TRD PRO vs TRD OR Gas Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, Aug 20, 2022.
  1. Aug 20, 2022 at 8:48 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    So, I just ordered the 2022 TRD PRO.. and now realizing the mileage must be awful compared to the OR given the extra lift. Anyone know how bad it is?
  2. Aug 20, 2022 at 8:50 PM
    Bishop84
    Bishop84 Well-Known Member
    Negligible.
    You are right though, lift = drag.
    But you will have one of the coolest trucks out there, so screw the mileage, enjoy the truck when it gets to you.
  3. Aug 20, 2022 at 8:55 PM
    TacoRancher
    Houston
    I need this energy right now.
    skeletron likes this.
  4. Aug 20, 2022 at 8:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You'll end up with larger tires, regardless of model which will affect gas mileage anyway.
    Everyone knows BIGGER TIRES MORE BETTER
    SoonToBeOn39s likes this.
  5. Aug 20, 2022 at 8:56 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Lift barely ever makes a difference in real world for mpg. It’s the tires and added weight that kills mpg with vehicles. The 1” larger stock tires might hurt it a small bit. They all suck in the mpg department though so I wouldn’t worry about it either way.
    33yrsoftoys and TacoRancher[OP] like this.
  6. Aug 20, 2022 at 8:58 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    The E rated tires did worse to my mpg than the lift ever did.. You'll be fine OP, just send it
  7. Aug 20, 2022 at 8:58 PM
    TacoRancher
    Houston
    All of you are correct. And I didn’t get the PRO for practicality. I got it to be a jackass and have fun.
    skeletron, GarrettTacoma and 530Taco like this.
  8. Aug 20, 2022 at 8:59 PM
    530Taco
    Adam
    Old Hangtown, CA
    :cheers:
    71tattooguy likes this.
  9. Aug 21, 2022 at 3:07 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Toyota's website lists the base OR at 19/24 MPG and the Pro at 17/21 MPG. I average a little higher than the stated MPG on my 2020 Pro and I don't baby the accelerator.
    Bottom line - you are getting an awesome truck, IMHO. Enjoy it!!
    ArchedRegant likes this.
  10. Aug 21, 2022 at 6:53 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    FWIW, I installed a 1in front and rear lift on my OR while currently running the 265/70/16. No change in mpg at all. Now like others have said, I will be getting 265/75 tires soon so that will probably have a small impact on mpg
  11. Aug 21, 2022 at 7:18 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They both get pretty bad fuel economy for their size and engine performance. Don’t worry about it and just drive the thing and enjoy it.
    TRD75 and TacoRancher[OP] like this.
  12. Aug 21, 2022 at 7:57 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 19/24 OR was probably for 2 wheel drive compared to 4x4 for the Pro.
    Chew, grogie and GarrettTacoma like this.
  13. Aug 21, 2022 at 8:00 AM
    TacoRancher
    Houston
    Where does it say this on the website? The official stickers I think show the same mileage as the OR..?
    JustJon likes this.
  14. Aug 21, 2022 at 8:05 AM
    TacoRancher
    Houston
  15. Aug 21, 2022 at 8:06 AM
    shakerhood
    Southern Ohio
    Yeah l think the Pro and OR have the same MPG when comparing the same configurations.
    33yrsoftoys likes this.
  16. Aug 21, 2022 at 8:15 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Could you be looking at the TRD offroad 4x2? They do make that truck, mostly for the southern states.
    Chew likes this.
  17. Aug 21, 2022 at 8:16 AM
    TacoRancher
    Houston
    I totally am and you’re totally right!
  18. Aug 21, 2022 at 8:16 AM
    33yrsoftoys
    joel
    mid Michigan
    :thumbsup:
  19. Aug 21, 2022 at 8:24 AM
    jneutron
    jneutron Well-Known Member
    Colorado
    2022 ORDCSB Cemint RIP-15 DCSB TRD MGM
  20. Aug 21, 2022 at 8:31 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    265/75-16 is what I run. They are about 1" taller than the stock 265/70-16s. Your too-fast speedometer will now read correctly with the taller tires but your accurate odometer will read about 4% less with the taller tires. Too calculate the true gas mileage, add 4% to the odometer reading.
