Trd pro shift knob disassembly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitetaco97, Feb 15, 2019.
  1. Feb 15, 2019 at 12:06 PM
    whitetaco97
    whitetaco97 [OP] Well-Known Member
    Tyger
    2017 White TRD sport
    5FB4B566-7F5E-48A0-BA98-53A08C4FFCB6.jpg Couldn’t find a write up on this but the Trd pro shifter can Infact be disassembled. Will be painting the pieces to match the truck
  2. Feb 15, 2019 at 1:14 PM
    Lazyninja27
    Lazyninja27 Nobody Cares. Work Harder.
    HTX
    Tacoma 2018 DCSB Off Road 4x4
    held together by clips?
  3. Feb 15, 2019 at 2:16 PM
    whitetaco97
    Tyger
    No clips at all. Just double sided tape all over
    DAS Taco likes this.
  4. Feb 15, 2019 at 4:07 PM
    ICU1
    ICU1 Well-Known Member
    GillyLink and Tacoknife like this.
  5. Feb 15, 2019 at 4:22 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    How did you get the shifter knob off? Does it pop off or unscrew?
  6. Feb 15, 2019 at 4:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    On the Manual the boot simply unhooks then you unscrew it, would assume the automatic is similar.
  7. Feb 15, 2019 at 4:58 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Unhooks? You pull it or pry it? I was wanting to customize my shift knob too!
  8. Feb 15, 2019 at 5:02 PM
    shakerhood
    Southern Ohio
    Simply rotates to unhook.
  9. Feb 15, 2019 at 5:11 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I assume counterclock wise?
  10. Feb 15, 2019 at 5:24 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    There is a plastic collar, that on the MT turns CC to disconnect the boot collar from the knob. I do believe AT is same. Then knob simply lefty loosey to remove
  11. Feb 15, 2019 at 5:25 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Awesome, thanks!
    TeecoTaco[QUOTED] likes this.
  12. Mar 16, 2019 at 11:25 AM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    On the AT, just need to push down on the chrome collar it will unclick and spin the knob counter-clockwise to remove. To install, do the opposite.
  13. Mar 16, 2019 at 1:44 PM
    Banker
    Banker Well-Known Member
    OHio
    2017 Sport TRD DCSB
    Bookmarked for later.
  14. Mar 7, 2021 at 7:07 PM
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    Anyone know how to get the TRD clip off? Planning on using someone’s product to put an LED behind it.
    Devious6 likes this.
  15. Feb 5, 2022 at 2:17 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Can someone explain how to remove the TRD clip? Been searching around and can't find it. I did a vinyl wrap on my shift knob but didn't think the TRD clip came off so I covered it in place. It doesn't look too bad but I'd prefer to wrap it than just cover it.
    SoCalTaco57 likes this.
