Trd pro Skid.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blueyeti, Dec 10, 2024.
  1. Dec 10, 2024 at 4:00 PM
    blueyeti
    blueyeti [OP] Well-Known Member
    Jesse
    2019 White Tacoma TRD Sport
    Quick question. If I order a trd pro front skid. Can I install it on my 2019 trd sport? Or do I not have spots to bolt it in?
  2. Dec 10, 2024 at 4:06 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    It will bolt right up
    shakerhood, BabyBilly and Chew like this.
  3. Dec 10, 2024 at 4:09 PM
    blueyeti
    Jesse
    Ok perfect. I thought I read that I need to order a cross bar or something since the off road has spots to bolt and the sport doesn’t
  4. Dec 10, 2024 at 4:55 PM
    Koolbreeze7
    Jon
    Jersey
    I bolted a 2nd Gen Pelfreybilt Aluminum skid to my 3rd Gen Sport
  5. Dec 10, 2024 at 4:56 PM
    World2405
    World2405 WUBBA LUBBA DUB DUB!!!!1!
    Delaware
    2023 Toyota 4Runner
    You could… but I mean there’s better options
  6. Dec 10, 2024 at 6:43 PM
    Taudelta
    Taudelta Well-Known Member
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Steelcraft Fortis front bumper, BodyArmor 4x4 rear bumper, LIft: Bilstein 5100+2885 OME coils, Icon RXT 3 stage. 255/85/16 wildpeak at4w
    yes. you will be able to install it.you will need help in case you don't have jack. it is easier if you have access to the list
    blueyeti[OP] likes this.
  7. Dec 10, 2024 at 8:00 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I can install a steel RCI by myself (40 lbs, TRD Pro is 20 lbs). I use the hard knee pads carpet installers use (Lowes, HomeDepot, etc) and balance the skid plate on those pads ... get first two bolts partway in, then the next two, then those hold it on enough to crawl under for the back two bolts and tighten all.
    blueyeti[QUOTED][OP] likes this.
  8. Dec 11, 2024 at 12:32 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    If you've got a floor jack, just balance it on that and slowly jack it into place. Super easy and very controllable. And read the directions as there are bolts you need to remove first.
    Taudelta, BabyBilly and Kolache007 like this.
  9. Dec 11, 2024 at 8:31 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    If you still have the front chin strap on that may interfere a bit but it is easily removed and should be removed by all. I installed a trd skid on my 18 sport originally without issue. But then found better options that weren't such a mud scoop.
  10. Dec 11, 2024 at 10:37 AM
    Sasquatchian
    If you drive a lot of highway miles at freeway speeds like I do, you may want to keep that chin spoiler as it does add stability and reduce noise at highway speed. If I were doing serious offroading I would remove it but most of mine is bouncing around the Alabama Hills in Lone Pine where it does not get in the way. The only thing I had to do was trim out the center with a dremel tool to make and fit around the TRD skid and then use some T-Rex tape to cover up the already partially covered holes to stop them from whistling.
