TRD Pro Skid Plate w/ Lift - oops?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mustainefan, Apr 7, 2018.
  1. Apr 20, 2018 at 4:33 PM
    mustainefan
    mustainefan [OP] Well-Known Member
    Portland, OR
    2022 Tacoma TRD Off Road
    Icon Stage 2, 2015 TRD Pro Wheels, BFG KO2 285/75r16
    Yeah that dealership definitely does. And they said they would have fixed it if they had installed the lift. They even said they could tell it was a professional job. Pretty irritating, especially considering that these trucks are ALWAYS lifted!
    Rob Daman[QUOTED] likes this.
  2. Apr 20, 2018 at 7:16 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    You have to understand their position. Toyota will not warranty any modified vehicle. If the dealer is doing the lift they accepting that if you have an issue they will take care of it. If you go somewhere else and have the lift done why would you expect the dealership to help you out?
  3. Apr 20, 2018 at 8:04 PM
    mustainefan
    Portland, OR
    I totally understand the position, but my understanding is that this part fails in both lifted and unlifted vehicles, and probably borders on recall territory. That said, this is a situation where a faulty part is the issue, not damage from a lift. And in the case where it was professionally installed, and acknowledged as such, it’s an easy call in my opinion for a Toyota to make an exception. Honestly, how much do you think this would cost Toyota in aggregate? The bigger question is why don’t they correct this with new models if the TSB fix is an aftermarket piece??
    So really I don’t think it’s on the Dealership as much as it’s on Toyota to cover this. But again, this is very specific to a known issue with a part, and not some freak damage that Toyota has no control over.
  4. Apr 20, 2018 at 8:44 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    The part is more prone to failure on lifted truck and is actually very common. The part has failed on non lifted trucks but is not a common issue, unless poll TW members. For the average Tacoma owner (let's say 80%) that doesn't lift his truck, doesn't off road and runs stock tire size it just doesn't happen that often. Toyota has many TSBs that will never be recalls.
  5. Apr 20, 2018 at 8:47 PM
    mustainefan
    Portland, OR
    Which leads me to believe that the cost to fix would be well worth it to Toyota to strengthen customer experience. But still, why not fix it for good with new production?
  6. Apr 20, 2018 at 9:24 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Because it doesn't occur enough to make it worth their while (cost). They have other concerns that effect the mainstream Tacoma owners such as squeaky leaf spring and rear differential leaks that happen much more frequent so those issues will get addressed first.
  7. Apr 20, 2018 at 10:33 PM
    mustainefan
    Portland, OR
    Ha- I don’t think this is a decision based on priority. Seems pretty simple to me. Build new Tacoma, use different bearing. Problem solved. Maybe I’m missing something?
  8. Apr 20, 2018 at 10:41 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    It's not enough of a problem to warrant their attention.
  9. Apr 21, 2018 at 1:24 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Is your truck a 4x4?
  10. Apr 21, 2018 at 1:33 AM
    Halena Molokai
    I'm a firm believer that maintaining the stock rake is important even with a lift, geometrically speaking.I know some prefer a level look or even the bro look but keeping the rear 1" higher works for me. $.02
  11. Apr 21, 2018 at 6:24 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    A lot of people either do the ecgs and never have problems, people do it before they lift the truck (me), or install the ecgs during lift. Mine cost 150 to install from ecgs and other shops do it around 250+ range. Some toyota Dealerships even carry the the ecgs in stock.
    Toyota is an asshole for continuing to use this needle bearing but it's just how it is...next time in the future if you lift another vehicle ask the forums what problems can occur after a lift.
    But hey you got it done free so....lol
  12. Apr 21, 2018 at 6:31 AM
    mustainefan
    Portland, OR
    Yes it is.
  13. Apr 22, 2018 at 3:25 AM
    Halena Molokai
    Put it in 4wd and see if the symptoms go away or not.
  14. Apr 22, 2018 at 4:34 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Apparently they revised the bearing and made it wider for ‘15 MY on up but that obviously didn’t work. I can’t believe that they can’t redesign and use the same type of bearing that on the passenger side.
  15. Apr 22, 2018 at 7:04 AM
    #35
    mustainefan
    Portland, OR
    Yeah I did and it has already been confirmed and repaired. Thanks!
  16. Apr 22, 2018 at 7:23 AM
    #36
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sounds like Toyota has some ‘splainin to do, especially since the reason for their denial of your warranty work had to be provided to you as a valid explanation showing cause. Uncle FTC and Magnu-Moss isn’t going to like it if they continue to blame needle bearing failures by pointing their fingers at us and blaming our lifts. It isn’t going to look good in court if they are blaming lifts for the failure when Toyota dealers are also doing lifts.
    Its good You got the shop to fix it, but I wonder if this is a new Toyota trend for the rest of us?
  17. Apr 22, 2018 at 8:59 AM
    #37
    mustainefan
    Portland, OR
    I would love to see this sort of thing be corrected by Toyota. I am a loyal Toyota customer for many good reasons, and I would like to continue as such.
  18. Apr 22, 2018 at 10:14 AM
    #38
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Thats good business practice right there.
    :thumbsup::thumbsup:
    Also good on ya for talking with the shop in a cool calm manor.
