TRD Pro & TX Baja OFFICIAL Thread...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UrbanWarrior, Jan 21, 2015.
  1. Feb 15, 2018 at 7:00 AM
    #3701
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    No no.....just speaking hypothetical. Still love it too much.
    Coot83[QUOTED] likes this.
  2. Feb 15, 2018 at 7:15 AM
    #3702
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Haha you tease!
  3. Feb 15, 2018 at 8:18 AM
    #3703
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
  4. Feb 15, 2018 at 8:24 AM
    #3704
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
  5. Feb 15, 2018 at 11:04 AM
    #3705
    RyanL
    Indiana
    BVita, Mr.Franko and Coot83 like this.
  6. Feb 15, 2018 at 4:46 PM
    #3706
    Nick_Taco
    Nick_Taco Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    Just ordered a TRD Pro suspension kit for my 2014 OR. I've been here long enough I know how to use the search function but have read some contradictory comments and would like to try and clear some things up for myself.
    I'm thinking of putting in the ToyTec 1/2" top plate space instead of the ToyTec spring spacer as I've read the spring spacer is essentially pre loading the springs and I'd like to not compromise the ride in any way. Are the studs long enough to accept this? I've read the studs are only long enough for the 1/4 spacer. Will I have a good chance of getting my alignment in spec with that much lift or will I need after market UCA's?
    I'm thinking of going with a 1.5" progressive AAL with overload left in which will net a 2" rear lift. Some say you can pull this off, some say the shocks aren't meant for this length and can only handle a one inch lift. How's the ride with the overload left in?
    Anyone with pics of this setup or similar would be greatly appreciated!
    Dave41079 likes this.
  7. Feb 15, 2018 at 4:54 PM
    #3707
    doorsidedown
    doorsidedown Well-Known Member
    If you got the pro kit and not the Baja kit, adding the coil seat spacer is probably a better option. It’s designed to work with that specific shock and it won’t preload it too much. Basically, it’d be like running the 650 pound springs vs the 600. you might need a UCA adding an extra inch of lift, but my guess is a good alignment shop will be able to get you close enough. If you experience any bump steer after the alignment, go ahead and get them. Just my .02
    Nick_Taco likes this.
  8. Feb 15, 2018 at 5:12 PM
    #3708
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I did the top plate 1/4”....it works. Rear shocks should be fine with the overload.
    RyanL and doorsidedown like this.
  9. Feb 15, 2018 at 5:23 PM
    #3709
    Nick_Taco
    Nick
    Maryland
    Thanks. Think there is enough space in the studs for a 1/2"?
  10. Feb 15, 2018 at 5:29 PM
    #3710
    BVita
    BVita Mall Cruiser
    RyanL[QUOTED] and Coot83 like this.
  11. Feb 15, 2018 at 5:52 PM
    #3711
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    Weathertechs Tint Led Interior Method NV TRD Pro Bilstein Suspension Icon AAL CaliRaised sliders
    On the Pro kit did anyone switch out the front bump stops to the shorter?
  12. Feb 15, 2018 at 6:02 PM
    #3712
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I believe it does, another member put them on if I’m not mistaken @Dave41079
    Nick_Taco[QUOTED] and Dave41079 like this.
  13. Feb 15, 2018 at 6:58 PM
    #3713
    Dave41079
    Dave...
    Nashville, TN
    You have to replace the studs, which is really easy. I did have to add UCAs, but that could have been the tech doing the alignment as much as the parts.
    I also have Dakars with the extra leaf and an overload removed in the rear with my Pro shocks and they're fine. I could use more down travel, but no complaints. I ran the progressive AAL's for a while too, but needed more load capacity.
  14. Feb 15, 2018 at 7:05 PM
    #3714
    Nick_Taco
    Nick
    Maryland
    Love your build man. What studs did you end up using?
  15. Feb 15, 2018 at 7:20 PM
    #3715
    Dave41079
    Dave...
    Nashville, TN
    Thanks. Toytec has extended studs just for that application, but I don't remember if they're included with the 1/2" top plate or not.
  16. Feb 16, 2018 at 4:58 AM
    #3716
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    Dave41079 and RyanL[QUOTED] like this.
  17. Feb 16, 2018 at 7:53 AM
    #3717
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    Looking at the specs for 5160's, I think it should be fine, but can anyone confirm the stock bump stops and brake lines are fine with Dakar/OME leafs? Preferably from someone who's truck has seen a bunch of articulation.
  18. Feb 16, 2018 at 7:59 AM
    #3718
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    RyanL[QUOTED] and JuanitoBonito like this.
  19. Feb 16, 2018 at 11:15 AM
    #3719
    99GC8
    99GC8 Well-Known Member
    Dwight
    Fort Collins
    2015 Taco supreme
    Stock length shock i assume?
  20. Feb 16, 2018 at 11:24 AM
    #3720
    Taco TRQ
    TuRDTaco
    Not just stock length, the actual factory Baja or Pro shock.
