TRD PRO Suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by V2009, Sep 16, 2022.
  1. Sep 16, 2022 at 3:41 PM
    V2009
    V2009 [OP] Well-Known Member
    Looking to install TRD PRO suspension on my 2020 Sport DCLB.
    Anyone did similar install on 2020 DCLB? Have part numbers that you used?
  2. Sep 16, 2022 at 4:04 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Take off aka used FOX rear shocks and front coilovers?
  3. Sep 16, 2022 at 7:42 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    All tacoma pro suspensions fit all tacomas. Doesnt matter the year. I have 2017 pro suspension on my 2018. So If I were you I would just find the newest lowest mile pro suspension you can and just put it on.
    There were some minor changes to the suspension between 2017 to now
    They changed the springs from a flat ground spring to a full coil in 2020 and revalved them a bit. In 2022 they changed the spring to give additional lift over the other years. From what I have found, the best version is the 2017-2019 with the flat ground springs. The newer full coil (top of the springs are not flat ground) suffer from a issue where the spring puts too much pressure on a single spot on the top hat, this results in the tops not centering the shaft and can wear out the bushings and damage the shaft. This design flaw was found when eibach made aftermarket springs for the pro suspension.
    RTweet, V2009[OP] and na8rboy like this.
  4. Sep 16, 2022 at 8:02 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You want to find take off. Buying new from dealer, would make your ass pucker$$$...
    RIX TUX likes this.
  5. Sep 16, 2022 at 8:04 PM
    na8rboy
    WI
    2nd gen pro suspension on 18
    V2009[OP] likes this.
  6. Sep 16, 2022 at 11:52 PM
    V2009
    How about those ones? https://trdshop.carlocktoyotaoftupelo.com/p-trd-pro-suspension-fox-shocks-tacoma-2016-ptr6135170x
    or can you please give me part number so I can hunt them down?
  7. Sep 16, 2022 at 11:54 PM
    V2009
    Looks great ! Do you know the part number?
  8. Sep 16, 2022 at 11:58 PM
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Does that mean Toyota fixed it?
  9. Sep 17, 2022 at 3:42 AM
    na8rboy
    WI
    They are not available anymore. Same as 6112/5160
    eurowner likes this.
  10. Sep 17, 2022 at 6:45 AM
    5nahalf
    Erik
    Minnesota
    No toyota has not fixed it because they dont really know about it being a issue. It only popped up as a issue when we increased the spring length thus increasing the force on that one spot of the strut top. On the stock pro suspension its going to end up being a long time out issue, but when you put in a eibach lift it makes the design flaw worse. Eibach is working on their own fix for the issue though.
  11. Sep 17, 2022 at 2:22 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Maybe I'm trippin , but your truck would look awesome as a duelly! Like the LB. The picture makes you look shoe horned in that garage. OTH, jealous of garage.
    Nice truck!
