Trd pro Rigid to baja squadrons question?
Discussion in 'Lighting' started by Jonbark0404, Sep 14, 2019.
  1. Sep 14, 2019 at 9:26 AM
    Jonbark0404
    Jonbark0404 [OP] Well-Known Member
    Jon
    2019 Tacoma TRD Pro
    I searched the forums and haven’t been able to find any info on this, and apologize if it has been talk about before.
    With the pro having the Rigid fogs. Has anyone changed these out to Baja squadrons sae? Is there a noticeable difference in output? And how would I change the bezel from the rigid to accommodate the squadrons?
  2. Sep 14, 2019 at 9:33 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    The rigids should unbolt, leaving the hole where a non-pro housing or a Baja designs squadron kit should fit and bolt right up.
    The Baja designs will have 2 more led’s, and should be much brighter and possible a better spread of light as well.
  3. Sep 14, 2019 at 10:08 AM
    Jonbark0404
    Jon
    2019 Tacoma TRD Pro
    Thank you. I wasn’t sure if was an entirely different housing or not.
  4. Sep 14, 2019 at 8:24 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can compare the performance in this thread:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    The TRD Pro Rigid’s are not very impressive, you get substantially better output out of the Rigid SAE fog D-Series lights.
    12TRDTacoma and paranoid56 like this.
  5. Dec 2, 2019 at 3:18 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    Did you get around to installing these, had the same question regarding install and what’s under the oem rigid bezel?
  6. Dec 9, 2019 at 7:37 PM
    michael ray
    michael ray Member
    mike
    Katy,TX
    2017 TRD Pro
    Im about to make the swap this weekend but hoping i ordered the correct replacement bezels...
  7. Dec 9, 2019 at 8:38 PM
    ls7alex
    Newark
    Taco gang
    Which ones did you get?
  8. Dec 10, 2019 at 1:27 AM
    michael ray
    michael ray Member
    mike
    Katy,TX
    2017 TRD Pro
    ls7alex[QUOTED] likes this.
  9. Jan 16, 2021 at 1:37 PM
    PitCh0w
    PitCh0w Well-Known Member
    Derek
    Boston, MA
    2020 TRD Pro - Army Green
    I know this thread is a couple years old, but did anyone successfully swap out the trd pro Rigid for the squadrons?
  10. Jan 16, 2021 at 2:33 PM
    ianGP
    ianGP Active Member
    VA Beach
    2020 TRD Pro SW
    2002 Tacoma SR5 *RIP*
    crashnburn80 likes this.
  11. Jan 16, 2021 at 5:41 PM
    PitCh0w
    Derek
    Boston, MA
  12. Jan 16, 2021 at 8:25 PM
    ianGP
    ianGP Active Member
    VA Beach
    2020 TRD Pro SW
    Yes and yes. you’ll have to get the bezel that’s pictured on the 8th post on this thread since the rigid pros and BD fogs are entirely different shape. If you got the car specific kit from BD then yes, it’s plug and play as they include the necessary wiring harnesses, otherwise you’d need that to plug directly to the existing fog wiring.
