TRD Pro Grill Swap, issue....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CdnDave20, Sep 13, 2020.
  1. Sep 13, 2020 at 5:37 PM
    CdnDave20
    CdnDave20 [OP] Active Member
    Stock
    So I just did the TRD Pro grill swap on my 2018 Sport, went "okay". Grill seems to be decent, it's solid.. the issue is in the garnish I bought from Amazon, the main part seemed well made, the plastic brackets were shit and 1 was broken already when I got it.. it doesn't seem to feel secure.. the tabs are in, but the little metal star type ones that go inside on the plastic thing are not solid and cause the whole garnish to move very slightly..
    Any idea for a fix? Was thinking of just folding up some paper really small and sticking it in the edges to prevent movement.. I decided to use the cover that came with the grill as the shiny garnish was shit and broken.. also any idea how long it takes the pre-collision sensor to recalibrate? Turned the truck on and off a few times, error comes back 20-30 seconds later.
  2. Sep 13, 2020 at 6:14 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    The aftermarket one I bought I never had any sensor issues. I unplugged the battery before installing, and when everything went back together and I took it down the road, no errors and my adaptive cruise tested to be working. My aftermarket garnish was less than desired in terms of quality as well, but it's ok.
    Some of the Ebay ones are known to have calibration issues, kind of a gamble but some have had luck installing washers to reposition the garnish, I wouldn't run it without one as I'm sure that sensor is pricey to replace.
    Junkhead likes this.
  3. Sep 13, 2020 at 6:47 PM
    CdnDave20
    Stock
    The clip on the garnish is busted off not exactly sure how to fix it other than buying another new garnish.. but at $50 a pop and sub par quality clips I dunno..
  4. Sep 13, 2020 at 6:49 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I bought a different garnish off Amazon. I just looked for a seller with good ratings. My first one was from mad hornets and it was garbage. The light would always come back on with the first one and has never come on with the second one. I don't think repositioning is really that important but others seem to have had a different experience
  5. Sep 13, 2020 at 6:51 PM
    CdnDave20
    Stock
    The seller had good ratings, the part had good ratings, I've read others had the same issue but after a bit the error went away, it sort of re calibrated automatically or something.. not sure if that's possible though
  6. Sep 13, 2020 at 6:51 PM
    BSFord
    2018 TRD Sport 4x4
    Can you return it? The one I got is from taco garage, shipping was slow but I'm generally happy with it and no errors. The garnish I got wasn't great ( I asked for a replacement which wasn't any better) so i think all aftermarket ones are just a little rough, no broken clips tho. The garnish has to be aligned correctly, if yours has a broken clip it sounds like you need a new one.
    Edit: my grill also snapped in pretty tight as well, could be a contributing factor if your is lose.
  7. Sep 13, 2020 at 7:00 PM
    CdnDave20
    Stock
    The grill itself is pretty good, I bought that from a different person as they didnt have any garnishes. The garnish seller had good reviews and votes.. I'll try and find a different one
  8. Sep 13, 2020 at 7:04 PM
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    The dealer must reset it once it’s been unplugged and reposition it’s not behind the Toyota emblem anymore it’s right below the old location
  9. Sep 13, 2020 at 8:02 PM
    BSFord
    2018 TRD Sport 4x4
    I'm not sure that's true. I unplugged mine and repositioned it, with the battery disconnected, never threw a code once.
  10. Sep 13, 2020 at 8:47 PM
    CdnDave20
    Stock
    I am going to try that tomorrow and see how it goes!
    BSFord[QUOTED] likes this.
  11. Sep 14, 2020 at 3:22 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Not true! Once you move it they have to recalibrate it. It's not necessary to reset it.
  12. Sep 14, 2020 at 6:52 AM
    AODRN
    STL
    Moving the location of the sensor changes the distance between you and the car in front of you but it will not set the light off
  13. Sep 14, 2020 at 7:13 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Huh? That makes no sense to me.
    bJz4jrNG4FLqmSKgVBhmaRCNITE0xlJXUIJXK3rX_713dc77e2fa45c9435a3625977e55a6c6dfd343c.jpg
  14. Sep 14, 2020 at 8:32 AM
    AODRN
    STL
    When you go from stock to pro grill, you lower the sensor a little. This doesn't cause a light saying it's dirty. It does change the distance between you and the car in front of you when using adaptive cruise control. If you don't like the new distances, you can get the dealer to recalibrate.
  15. Sep 14, 2020 at 9:16 AM
    Tullie D
    Tullie
    Wilson, NC
    funkeedingus likes this.
  16. Sep 14, 2020 at 10:36 AM
    AODRN
    STL
  17. Sep 14, 2020 at 11:33 AM
    NoeWiy
    NoeWiy Well-Known Member
    Alex
    Washington State
    2018 TRD Sport MGM DCSB
    My bullshit meter is also off the charts. Why would moving the sensor down, but not forward or backwards, change the distance between you and the cars in front of you?
    BSFord likes this.
  18. Sep 14, 2020 at 1:17 PM
    AODRN
    STL
    The radar in the grill works with the sensor in the windshield. You are changing the distance of one side of a triangle.The garnish is just a piece of plastic that is supposed to be invisible to the radar. As long as it is invisible it doesn't get in the way. If I'm wrong then that's fine but just telling me I'm an idiot doesn't work
    Natetroknot likes this.
  19. Sep 14, 2020 at 1:46 PM
    Tullie D
    Tullie
    Wilson, NC
    I don't remember anyone calling you an idiot. Well, except for yourself. :rofl::rofl::rofl:
    If the shoe fits, wear it.​
  20. Sep 14, 2020 at 1:55 PM
    AODRN
    STL
    How did I know it was gonna go here? Just trying to help. If you don't want my help then what is your motivation for even making a reply? If it's your sense of right and wrong, you should show me why I am wrong so everyone can correct themselves and move on. I really don't care about the sensor but the way people treat each other is starting to wear on me. I apologize if I offended you but please believe it was not intentional.
