trd pro grill questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinktaco808, Sep 16, 2021.
  1. Sep 16, 2021 at 7:15 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    soo does it matter which tss i buy on ebay? also is it the same thing for the cruise control? also how do i know if the tss is calibrated?
    will trd pro grill with the tss work with my sr tacoma access cab 2021???
  2. Sep 16, 2021 at 7:20 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    The tss on the pro grill is lower and angled different. The sr grill is higher and angled lower I believe. You might have to do the spacer fix so the radar isn’t giving you a warning all the time.
    pinktaco808[OP] likes this.
  3. Sep 16, 2021 at 7:29 PM
    pinktaco808
    this?? put washer on the top bolt of the tss?? has anyone else done this swap for the access cab??
  4. Sep 16, 2021 at 7:33 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    You don’t really know until you try it. I had no issues on my dclb, but others have needed the washers. It’s an easy fix if you have issues. As far as the quality of the grill/garnish, I’m not sure what’s out there these days
  5. Sep 16, 2021 at 9:50 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I don’t think you need to do anything if you do the install carefully. I changed out mine at 600 miles or so with a pro copy from the Taco Garage IIRC. Pulled the grill shell, then pulled the grill out of it, carefully put in the Pro grill and sensor, put the sensor cover on and used a deep socket to push the speed nuts down tight. It works fine. At 11,xxx miles, I have had no problems rain, snow, or shine. I use the adaptive cruise all the time and it works perfectly.
    I think people run into trouble when they try to compensate for the difference in some way. I also think some of the issues stem from not putting the sensor cover on tight. Though plastic is invisible to RF energy, it may read a loose cover as clutter or feedback and that may be why some people get an error.
    The sensor has some ability to work within a height difference parameter. The vehicle is dynamic and the angle and height above the roadway constantly change as the suspension cycles up and down, and the vehicle travels over terrain. I don’t get errors when the truck is off road and the front end is bouncing or I am going up or down a steep grade. If the sensor couldn’t deal with vehicle height and angle changes, it would throw a fault all the time and be worthless.
  6. Sep 16, 2021 at 10:09 PM
    Tacomod
    Tacomod Well-Known Member
    When doing the swap, I recommend leaving your TSS sensor plugged in (just place it on top of the engine after you unscrew it). I think a lot of peoples problems with doing the swap are related to unplugging and replugging the sensor.
  7. Sep 17, 2021 at 2:30 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Disconnect the battery and wait 20 minutes before install.
  8. Sep 17, 2021 at 4:30 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    There's no need to unplug it. There's enough slack to leave it there while you swap grills.
  9. Sep 17, 2021 at 5:00 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Gonna be honest here, I only had an issue the first time I installed my pro grille. It said "clean sensor" I think. Other than that, I've reinstalled my stock grille like 15 times in the past 2 years (whenever I go to the dealership I put the stock grille on) and I've never had an issue. I think I hold the speedrun record at just under 5 minutes for the swap.
    Just a good tip, if you have a 2018 tacoma or a tacoma that has the TSS recall (or if you think you have it), always throw the stock grille back on before going to the dealership. Don't let this happen to you
    https://www.tacomaworld.com/threads...n-system-due-modified-grill-pro-grill.692391/
  10. Sep 17, 2021 at 4:36 PM
    pinktaco808
    Has anyone done it to access cab no problems and do the trick with the washers on the top screws????
  11. Sep 17, 2021 at 4:43 PM
    brandon78lusch
    Brandon
    It'll work on access cab tacos too
  12. Sep 17, 2021 at 5:02 PM
    MAD777
    MAD777 Well-Known Member
    White Mountains, NH
    2021 Tacoma SR5 4x4 Double Cab 6' bed
    I installed a pro grille with TSS the other day and placed one washer on the top skrew. It works perfectly fine.
  13. Sep 18, 2021 at 1:53 PM
    pinktaco808
    Gotta disconnect battery and Waite 20 min???
  14. Sep 18, 2021 at 1:54 PM
    brandon78lusch
    Brandon
    Its not required
  15. Sep 18, 2021 at 1:55 PM
    MAD777
    White Mountains, NH
    I did.
    Not sure what would happen if I hadn't.
