TRD Pro Rear Shock (Upper) Bushings and Washers?
Discussion in 'Suspension' started by 7ender, Dec 4, 2019.
  1. Dec 4, 2019 at 10:39 PM
    7ender
    7ender [OP] Well-Known Member
    Hello TW
    Replacing rear 5100's in a 3rd gen with TRD Pro shocks. However, the threaded shaft diameter is larger than that of the 5100's. The TRD Pro shocks did not include washer/bushings to install to the upper mount, and the ones from the 5100's dont fit over the shaft.
    Is there a special kit associated with the TRD pro suspension? Looked around but couldn't find a Toyota P/N for such.
    Thanks!
  2. Dec 5, 2019 at 8:04 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    All mounting part (bolts/nut/washers) for the TRD pro struts are the same with the exception of the rubber bushings (at least according to the parts guys at my local dealer)
    whatstcp likes this.
  3. Dec 10, 2019 at 3:47 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Maybe just drill out the 5100 bushings, they should be the same outer diameter since they use the same upper mount.
  4. Dec 10, 2019 at 3:52 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Talk to FOX?
  5. Dec 10, 2019 at 3:52 PM
    5nahalf
    Erik
    Minnesota
    Here are the specs from fox on the replacement bushings they are sending me
    Bushing: Eyelet [0.380 ID X 1.268 OD, 0.639 TLG] Polyurethane, Black, Mount Stud
    perkj likes this.
