TRD PRO Skid plate is it worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean62, Mar 11, 2020.
  1. Mar 11, 2020 at 11:22 AM
    Dean62
    Dean62 [OP] Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    Im wondering is a TRD Pro Skid worth getting over an aftermarket one? They seem to be about the same price?
  2. Mar 11, 2020 at 11:34 AM
    heybronicetacoma
    heybronicetacoma Meat Popsicle
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    I like mine a lot buuuuutttt....
    If you're going to drop the cash and you really do plan to off road and hit it, get a steel one that goes further back and protects more bits. Steel slides easier but then again, it doesn't have as much corrosion resistance
  3. Mar 11, 2020 at 11:52 AM
    Dean62
    Jacob
    Florida Panhandle
    I'm just worried about weight with getting a steel one because its also going to be my daily driver. I'm looking to do mostly camping with it in the south east USA. The aesthetics are a plus but not whats most important to me. Id really like to keep the weight down and keep the corrosion resistance.
    So there aren't many aftermarket mid skid plates that work with the pro skid?
  4. Mar 11, 2020 at 11:57 AM
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Pretty sure the RCI Mid skid is compatible with the pro skid, and they do make an aluminum configuration.
  5. Mar 11, 2020 at 11:59 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    My trd skid came in handy at the rally took a little beating. Still looks nice. However Im not rock crawling or technical trail riding. Comes back to usage and for mine the trd is great.
    TacoMamba35 and GreyBaldTaco like this.
  6. Mar 11, 2020 at 12:00 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Pro skid is probably fine for you. If you like playing in the rocks at all, get steel. I have the pro skid and its all bent up. Replacing it with a full set of steel skids from SOS concepts.
    GreyBaldTaco likes this.
  7. Mar 11, 2020 at 12:05 PM
    Myles G
    Myles G Well-Known Member
    Myles
    IMO is the best looking skid sad mine was not compatible with my lift I had to take it off
    D.A.S. Taco and GreyBaldTaco like this.
  8. Mar 11, 2020 at 12:20 PM
    Dean62
    Jacob
    Florida Panhandle
    what lift do you have?
  9. Mar 11, 2020 at 12:30 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I love how mine looks. I also like to keep things OEM. Win win for me.
  10. Mar 11, 2020 at 12:36 PM
    Myles G
    Myles
    forbidden 4.5 RC cross member lift
    DonutsLoveUToo likes this.
  11. Mar 11, 2020 at 12:41 PM
    JG358
    JG358 Well-Known Member
    Jake
    Colorado
    16 Tacoma TRD OR DCSB
    I'd go steel aftermarket. Pro looks good but if you can get a nice thick steel skidplate for the same price or less.
    whatstcp likes this.
  12. Mar 11, 2020 at 12:44 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I went with RCI aluminum front and transmission. I’m almost positive the RCI transmission plate can slide the price under the TRD. They have little black bushing which add space.
    Taco_Craig likes this.
  13. Mar 11, 2020 at 3:59 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I like my TRD Pro skid plate. I bought mine, not so much for added protection (which is a nice positive), but to allow easier access to the oil filter.
  14. Mar 11, 2020 at 4:03 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I second this. Get it if you like the look. It’s not necessary for what you do, so if another looks cooler, get that one.
  15. Mar 11, 2020 at 5:39 PM
    Infidel1920
    Infidel1920 Well-Known Member
    Patrick
    Wurtsboro NY
    2016 Tacoma TRD Sport
    Door sill plate vinyls (Blazing Blue) Glovebox vinyl inserts (Blazing Blue) Super bright LED interior lights AC vent blazing Blue surrounds CNC Machined Grill (Blazing Blue letters) Tailgate Vinyls (Blazing Blue) Engine shroud Vinyls (Blazing Blue)
    Always depends on how you intend to use your truck
  16. Mar 12, 2020 at 4:42 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    It is, I have one on mine. Bolted right up to the stock skid plate.
  17. Mar 12, 2020 at 5:41 PM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Mines been bashed an now dented and I consider it light off roading. If I was serious about beating my truck off the pavement often, I would go steel and not care about MPG's.
  18. Apr 13, 2020 at 11:47 AM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    I’ve been researching this as well. I wish they still made one that didn’t have the red lettering. It might just be me but I feel like a poser driving an SR5 with anything that says TRD. But if it didn’t have the lettering, than maybe I won’t feel that as much.
    Does anyone know if the red would be able to be peeled off or removed easily?
    2wdSR52022 and FloridaCementTaco like this.
  19. Apr 13, 2020 at 11:50 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Perfect, thank you!!
  20. Apr 13, 2020 at 12:19 PM
    Trah
    Trah Licensed Class C Driver...
    San Diego
    2017 Barcelona Red TRD Sport ACLB
    stuff and things...
    smash it up until they fall out...i'm about 1/3 of the way there...
