TRD Pro suspension coil spring lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hcenteno21, Feb 2, 2020.
  1. Feb 2, 2020 at 8:32 AM
    hcenteno21
    hcenteno21 [OP] Well-Known Member
    Tito
    El Paso, TX
    2020 AG Tacoma TRD Pro Supercharged
    I have been trying to research, but have not found an answer. I have a 2020 trd pro, and was wondering since you can put a 1.5" spacer for small lift on top of spring couldn't you fit a slightly bigger coil spring to achieve same? I am not ready to shell out a ton of $ on a whole new system, but would be open to the idea of replacing coils. Does anyone have any information on this? I know nothing about suspensions I apologize ahead of time if I sound like a fool!
  2. Feb 2, 2020 at 8:43 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    eibach is working on a longer front spring for the trd pro right now, though I think its for the 2016-19 models as the 2020 changed a little bit. (springs and perches changed). But they are more describing it as extra support for heavy bumpers.
    hcenteno21[OP] likes this.
  3. Feb 2, 2020 at 8:44 AM
    hcenteno21
    Tito
    El Paso, TX
    Thanks, I will keep an eye out!
  4. Feb 2, 2020 at 8:48 AM
    5nahalf
    Erik
    Minnesota
    Also something to keep in mind, you can get usually around $1200-$1500 for your stock trd pro suspension. So if you picked out a nice new suspension, a good chunk of it would be funded by your old suspension. Just make sure you get something that is the same or better than your current, but with the lift you want.
  5. Feb 2, 2020 at 8:51 AM
    hcenteno21
    Tito
    El Paso, TX
    I have been considering that, what would you recommend that would achieve a 2" lift? Can I just swap front, or would it be recommended to swap everything?
    I am trying to clear 285/70r17s I just installed JBA High Caster UCAs
  6. Feb 2, 2020 at 8:54 AM
    5nahalf
    Erik
    Minnesota
    im not a great source for lift info, but check out the suspension section and you will find lots of good info.
  7. Feb 2, 2020 at 9:05 AM
    Brent2014
    Brent2014 Well-Known Member
    Raleigh
    2020 DCSB TRD SPORT
    He’s correct. I’ve been keeping my eye out for a pro suspension in good shape.
  8. Feb 2, 2020 at 9:29 AM
    hcenteno21
    Tito
    El Paso, TX
    i have a 2020 trd pro 1,025 miles on my truck 0 offroad miles... if i do decide on something I will let you know
  9. Feb 2, 2020 at 9:30 AM
    Brent2014
    Raleigh
    2020 DCSB TRD SPORT
    Please do! Sounds good.
