TRD Quick Shift Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fatsac, Jan 7, 2011.
  1. Jan 7, 2011 at 7:08 PM
    fatsac
    fatsac [OP] Well-Known Member
    Millbury, MA
    07 Tacoma DC Offroad
    Katz Leather, heated seats, Tint, KN Filter, OME 887, Camburg UCA, Dakar packs, 17x9 XD, 295/70 Toyo MT w cab mount chop, fender massage, Weathertechs, Black PC steps, skidplate, 2012 grill, Bushwacker painted flares, Nearly every TSB you can think of, TRD quickshift, All-Pro front w/ Skids, 9k winch, Tonneau cover, voodoo tailgate cap...
    While performing the new TSB on my clutch today, they installed the TRD kit.
    First off, I love the difference between gears. My only concern is the shifter is too far away now. 2nd, 4th, and 6th are just about center in the shift boot while 1st, 3rd, and 5th are close enough to the climate controls, my fingers touch if not paying attention.
    Is this normal? I could probably get use to it but definitely not what I was expecting. Can it be adjusted?
  2. Jan 8, 2011 at 7:07 AM
    fatsac
    Millbury, MA
    Buehler?
  3. Jan 8, 2011 at 7:13 AM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Sorry no experience with the TRD shifter... A bunch of us have the URD kit & the only complaint about that is initially getting it into reverse is difficult.
    too close to the climate control? - can't help you there.:eek:
  4. Jan 8, 2011 at 9:39 AM
    fatsac
    Millbury, MA
    My neighbor works at our local dealer and was able to get it on the cheap. Crisp, short shifts without any issue getting in gear.
    I'll get use to it but it's almost like my arm's too short and fingers to fat!
    Maybe I could pull it out and bend the arm back?
  5. Jan 8, 2011 at 10:55 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I don't think that they installed something correctly. My TRD quick shift is properly centered when in N, and it doesn't even come close to hitting the climate controls when in 1st, 3rd, or 5th.
    You said they did the clutch TSB; did they pull the transmission? Or was it the squeaky pedal TSB? If they pulled the transmission, I'd be concerned that they didn't line up the transmission correctly, although its hard to do that.
  6. Jan 8, 2011 at 11:25 AM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    Mine's centered too. Sounds like they have the assembly plate mis-oriented 180 degrees out but there are locating pins to prevent this. If the plate isn't located on the pins then there is a good chance it's leaking oil too. Hope the rest of the work is of a higher standard! If it is installed wrong it's most likely damaged. I'd want a new one!
  7. Jan 8, 2011 at 12:25 PM
    fatsac
    Millbury, MA
    When in 1, 3 or 5th, i have about a fingers width between the boot and console edge. Is that right??
  8. Jan 8, 2011 at 4:34 PM
    fatsac
    Millbury, MA
    Took it apart and all looks correct. Unless they changed something, the angle just shifts everything forward quite a bit. I'll get use to it!
