TRD Pro Grille for $140?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SDTaco89, Nov 10, 2017.
  1. Dec 7, 2017 at 5:27 PM
    #1741
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    Same. Tell us how the eBay claim goes
  2. Dec 7, 2017 at 5:30 PM
    #1742
    javamac10
    javamac10 Active Member
    IMG_6224.jpg IMG_6226.jpg IMG_6221.jpg IMG_6222.jpgIMG_6227.jpg IMG_6228.jpg IMG_6229.jpg IMG_6232.jpg IMG_6233.jpg IMG_6236.jpg IMG_6237.jpg IMG_6238.jpg
    Ordered from Motorfansclub on eBay on 21NOV2017 at 9:37 PM for $140 shipped.
    Shipping was delayed due to the aforementioned "package size limit". The shipment had to be changed to HongKong Air Post. After that, it took a few days for the tracking to update, but once it started to update, it quickly changed from "Processed through Hong Kong blah blah blah" to Chicago ICS. It was in customs for only about 24 hours and then was on it's way to Indiana. The grille arrived at my door at about 4PM on 06DEC2017.
    The box and packaging looked like lots of others' who have posted here.. the box: about 6"x20"x50". The box was in good condition when it arrived with only one puncture about the size of a pen. Inside the box, the grill was in a slim bubble wrap bag, with the tab-side backed by two large foam blocks (again, like others have posted). I'm not sure how the grill made it that far in such a good condition with such little packaging in the box...
    The grille has no broken tabs. The outside edge of the grille has some small imperfections as shown in the pictures, but my guess that these edges would not be visible when mounted, was correct. There was also some plastic fringe around the edges of some of the grille detail, but these were easily pulled off by hand, scraped off by fingernail, or finessed with a metal file. If I must nitpick, there is a very VERY small/shallow scratch on the "O", and the lower left leg of the "A" is a bit deformed, but this is REALLY nitpicking and honestly - no one else will notice this.
    I would say that this grille is a THREE-piece:
    1) The main body of the grille.
    2) The "TOYOTA" emblem that screws into the center (with 4 screws).
    3) The lower plate that screws in place of where some people have noted that the new TSS sensor may go (also 4 screws).
    The grille pieces were all solid molded black plastic; no paint. The front of the Toyota letters are of course, silver plastic.
    After reading other posts on this thread, I decided to preemptively hand-file down the lower 1/3 of the screw mounts for the TSS block plate area. I found during the install that this was definitely a good idea to do beforehand, as it wouldn't have mounted correctly if I had not filed them down before assembly.
    Learning from others, I installed the grill following these steps:
    1) open hood
    2) use painter's tape to mask off surrounding areas to grille fascia, to avoid scratches when dismounting/mounting grille.
    3) remove two main philips screws
    4) remove two plastic fasteners
    5) pull the entire grille forward off the truck.
    6) take inside and place on carpeted floor
    7) remove 8 black screws holding factory TRD OR chrome grille bezel (these 8 small screws won't be reused)
    8) carefully release each tab of the stock grille, going around in a continuous circle.
    9) Lift factory chrome grille from fascia
    10) slowly work the faux pro grill into place, snapping tabs back in place slowly, in a circle pattern.
    11) back at the truck, line up the lower mounting tabs of the fascia with the receiving holes in the bumper.
    12) push entire grille back into place as one piece, feeling it snap into each area.
    13) re-install the plastic fasteners and philips head screws on top.
    14) remove painters tape
    15) enjoy enhancement of the black contrasting color, matching the other TRD OR black trim.
    The install took about an hour total, including the filing, fringe trimming, etc....
    You can't see any of the edges of the grill where there are small blemishes from the mold. There are no visible blemishes, especially after removing any of the plastic fringe in the grille pattern area. There is a small gap around the outer edge of the grille as some others have mentioned, but on the inferno color, it's really not noticeable.
    Also, after removing the factory chrome grille, it's really of almost the exact same quality as he faux pro grille, and also has marks and a bit of an edge around the outside from where it must have been released from it's mold. The two, in my eyes, are really very similar in quality.
    Time will tell if the faux pro grill will look good in the distant future, but for now it is definitely worth the price, and I am very satisfied with the purchase.
    Ruggybuggy and TT005 like this.
  3. Dec 7, 2017 at 5:41 PM
    #1743
    Gillbilly
    Gillbilly Active Member
    Thomas
    17 white trd sporty
    Please post the link to this claim. I can only find the 140.00 grills
  4. Dec 7, 2017 at 5:45 PM
    #1744
    TSmoove
    Trevor
    Atlanta, GA
    2017 Tacoma
    Burns, Xtian8 and Ruggybuggy like this.
  5. Dec 7, 2017 at 5:53 PM
    #1745
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Thanks, TSmoove.....I wouldn't know how to do the link.
    TSmoove likes this.
  6. Dec 7, 2017 at 6:40 PM
    #1746
    TT005
    TT005 Well-Known Member
    NC
    2023 SR5 DCSB 4X4
    Here are a few close-up photos of the back. It looks like black plastic to me, although the back shows a lot of spotting.
    8D720DF3-AB20-47EC-BBEC-752A665DC695.jpg F96458BC-6577-4CB0-B583-74FE57E83F34.jpg DDD611C6-CAC6-4043-9384-283CA25A54F4.jpg
  7. Dec 7, 2017 at 7:36 PM
    #1747
    Christopherm1856
    Christopherm1856 Well-Known Member
    Christopher
    17 TRD OR DC 4X4
    1512686900291.jpg 1512668688012.jpg Looks great! Only took 15 minutes to install. Got mine on Amazon and it took 12 days.
  8. Dec 7, 2017 at 7:58 PM
    #1748
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Now 2 ebay ads under $95
    growyourmind86 likes this.
  9. Dec 7, 2017 at 8:10 PM
    #1749
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Wow, I thought mine was a deal at $108.
  10. Dec 7, 2017 at 8:12 PM
    #1750
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I'm a buyer when they get down to $50. I wonder if they're clearing out the painted ones for less in those listings?
  11. Dec 7, 2017 at 10:31 PM
    #1751
    Stefan_Ray
    Stefan_Ray Tacoma TRD Life
    Stefan
    Concord,North Carolina
    2021 TRD Pro
    Cooper STT Pro’s
    You don’t want to wait that long. I bought OEM and it was worth every penny!
  12. Dec 8, 2017 at 5:32 AM
    #1752
    Xtian8
    Xtian8 Well-Known Member
    NYC
    2017 Tacoma TRD OFF-ROAD DCSB (SuperWhite)
    SCS Ray 10's, KO2's, TRD Pro-Grille TRD Sport Hood Bilstein 5100 Icon AAL
    How much from Amazon?
  13. Dec 8, 2017 at 5:36 AM
    #1753
    Christopherm1856
    Christopher
    17 TRD OR DC 4X4
    $150. I know I could have done cheaper on eBay but I like Amazon customer service more
    Lt. Dangle and Xtian8[QUOTED] like this.
  14. Dec 8, 2017 at 6:48 AM
    #1754
    rancho
    rancho Well-Known Member
    Martin
    Rancho Santa Margarita, CA
    2017 TRD Sport 4x4
    did you use this vendor? http://amzn.to/2B8fLjk
  15. Dec 8, 2017 at 6:49 AM
    #1755
    Gillbilly
    Thomas
    17 white trd sporty
    Im going to revert this to the "yeti cup crazyness". When they first came out they were like 60 bucks. All the sudden walmart got ahold of them and boom 9 bucks. They were the same cups from same factory just different logos. But all worked the exact same.
    Now we just need someone to come out with an affordable pro headlight set under 300 so we can all get-r-done....
    Burns, mrproduxn and TT005 like this.
  16. Dec 8, 2017 at 6:57 AM
    #1756
    TT005
    NC
    2023 SR5 DCSB 4X4
    I like this look.
    Blue16TSS likes this.
  17. Dec 8, 2017 at 7:08 AM
    #1757
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    I'm waiting on mine which is apparently shipping from Singapore.
  18. Dec 8, 2017 at 7:10 AM
    #1758
    TacoGlenn81
    TacoGlenn81 Well-Known Member
    I ordered the $108 grill off ebay. Has anyone received theirs yet?? if so hows the quality?
  19. Dec 8, 2017 at 7:12 AM
    #1759
    growyourmind86
    growyourmind86 Well-Known Member
    2017 trd Tacoma
    Ughhh I want a grill so bad. Been watching this thread awhile now. Def will order from one of these vendors and save the cash. My plasti dipped stock grill has to go.
    remgu2000 likes this.
  20. Dec 8, 2017 at 7:44 AM
    #1760
    Christopherm1856
    Christopher
    17 TRD OR DC 4X4
