TRD Pro wheel replacement question...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lancelotless, Jan 8, 2018.
  1. Jan 8, 2018 at 7:56 AM
    Lancelotless
    Lancelotless [OP] Well-Known Member
    Louisiana
    2018 Toyota Tacoma TRD Off-Road Cement
  2. Jan 8, 2018 at 8:29 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    There r threads that r exactly what u r looking for I’m sure. C if u can find the thread addressing the wheels and maybe pm someone that has them and ask. That would probably b the easiest and most accurate advice. That way someone who actually has them can attest. I’ve seen at least a couple of threads specific to these wheels. Best of luck.
  3. Jan 8, 2018 at 8:35 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I went from 16's to 17's and it's totally fine. The Sport uses a 17 inch wheel as well.
  4. Jan 8, 2018 at 5:38 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If the 17" rim and tire are heavier than the 16" rim and tire, the vehicle will drive differently in a negative way.
  5. Jan 8, 2018 at 5:53 PM
    Sarhog
    Sarhog Well-Known Member
    Greer, SC
    2017 Tacoma Sport Rally
    Very enlightening! Would it also be safe to say.....
    If the 17" rim and tire are lighter than the 16" rim and tire, the vehicle will drive differently in a positive way?
    Thanks for the tip! :boink:
  6. Jan 8, 2018 at 5:56 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Seems to handle better and KO2's I upgraded to grip fantastically in the snow.
  7. Jan 8, 2018 at 5:57 PM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    my experience was very different. (285/75/16 at 38 PSI---maybe you were aired down?)
  8. Jan 8, 2018 at 5:59 PM
    2016Tacoman
    J
    No I don't run that high. 265's running at 34 psi C load.
    285's I'm sure you do.
  9. Jan 8, 2018 at 6:20 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Rough estimate is 10lbs of rotational weight is equal to 100lb on the chassis. Less rotation weight for accelleration and braking, and less suspended weight makes the vehicle drive "lighter".
