TRD PRO Myths Truths & Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RKCRUZA, Oct 3, 2014.
  1. Oct 6, 2014 at 9:07 PM
    #61
    Sgt Jmack
    Sgt Jmack Well-Known Member
    Jeremiah
    New Orleans, LA
    14 Sport Dbl cab L/B
    3" Revtech, Undercover flex.
    Remember, training material comes out way before the vehicles, and it is printed by someone other than the builders. Don't know why, but it has been that way since I started with Toyota years ago.
  2. Oct 6, 2014 at 9:11 PM
    #62
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    But you can not add the TSC, Trailer Sway Control. That is only done at the factory.
  3. Oct 6, 2014 at 9:14 PM
    #63
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    According to Toyota, everything is "within specs." Sorry.
  4. Oct 6, 2014 at 9:20 PM
    #64
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    No need to cool the manual transmission fluid as it is not compressed and heated as it moves through the inner workings of the transmission like the automatic ones are. Plus (in a nut shell) there isn't a strong pump in the manuals like there is in the auto's, gear oil is basically slung around inside as the gears move.
  5. Oct 6, 2014 at 9:22 PM
    #65
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    TCS works with the braking system and VSC to help you carry heavier loads and keep the trailer behind you instead of beside you... So it can only be installed at time of build.
  6. Oct 6, 2014 at 9:28 PM
    #66
    loki32687
    loki32687 Matt
    Peabody, Ma
    17 TRD Sport Inferno
    I've said it before in this thread. My Pro has a tow package and coolers.
  7. Oct 6, 2014 at 9:30 PM
    #67
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    No, you can get the factory installed tow pkg on the Pro. The problem is that some dealerships don't like to add a lot to these trucks because the cost gets high and some times high priced specialty vehicles sot on their lots for a little longer than they want. Certain dealers sell mostly lower priced vehicles depending on their location and client list.
  8. Oct 6, 2014 at 11:35 PM
    #68
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Might be because TRD OR, and TRD Sport come with Tow Package as part of the TRD package, yet the TRD T/X Pro package does not. Folks have to appreciate that they have to order the Tow Pkg as optional eqt. on the PRO model to add to the unique features of the PRO pkg. Then of course there is the T/X Baja package as well. :goingcrazy:
  9. Oct 6, 2014 at 11:51 PM
    #69
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    feels like Toyota is going the route of GM at times, with a zillion different packages, and this comes with that, but not this nonsense. All in the name of sales, and grab some more monies out of your pocket so you can have a cool looking truck.
    Some of us are less inclined to go into debt to get a new vehicle, work with modifying our 'new to us' truck and spend way too much time on forums like this.
  10. Oct 7, 2014 at 12:23 AM
    #70
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    exactly, and You Sir, are just the customer Toyota is aiming at and have they got a deal for you, Full Warranty, drive it off the lot, mods already made, and in a color you can't get on the lot in any other Tacoma. 4.99% financing available OAC, Dealer may sell for less (NOT) Hey, don't knock it, It works, and is the right fit for many folks. :D <--the smile the new driver is wearing when they drive off the lot!
  11. Oct 7, 2014 at 1:51 AM
    #71
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Totally agree, definitely the wrangler route lmao, but at least theres not as many, and i feel the toyotas are more thought out lol
  12. Oct 7, 2014 at 1:59 AM
    #72
    kyleTRDtaco12
    Kyle
    New Jersey
    I guess.. but a factory tow package is only like a $650 factory installed option. . It doesnt add very much to the MSRP so i dont see the dealers wanting to dismiss something thats so good for the consumer in so many ways just to keep prices down like a literal hair, that doesnt make sense to me. :rain: i mean, i know $650 is $650, I'd like to have that right now, but still, it's alot of bang for your dollar, if its factory installed that is..
  13. Oct 7, 2014 at 2:38 AM
    #73
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm a little late to replying back. This is a post given directly by one of the members on here and while mine was set like this from the factory, I could see this helping EVERYONE out. I feel it's only right to spread this post so more people find out about this.
  14. Oct 8, 2014 at 10:25 AM
    #74
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    TACO '09--I WANT TO THANK YOU AGAIN! Toyota took in my TRD PRO today finally. The lead toyota mechanic confirmed your letter.
    Indeed, the 2015's did not get the re-designed intermediate shaft T-SB-0057-12, so they are replacing it today under TSB. Hopefully the steering clunk will go away!! THANK YOU,THANK YOU,THANK YOU!
  15. Oct 8, 2014 at 3:09 PM
    #75
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If worse comes to worse, you can always do the fix described above. Mine is set to the exact same depth as described in the picture from the factory, I get no odd clunks, and the only clunk I get on hard off-roading impacts are from my Fox delrin lined air bump pads (Not applicable to your stock application, lol).
  16. Oct 8, 2014 at 8:46 PM
    #76
    pocketsmcaaron
    Oregon
    UPDATE:
    TOYOTA FIXED THE CLUNKY STEERING UNDER 3YR/36K WARRANTY.
    IF YOU ARE EXPERIENCING THIS WITH ANY VEHICLE FROM 2013-2015 THERE HAS NOT BEEN AN OFFICIAL RECALL AND THE INTERMEDIATE STEERING SHAFT HAS NOT BEEN CORRECTED FROM THE RECALL OF 2005-2012 REDESIGNED SHAFT.
    AFTER MANY FAILED ATTEMPTS TO GET THE GREEN LIGHT AND MUCH RESEARCH ON THIS AWESOME SITE, TOYOTA INSTALLED UNDER TSB 45220-04020 SHAFT ASSEMBLY. RESULT: STEERING IS SMOOTH AS BUTTER ON ALL DRIVING CONDITIONS, NO MORE CLUNKY IMPROPER FREEPLAY.
    I AM SINCERELY GRATEFUL TO A FEW OF THE SENIOR MEMBERS, PARTICULARLY TO
    TACO '09, THANK YOU:
    "Your steering components are the same as on my '14 TRD Off Road and by 800 miles mine was clunking so bad I could not take it any more.
    Toyota is so full of it. They issued a TSB for this in 2010 and then reissued it again in 2012 to include models through 2012. The current TSB is T-SB-0057-12 and is a redesigned intermediate shaft. Problem is the TSB has not been reissued for 2013-2015 models. Now get this. From the time the original TSB was issued in 2010 they have been using the non-TSB shaft on new production models which forces us to do our own fix by purchasing the TSB shaft.
    Moving the intermediate shaft forward a bit as described above is part of the fix but my intermediate shaft was shot and my fix required installing the new TSB shaft and slightly moving the shaft forward. I also did this fix on my '09 about 4 years ago and have been happy with it."
  17. Oct 13, 2014 at 10:44 PM
    #77
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    Dollar amounts are all psychological... $27,859 looks better than $28,205. I don't see it in my head, I see $27,900 and then look at $28,000 any way.
  18. Oct 16, 2014 at 4:46 PM
    #78
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    I can confirm that I just saw a window sticker from an inferno trd pro that does have the full tow package.
    They do have rear locker and a trac.
    Jon
  19. Oct 18, 2014 at 11:52 PM
    #79
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    Yeah, they start out life as an TRD OR Pkg and add a few extra parts and pieces.
  20. Oct 19, 2014 at 8:07 AM
    #80
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    yes A-trac and rear locker also,, duh..lol...
