020 at 4:49 PM
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    Like this:
    UXiji1q-LRMZcVhjpWUEXV9hz9xF16w0P6B48Fcr_af4c61be8945ec6fd4099e5fbaa99639f612fada.jpg
    Use the 1/4" extension (open end) to get them started. Just until the teeth get around the little post.
    Finished them all the way with the 10mm.
    Put a block of wood (I covered it with vinyl for a little extra protection) under the garnish, the rappy-tap the tool (extension/socket) with a hammer.
    Medium, quick, firm hits should work.
    Darthkevyn likes this.
