TRD Pro Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by unavailableTaco, Aug 22, 2018.
  1. Aug 22, 2018 at 12:44 PM
    tac0turd
    tac0turd Active Member
    Mighty Max
    Colorado
    2017 BRed Taco TRD OR
    Sliders by Ryan Ahls
    Lt. Dangle and SuperBad like this.
  2. Aug 22, 2018 at 12:45 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I was just curious which ones you meant. There are tons of people running 4R pro wheels on the Tacoma, its a very popular choice and 95% of the time someone says Pro wheel they are talking about the 4runner ones. Have you joined in on the DFW thread? Come over and say hi!
  3. Aug 22, 2018 at 1:39 PM
    Elk_Addict
    Elk_Addict Active Member
    Very Common. I opted for the 4 Runner wheels. Since they came out i have always liked the matte. They provide a perfect offset and stance for my need.
  4. Aug 22, 2018 at 2:35 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    20180815_175307.jpg Hopefully this pic will work for you
  5. Aug 22, 2018 at 4:20 PM
    Tivalleyok
    Tivalleyok Active Member
    SE Oklahoma
    2018 White TRD Off-Road
    Toyo Open Country AT 2. The RTs are very nice too.
  6. Aug 22, 2018 at 5:24 PM
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Pro wheels with KO2s. The Falkens look sweet too
  7. Aug 22, 2018 at 7:02 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    They never made the KO2 until 2014. The original KO came out around 1980, so maybe you mean those, but they are different tires.
    I and many others have had issues with blowouts with KOs on heavy 1 ton off-road vehicles, but still under the weight limits of the tire, so I stopped used them, but the KO2 are 10x better IMO. But you are right, most tire issues are blown out of proportion, just look at the ford / firestone crap.
    tacodnr likes this.
  8. Aug 22, 2018 at 7:11 PM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Tacoma Sport wheels are 17" I believe, but the Tacoma TRD Pro has 16". I thought the reason people went with the 4Runner TRD Pro wheels is because they are 17" like on the Sport so they look the same size wise. Also you can then do a direct tire swap and not have to buy a whole new set of rubber on top of the cost.
  9. Aug 22, 2018 at 8:36 PM
    unavailableTaco
    unavailableTaco [OP] Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    Very Nice.
    Foozer[QUOTED] likes this.
  10. Aug 22, 2018 at 8:37 PM
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    The Pro 16 inch has more tire options that is one reason I was looking at them
    shakerhood likes this.
  11. Aug 22, 2018 at 8:42 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Aren’t those similar to the stock OR tires? If so, I wasn’t impressed. The carcass is pretty flimsy.
  12. Aug 22, 2018 at 8:43 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I'd argue that the 4runner pro wheel is the more frequently done pro wheel swap. I was wondering which pro wheel we were talking about too.
  13. Aug 22, 2018 at 8:46 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    These are my dad's tires from 1983. They say "BFGoodrich Radial All-Terrain T/A" on the sidewall.
    Taco_Guero18 likes this.
  14. Aug 22, 2018 at 9:20 PM
    Lt. Dangle
    Ohio
    Nice.
    ALI3N_123[QUOTED] likes this.
  15. Aug 22, 2018 at 9:26 PM
    #35
    ALI3N_123
    Eric
    Austin, Texas
    Thanks.
    Lt. Dangle[QUOTED] likes this.
  16. Aug 22, 2018 at 10:26 PM
    #36
    Elk_Addict
    Ha yes sorry. That is what I meant by ATs. The original KO on the older two and the KO2s when they came out for the 07 and both since. While the tires are different, the BFG AT line has held very well for me. Long tread life, great in snow and mud, dry road and wet road alike.
    Now the toyo open country at2’s that came on my ram were abosoulte shit in snow imo. After the first two storms I went straight to the tire shop for the KO2s again.
  17. Aug 25, 2018 at 4:23 PM
    #37
    Solenya
    Solenya Well-Known Member
    Southern California
    2018 SSM Tacoma TRD Sport 4x4 DCSB (TOTALED OCT 2023)
    Looking for a set. If anybody has a set of 16” Tacoma Pro wheels for sale in Southern California, let me know!
  18. Aug 25, 2018 at 6:21 PM
    #38
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    For the record the Taco Pro wheels and the 4runner Pro wheels are NOT the same spec as someone stated earlier.
    Taco Pro - 16x7 +13mm offset
    T4R Pro - 17x -4 offset (will give you a bit wider stance)
    Here are mine with 285 KO2’s.
    I also have falken 265/75 sl rated on my OR wheels. They’re both great tires can’t go wrong with neither one they’re both quiet on the road. Falkens are def cheaper be still good quality. I also have Falkens on 4runner Pro wheels and they look awesome.
  19. Aug 25, 2018 at 7:41 PM
    #39
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Don’t rule out ST Maxx’s
    285/75/16’s:
    Acetigg likes this.
  20. Aug 25, 2018 at 7:59 PM
    #40
    itsdug
    itsdug Well-Known Member
    Doug
    Fentress County
    2018 DCSB 4x4
    I went with the Cooper Discoverer AT3.
    El Latigo and shakerhood like this.
