TRD Pro Grille for $140?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SDTaco89, Nov 10, 2017.
  1. May 5, 2018 at 6:04 PM
    #4141
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    ^ Your truck is sweating
    blewis likes this.
  2. May 5, 2018 at 6:52 PM
    #4142
    Forge
    Forge Well-Known Member
    Rick
    Installed my china pro grill...easy 5 min job...no broken tabs. Also installed fogs on my SR.
    Taco de Naranja and N2DesignsInc like this.
  3. May 7, 2018 at 6:42 AM
    #4143
    Ricebox
    Ricebox Well-Known Member
    FL
    18' TRD Off-Road 4x4 Prem/Tech
    Confirmed with seller that letters shipped separately, they were just a few days behind the grill and i didn't know that, no worries there. as far as the broken tab im working with the seller to get a partial refund, seems like a few people have made it work with a broken one or two.
  4. May 7, 2018 at 6:02 PM
    #4144
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    What kit did you use for the fog lights ? I have an SR and looking to do the same.
  5. May 7, 2018 at 6:12 PM
    #4145
    SavageTacoma
    SavageTacoma NorCal-Taco
    Dillon
    NorCal: Wine Country
    16' AC Grey TRD OR
    285/70r17s Pro comp 3" lift
    Bought mine used on eBay for 210 for my 18
  6. May 7, 2018 at 6:29 PM
    #4146
    Forge
    Rick
    Got this set off Ebay. Just a heads up if your SR is wired for it you can do an install that will not need an add a circuit. If you have the convenience package on your SR then you probably are. I am but the fam gave me this kit as a gift. Plus this is the lower cost option. They actually got it with a 20 percent off ebay coupon. There are several kits on ebay. Kit has everything you need except add a circuit and fuse for switch. Here is the thread on doing an install if you are pre-wired by @Nitori. Here is post from another thread I had.
    [​IMG]$69 2016-2017 TOYOTA TACOMA BUMPER DRIVING FOG LIGHTS LAMP YELLOW W/BLACK BEZEL+BULBThe kit is pretty straight forward. The light trim fits pretty good but not as tight as a stock one would. H11 bulb seems to work good...also like the color of light also. Will keep an eye out for OEM light trim. Only cause I can be picky at times. Taking the old trim off was pain in butt... Had to shove arm in from top and feel around to get the snaps out. Also fished the wire thru the bumper (internal bumper not cover) using two metal coat hangers. Used add a circuit and connected to switch fuse so won't accidentally leave on and drain battery.
  7. May 7, 2018 at 6:56 PM
    #4147
    SchwiftyTaco17
    SchwiftyTaco17 Well-Known Member
    2017 Quicksand Tacoma SR5 DC
    Have you ever been to Florida?
    blewis likes this.
  8. May 8, 2018 at 3:20 PM
    #4148
    Zn6ft86
    Zn6ft86 Active Member
    Nashville, TN
    2017 Quicksand TRD Offroad DCSB
    AeroCooper likes this.
  9. May 8, 2018 at 9:44 PM
    #4149
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    oh wow, great find. that was my only gripe with the grill after the install and even before buying the grill. but i found a work around that hides the gap, kind of sort of. the gaps are still there, but now it looks like the gap was kind of intentional, if that makes sense. so now im 100% happy with it. thanks for the link!
  10. May 8, 2018 at 9:46 PM
    #4150
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    So what was your work around that hides the gap? Pics?
  11. May 8, 2018 at 11:37 PM
    #4151
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    I still have the chrome grille on and I checked for the gaps and it has the same gaps posted earlier, I too have the China grille waiting to install when rain stops...
  12. May 8, 2018 at 11:45 PM
    #4152
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    You mean when the lava stops...
    Taquitoma likes this.
  13. May 9, 2018 at 11:26 AM
    #4153
    slowlane
    AZ
    16 double cab MGM
    i should have taken pics when i did it.
    so i bought some black screen spline from home depot. the thing you us to attach the mesh to a window screen. if youve installed the faux grill, you might know what im talking about. on the inside of the color matched part of the grill, there are these grooves all the way around the grill. i pretty much sandwiched the black spine in those grooves. so the gap is still there, but it now looks like theres a "rubber gasket" behind the faux grill. the gaps were bothering me to much. i almost went back to the ofg road grill.
  14. May 9, 2018 at 11:47 AM
    #4154
    maileboy
    David
    Yah, rain and lava! Vog is unreal to do anything outside.....don't even wanna go anywhere, acid rain leaves deadly water spots!
  15. May 11, 2018 at 9:30 AM
    #4155
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    Just bought a grille.. Hopefully it works well. 120 shipped!
    Next I want the TRD PRO fox suspension at some point!
  16. May 12, 2018 at 5:27 AM
    #4156
    taco_boy
    taco_boy Antiplastidipper
    California/Land of the Fee
    2018 Tacoma TRD On Road MT
    Noob Taco owner
    The $119 eBay grill fits my 2018 like a champ! It even houses the OEM TSS garnish without issues. Mind you this setup ran me $175 total and twas a breeze to install. The stealership quoted me $500 for grill, garnish and extra to install. Nope. For those with TSS, don't break the zip ties on the harness cause you can reuse them on the knock off grill. Test drove it 200 miles, no dash lights, error codes DRCC, lane departure bs work the same before install.
    MVIMG_20180509_145816.jpg IMG_20180509_135059.jpg IMG_20180509_171852.jpg IMG_20180509_172257.jpg IMG_20180510_102252.jpg
    Pistolpete8521, TacoJetMech and 75z28 like this.
  17. May 12, 2018 at 8:27 AM
    #4157
    75z28
    Homer
    I just ordered the 119 one(I have a 17 so mine doesn't need anything extra). I can't wait. Your truck looks sweeeeet!
    taco_boy[QUOTED] likes this.
  18. May 12, 2018 at 10:53 AM
    #4158
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    i effed up...... listing is gone for the 119 one.. fack
  19. May 12, 2018 at 11:08 AM
    #4159
    75z28
    Homer
    I got an email saying I had ordered the last one. Keep an eye out, I am sure they will pop up!
  20. May 12, 2018 at 11:14 AM
    #4160
    FlapJack935
    Jack
    Abq New Mexico
    just ordered one that had good reviews and quick shipping for 140. no biggie! snooze you lose! had that tab open for 6 days but never ordered it lol
