TRD PRO Myths Truths & Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RKCRUZA, Oct 3, 2014.
  1. Oct 4, 2014 at 3:47 PM
    clc2112
    clc2112 Well-Known Member
    Calvin
    San Jose, CA
    '21 Lunar Rock
    ** 2015 Tacoma TRD PRO ACCESS CAB 4X4 V6 **
    This is odd. I have two on order from two dealers. They BOTH say:
    "V6 Tow Package for Off Road Package " $650 under the OPTIONAL EQUIPMENT.
    • Class-IV Towing Receiver Hitch
    • Transmission Oil Cooler (Auto Only)
    • Engine Oil Cooler
    • 130a Alternator
    • Heavy Duty Battery
    • 7-Pin Connector w/converter
    • Trailer Say Bar
    This is on my Tacoma Pro sheet the tow package is $650.
    Are you telling me that it will arrive without it?
  2. Oct 4, 2014 at 3:55 PM
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    I have on order and it is Ordered with the tow package for $650 including coolers and beefed up altenator/battery
  3. Oct 4, 2014 at 4:02 PM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Ok, I stand corrected. I was using two different trainig sources and they both say that the Tow Package isn't available. So I took it a step further and went to the locate screen and there are 8 coming in to the southeast WITH THE TOW PACKAGE!!
    SO I AM SO SO SO SO SO SORRY for being "that guy" lol! I'm gunna dig a lil further on Monday w/ our Inventory manager and double double check lol!
    I'm PISSED that this TRAINING material is ALL WRONG!!!
    *hangs head down low and walks away*
  4. Oct 4, 2014 at 4:03 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    This is getting interesting. Has anyone seen or have a picture of a TRD Pro WITH the tow package? Any of you Pro owners? Anyone? I'm not buying one or anything. But this is just crazy.
  5. Oct 4, 2014 at 4:04 PM
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Ahhh. There we go. Hey, at least it's an answer finally.
  6. Oct 4, 2014 at 4:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Those are not acceptable either. All three vehicles are unacceptably clunky. However, there is a fix to it. There is a fix to that issue. The clunkiness you are experiencing is due to an intermediate shaft which is exposed too far into the cabin. In order to fix it you need to unbolt the shaft at the sleeve which grips on it behind the wheel well engine compartment skirt and move the shaft until you can only see about 2-3 mm of exposed shaft inside of the steering column in the cabin. I will provide pictures later for you to see and no it will not void the warranty.
  7. Oct 4, 2014 at 7:32 PM
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    I think the OEM's are not great on the freeway. It takes longer than the Sport or OR. I'm considering putting in TRD brakes eventually.
  8. Oct 4, 2014 at 7:38 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Mine make a weird clamping sound when applyed
  9. Oct 4, 2014 at 7:41 PM
    pocketsmcaaron
    Oregon
    Vijay, I picked mine up on Sept. 4th, Same configuration as yours. Have you had the clunky steering issue when off-road bumpy surface? I am in a struggle with Toyota to fix the steering column. They simply won't....If you experience this, join the movement pls...
  10. Oct 4, 2014 at 8:47 PM
    Taco'09
    Taco'09 Well-Known Member
    If you like the way your steering clunks now you are really going to like it in a few hundred or a couple of thousand miles. It is only going to get worse.
    Your steering components are the same as on my '14 TRD Off Road and by 800 miles mine was clunking so bad I could not take it any more.
    Toyota is so full of it. They issued a TSB for this in 2010 and then reissued it again in 2012 to include models through 2012. The current TSB is T-SB-0057-12 and is a redesigned intermediate shaft. Problem is the TSB has not been reissued for 2013-2015 models. Now get this. From the time the original TSB was issued in 2010 they have been using the non-TSB shaft on new production models which forces us to do our own fix by purchasing the TSB shaft.
    Moving the intermediate shaft forward a bit as described above is part of the fix but my intermediate shaft was shot and my fix required installing the new TSB shaft and slightly moving the shaft forward. I also did this fix on my '09 about 4 years ago and have been happy with it.
  11. Oct 4, 2014 at 9:48 PM
    pocketsmcaaron
    Oregon
    Taco '09, can't thank you enough for this info. WOW....I will most likely try this route soon. Today I sent a letter to Toyota describing how their customer care for a new vehicle with this problem has been completely dissatisfactory.
  12. Oct 4, 2014 at 11:08 PM
    loki32687
    loki32687 Matt
    Peabody, Ma
    17 TRD Sport Inferno
    Here's the sticker from my pro...
    D30E550E-F8F3-483B-A8E1-E95A9E357B31_zps_8748be95744a83b8ade156459fca56cfb0b6035a.jpg
    Anderson likes this.
  13. Oct 4, 2014 at 11:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have found the brakes on my 12 Sport to be nothing short of exceptional for a truck. They have always provided me great stopping power and distance, even when hard wheeling it. I see absolutely no need to upgrade anything at all in the brake systems on these, but that's just me.
  14. Oct 4, 2014 at 11:35 PM
    RKCRUZA
    RKCRUZA [OP] Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Thanks for posting it! The dealer I have been working with said the one they are getting has the full tow package so this confirms it.....now if they follow through and actually get the thing it seems I will be getting an Inferno 4drsb auto with factory tow package for 40,700 out the door (California)...works out to about $1500 off the MSRP of 38,950 (38,300 + $650 for Tow Pkg)......so about $37,500 or so actual cost before TL & such....then again I'll believe it when I have the keys in hand. This is the only dealer I have found that would give any discount off of MSRP and has since said they won't be doing it again....seems they are going to stick by the quoted price but have figured out it was a mistake on their part. Most dealers out here don't seem to have a clue what a TRD Pro even is!
  15. Oct 4, 2014 at 11:37 PM
    #35
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    no additional coolers, not even one for the engine oil?? that's honestly upsetting to me, and if you wanted to add that on yourself it costs a pretty penny... and if only 8 are being shipped with the tow package, those are going to be some VERY RARE birds... idk why toyota just hasnt made the V6 tow package standard equipment yet on ALL V6 tacomas regardless of them being a TRDpro or not.. those coolers and higher output alternator alone are worth 3 times their weight in gold to a person like me lol.
  16. Oct 4, 2014 at 11:55 PM
    #36
    RKCRUZA
    Bob
    Placerville, Ca
    It would be interesting to find out if the ones with the added on hitch have the wiring installed where you could add the 7 pin connector. The ones with the factory tow also have a connector in the cabin to plug a brake controller into so it is a plug and play thing with a small adapter cable that you can get with your Brake Controller. Factory tow also has "Sway Control"...not sure what that is, but assume it is another computer function that helps control trailer sway. So there is a lot that comes with the Factory Tow Package, it is not simply a hitch and a plug....
  17. Oct 5, 2014 at 9:59 AM
    #37
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Most dealrs out here don't seem to have a clue what a TRD Pro even is!
    Lol, irony behind truth. Why dont manuals come with coolers?
  18. Oct 5, 2014 at 10:10 AM
    #38
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nvm, i found out why. Sorry
  19. Oct 5, 2014 at 11:43 AM
    #39
    medic2230
    Murph
    Bama! Roll Tide
    Not going to share with others that might not know why the manual doesn't have a cooler? :rolleyes:
  20. Oct 5, 2014 at 11:47 AM
    #40
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Can you even order the tow package with a manual transmission? I believe the cooler is for the Automatic Transmission fluid.
    edit:Yes, Manual 6spd with tow pkg has an engine oil cooler. Yes, both TRD Sport, and TRD Off Road packages come with Tow Pkg as Standard. TRD T/X Pro model is based on upgrades to TRD OR model. No idea if it comes w/ tow pkg.
