TRD Pro vs TRD Offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ghat, Jan 7, 2022.
  1. Jan 7, 2022 at 6:07 PM
    ghat
    ghat [OP] Member
    Ghatothkach
    TBD / TRD Pro Offroad
    noob here,
    my next car is a tacoma...
    I know what the TRD-Pro specs are, but is the TRD-Pro lifted like the TRD-Offroad, or its a version of the TRD Sport ?
    I hate the Toyota-Entune system, have tried to fix phone sync problems for various friends, and also myself using rentals, it truly horrible. I want to swap the head-unit out to a third party Pioneer/Sony, not sure if it will be fully compatible with a TRD-Pro/Offroad.
    G
  2. Jan 7, 2022 at 7:13 PM
    dhughins
    dhughins Well-Known Member
    Dave
    Skipperville AL
    2016 SR5 DCSB V6
    This is easy. If you have the money buy the Pro. The Off road is not lifted. It is a different option than the sport. I just upgraded from a 2016 SR5 to a 2022 Off road. The ride is great. If you want the best, baddest, coolest, that would be the Pro.
    No idea about the audio difference.
    markgphoto, CorsoTaco and eurowner like this.
  3. Jan 7, 2022 at 7:19 PM
    gemiv19
    gemiv19 Well-Known Member
    Ted
    Central Point OR
    2024 DCLB TRD OR Blue Crush
    Totally Stock for now
    Depends on your plans with the truck. Plan heavily modding it, lift and wheels. Stay with the OR. Gonna leave it stock and can afford it go pro. I myself went with an OR. I knew I was going to lift it and you can't get a longbed in a Pro configuration.
    SSTT0816, Kyebasse, anthop and 2 others like this.
  4. Jan 7, 2022 at 7:20 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Save yourself some money get the off road . Get better suspension be money ahead
  5. Jan 7, 2022 at 7:20 PM
    shotgunbilly420
    Same here
  6. Jan 7, 2022 at 7:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If you want a DCLB you can’t get it in the Pro.
    WELLSPRING and gemiv19 like this.
  7. Jan 7, 2022 at 7:23 PM
    schwartzki
    schwartzki Well-Known Member
    Midwest
    2020 Voodoo Tacoma TRD OR DCSB Prem/Tech/LED
    TRD Pro wheels, suspension & grill. KO2's, Front Window tint, Truxedo X15 Pro
    As far as the audio upgrade look at OEM Audio Plus.
    shotgunbilly420 likes this.
  8. Jan 7, 2022 at 7:25 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Have the 21 Pro. They say it is lifted but feels
    same height as Trd off road and sport.
    Pro comes with 2 year nav and xm.
    Go with what they have in stock.
  9. Jan 7, 2022 at 7:47 PM
    shotgunbilly420
    I second that I got their speaker kit for my tacoma . Then added a joying hu and my own sub and amp .
  10. Jan 7, 2022 at 7:51 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    My off road handles the walmart parking lot very well.
  11. Jan 7, 2022 at 8:03 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    TRD pro is just a trd offroad with a few changes.
    Upgraded suspension - offroad has bilsteins, pro has fox shocks. Pro sits 1 inch higher in the front
    Skid plates - offroad has thin steel ones, pro has thicker aluminum skids.
    The rest of the stuff is cosmetic... headlights, taillights, hood scoop, leather seats, different wheels.
    Really the main selling point for offroading is the rear diff on both the pro and the offroad. Its larger than other models, and also comes as a factory locker. They both have multi terrain and crawl control.
    So if you are planning to change the suspension anyways, and put on aftermarket skids, then start with the offroad. You can add other pro parts anytime you want to make it a clone for much cheaper than it actually costs to buy one.
  12. Jan 7, 2022 at 8:20 PM
    schwartzki
    Midwest
    I agree, I went with the Offroad. Threw on TRD Pro suspension, front spacer, rear AAL, RCI alu skids and sliders and I got my Off road pre-covid so it was 10k cheaper then the Pro.
  13. Jan 8, 2022 at 10:01 AM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    SNAHALF - above makes an excellent point… and if you are planning to lift your truck…the TRD Off road will be cheaper…I agree here..
    Yes the PRO ,name puts you into a different class..( up-grades)…
    All stereos speakers can be replace with many aftermarket Audio companies…enhancing the listening experiences…making it way better then stock speakers..
    Want the TOP of line Tacoma buy the PRO…especially if you are going to remain stock…Yes there are some excellent lift kits for the PRO keeping many of the components…and still consider a PRO model..
    Enjoy…. hope you get what you want…
    Aloha
    5nahalf likes this.
  14. Jan 8, 2022 at 10:29 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Had a 2017 OR and it was awsome. This time around ordered a 2022 Pro. Just like the look of it stock and won't touch the suspension. Just better tires and that's it.
    In Canada you can't get LB OR so both trucks have to be SB, so that made the choice to go Pro easier.
    Can't go wrong with either, one other thing to keep in mind is that OR is a lot easier to buy right now. Pro is a 5+ month wait.
    DingleTower and DavesTaco68 like this.
  15. Jan 8, 2022 at 10:32 AM
    5nahalf
    Erik
    Minnesota
    I wanted a pro, but I needed a long bed and wanted inferno. My only option was to make my own pro out of a offroad.
    shotgunbilly420 and shakerhood like this.
  16. Jan 8, 2022 at 10:59 AM
    Carlosky1
    Carlosky1 Well-Known Member
    2018 Wht Tacoma TRD
    Actively modding
    True to a point.... I have a TRD sport with the larger rear diff, 8.75", since I have a manual transmission.... And only autos have multi terrain and crawl control. Manuals don't come with those toys. And like you said, everything else is cosmetic...
  17. Jan 8, 2022 at 11:53 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    MT OR and Pro get A-TRAC in place of that.
  18. Jan 8, 2022 at 12:10 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    The manual OR and Pro get A-TRAC and rear locker.
    Edit: @shakerhood beat me to it.
    shakerhood likes this.
  19. Jan 8, 2022 at 12:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you are going to mod get the offroad. If you just want a plush stock truck get the PRO. If you are going to be a hell bent modder get a previously owned SR5 and rip it apart.
  20. Jan 8, 2022 at 12:37 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Tacoma Trail Special edition
    Although it costs more than the OR, isn't available with Crawl Control, optional LED headlights, and does not have fog lights. The trail does have a rear locker, a TRD Pro style grill, and TRD Pro wheels in bronze. The truck is also lifted.
    What ever you decide to buy. You can turn it into a Pro by adding the TRD Pro letters, for the new embossed bedsides found on the 22 Pro.
