TRD PRO Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CHMM, Aug 12, 2016.
  1. Aug 12, 2016 at 8:05 AM
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Has anyone added UCAs with TRD Pro suspension and noticed a difference? I know technically you don't need em. But curious as to if anyone has done it and what the results were.
  2. Aug 12, 2016 at 8:10 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    probably couldnt hurt! I know SPC uca's helped a bunch with my 5100's and the 6112's (aka trd pro front shocks) have very similar extended and collapsed lengths.
  3. Aug 12, 2016 at 8:12 AM
    CHMM
    CHMM [OP] GTO
    Gabe
    So you put on the light racing UCAs? And the truck drive a little more under you at speeds?
  4. Aug 12, 2016 at 9:47 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Go for it. It will not change your normal driving experience in any noticeable way, outside of the placebo effect where your brain will tell you it "feels better" but you "can't really describe it" because you "spent a ton of money" on "something you didn't need"
    It is your truck, I burn plenty of cash on silly shit for mine... so I can't really be a dick about any of this without admitting this.
  5. Aug 12, 2016 at 9:51 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I recall reading TRD engineers said the addition of aftermarket UCAs can give the Pro suspension 1" more travel, as the stock UCA is currently the limiting factor. Won't have any noticeable effect on daily driving, assuming you haven't added top plates or other mods to increase the lift.
  6. Aug 12, 2016 at 9:57 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    I have a TRD Pro suspension on my truck, and have driven it in a lot of different situations on and off road, although I'm a pretty conservative driver off road. When I get in the back country I like to take my time and enjoy the nature. I can't see where a non stock UCA would make any difference whatsoever the way I drive. The alignment is to specs, and it drives as well off road as at high speed.
