Trd pro suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guamtaco6, Apr 5, 2017.
  1. Apr 6, 2017 at 8:59 AM
    #61
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    So you admit you have a dream world.
  2. Apr 6, 2017 at 9:03 AM
    #62
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    So how is ground clearance measured? From the ground to what part of the truck?
  3. Apr 6, 2017 at 9:20 AM
    #63
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    The rear diff is lowest of course, but the reality is the tacoma has a wheel base of some 127inches give or take.
    The highest point of the truck is the antenna, which sits closer to the rear wheels than it does the front.
    If the front end is raised 1inch it will not mean that the whole truck body will rise equally.
    Or in the simplest example when you lift the handles of a wheel barrow you aren't actually lifting the dirt the same amount as the handles.
    Therefore toyota slapping an extra inch on top dimensions above the rest is pretty shady.
  4. Apr 6, 2017 at 9:26 AM
    #64
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    My $2k for the suspension remark was for all the suspension differences between Pro and OR. Shocks alone I wouldn't expect to be more than $150 each for the rear and maybe $200 for the front. That's going by the current Fox 2.0 and 2.5 pricing. Then you have custom valving ontop if Fox don't sell their generic shock with this valving.
  5. Apr 6, 2017 at 9:33 AM
    #65
    mutely
    If all cars are build equally I agree, but they are not. I can assure you that the bottom lip of the plastic wheel arch on my front fender is not in the identical position to yours in relation to the exact same spot on the frame. Also guessing at the center of the wheel is not accurate at all between people, I would be 1/4 out from you, and when measuring an inch or so difference, that's a lot.
    The only true measurement between different vehicles (assuming wheels / tires are the same) would be a similar spot on the frame against the ground (assuming level / flat ground).
    poopshute likes this.
  6. Apr 6, 2017 at 9:43 AM
    #66
    mutely
    It's a "law suit" thing I'm sure. I agree the height of the Pro is not 1" higher as it's only the front that gets a lift (to my knoladge). But if the highest point on the Tacoma is 70.6" and they know they added 1" to the front suspension, the "safest" thing to state is 71.6 on the pro. A complete assumption here and based on no facts from Toyota, but coming up with the 70.6" number probably cost a LOT of money, and going through that expense again wasn't worth it, so they added 1" to be safe.
    Everyone's suspension will settle differently as it depends on so many variables, I'm sure you could pick two 100% stock OR with exact same mileage and they would have a least 1" maybe even 2" difference in height.
    rlx02 and poopshute like this.
  7. Apr 6, 2017 at 10:32 AM
    #67
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    NO!. Same argument I had with the dealer rep when I got my PRO about 1" higher BS. We compared 5 Tacos in the lot of different models and ALL had the same height. Measured from the ground to fender plastic flare bottom.
