TRD Pro Rigid Foglight replacement
Discussion in 'Lighting' started by Shawny5ive, Sep 8, 2021.
  1. Sep 8, 2021 at 8:00 PM
    Shawny5ive
    Shawny5ive [OP] Well-Known Member
    Shawn
    NorCal (707), California
    ‘21 Army Green Tacoma TRD Off-road DCSB
    Anyone know if there’s a plug and play option for fog lights that fit in the TRD Pro Rigid Industries shroud?
  2. Sep 8, 2021 at 8:01 PM
    Shawny5ive
    Shawn
    To clarify, I like the look of the Rigid Industries design, but am wondering if there’s a better fog light that can be put in there
  3. Sep 8, 2021 at 8:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I don’t think anything will be plug and play other than Rigid’s SRM SAE lights which the TRD lights are based on, but I believe the TRD Rigid SRM versions are higher output.
    You can compare a lot of output data here, including the TRD Rigids in the original post:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    Aside from unique style, far higher performing options exist for less.
  4. Sep 8, 2021 at 8:11 PM
    Shawny5ive
    Shawn
    I have looked through your comparisons and that’s what got me thinking. I like the style of that stupid shroud haha, just wish it used a better performing light. I’ve thought about trying to fab a second light in that blank space above the fog
  5. Sep 8, 2021 at 8:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You could try and fab some higher performing Diode Dynamics SSC2s in there. But 2 sets of those will basically be equivalent as a plug and play SS3, and you can go even higher performing on the Max with the SS3 so you are limiting yourself and making it far more complex for cosmetic reasons. If going down that path, might as well abandon the TRD look and go for the functional performance and sell the TRD units to recoup most the cost.
  6. Sep 8, 2021 at 8:39 PM
    Shawny5ive
    Shawn
    Well said. Thank you
    crashnburn80 likes this.
