TRD PRO Skid plate is it worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean62, Mar 11, 2020.
  1. Nov 18, 2021 at 5:09 AM
    #61
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    After doing a lot of searching online, I found the best price at Schaumburg Toyota. The price ended up being a combination of stacked discounts from the dealer and Toyota for black Friday.
    rastaban and rmreid20 like this.
  2. Nov 18, 2021 at 6:52 AM
    #62
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    TRD Pro is more than adequate for most people!, and save $$$ at the pump!
    D.A.S. Taco likes this.
  3. Nov 18, 2021 at 6:56 AM
    #63
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I sent an online message to the dealership in Illinois...let's see if they can make a great deal to a Delawarean like they did for you from Tennessee!
  4. Nov 18, 2021 at 11:32 AM
    #64
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Just to throw my .02 into the mix, I get some pretty gnarly rocks out here where I wheel in the desert. Started out with the TRD skid and ended up gouging it up real nice and ultimately cracking it. Switched to RCI full steel skids. Those aren't bomb proof either. I wound up denting in the oil access plate to the point where it was difficult to remove. Happily, RCI sells replacement panels.
    I sacrifice weight & mpg for better protection based on my needs.
    By the way if you see somebody with the TRD skid and the red letters still attached, good indication they don't take their rig offroad (or at least nothing serious). I lost those letters the first time I had it out.
    skiploder likes this.
  5. Nov 18, 2021 at 11:48 AM
    #65
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Love my TRD skid.
    DAS Taco likes this.
  6. Nov 18, 2021 at 12:42 PM
    #66
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Here is a size comparison for those who may be interested.
  7. Nov 18, 2021 at 8:19 PM
    #67
    maximum
    maximum Well-Known Member
    It's worth the eye candy.
    DAS Taco, 20AGTaco and VaToy like this.
  8. Nov 19, 2021 at 5:16 AM
    #68
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Beautiful "Eye Candy".
    I want to buy one...hopefully, I can find/catch a Black Friday sale.
  9. Nov 19, 2021 at 5:41 AM
    #69
    retrofive
    retrofive Well-Known Member
    Eye candy = good :D (I like the silver-ish PC on the silver truck looks)
  10. Nov 19, 2021 at 5:54 AM
    #70
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Finally able to see this photo.
    Fantastic!
    That looks like the skid plate currently on my '21 Sport.
  11. Nov 19, 2021 at 6:00 AM
    #71
    retrofive
    Why do I feel like I pulled off 2 separate sections of "skids" on my stock '21 OR when i put the Pro on?
  12. Nov 19, 2021 at 6:02 AM
    #72
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I believe the plate on an OR is different than a Sport.
    retrofive[QUOTED] likes this.
  13. Nov 19, 2021 at 6:03 AM
    #73
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
  14. Nov 19, 2021 at 6:07 AM
    #74
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    That's the correct Part Number: PTR6035190
    sporin[QUOTED] likes this.
  15. Nov 19, 2021 at 6:14 AM
    #75
    sporin
    Dave
    Vermont USA
    Thank you!
  16. Nov 19, 2021 at 7:01 AM
    #76
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    I put one on when the clowns at the dealership destroyed the nuts welded to the stub frame that holds the front of the flimsy ass
    sheetmetal on. The factory metal piece is actually referred to as splash guard, in the parts manual. Probably some of the better money to spend on a tacoma if your going to go off road.
  17. Nov 19, 2021 at 7:17 AM
    #77
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I got one a couple of weeks ago and really like it. Did mine to change the look of the truck away from the Sport "air dam" look, with the added benefit of more protection. My truck is a 4x2 and the most off-road I go is dirt and gravel so this is all I will ever need.
    Jerry311SD likes this.
  18. Nov 19, 2021 at 7:31 AM
    #78
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Oh, wow!
    So that's what it would look like without the "Air Dam"?
    I've read/seen YouTube video explaining the purpose of the Air Dam--because the Sport is tailored to street driving, the Air Dam forces air downward and keeps the front of the truck down. Apparently, it has been known to lift without some sort of mechanism keeping the front down.
    I've taken my Sport (with air dam on) to 90mphs and it felt just like my 2003 Honda Pilot when I reached over 120+ kphs on the Autobahn from 2003-06. (I was stationed at Ramstein AB for 3 years)
    Not likely, I will be making those speeds on the regular here in Delaware. I may just consider removing the Air Dam (but not disposing of it) too if/when I get a TRD Skid plate.
  19. Nov 19, 2021 at 7:36 AM
    #79
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I did a post and asked a question about stability before I removed mine and the consensus was no adverse effects even at highway speeds. One person complained of a bit more wind noise. A couple of people said they notice a slight difference in MPG without it but most said no. Based on that I went for it and I like the look a lot better. My air dam is still in the garage too just in case, but I don't think it will be going back on. Just FYI, if you want the skid plate the air dam has to go.
  20. Nov 19, 2021 at 8:49 AM
    #80
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Yeah, I figured that was the case.
    I'll keep mine on in the meantime...I just have to persuade my wife that this can be my Christmas Gift...& if I can get it reduced price for Black Friday, maybe it will soften the blow...but I think she will still be annoyed. lol
    Thanks for sharing the pic...really makes me want to go the route you did.
    FL_TRD Sport[QUOTED] likes this.
