TRD "Quick Shifter" installed. Ahhhhh...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by newfieDan, Apr 4, 2013.
  1. Jul 8, 2013 at 4:30 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    this is in my mods list!
  2. Jul 8, 2013 at 8:43 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    mine too...wish i could find a used one, lol
  3. Jul 8, 2013 at 8:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Amazing difference with URD one....look in FS section, someone has one for 60.00......nevermind, dude had 2 threads for same SS, one for 75.00 and then made another for 60.00 but it says sold and it was for 5 spd, sorry.
  4. Jul 8, 2013 at 1:16 PM
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    2013 TRD OR DC 6 spd.
    3" Toytec Ultimate lift, Light Racing UCAs.
    I have a TRD SS too, it made a world of difference! Not really any additional shifting effort required for gears 1-6 but reverse is a bit more of a struggle. Take the first 1.5" of play out of the clutch pedal too and the entire driving experience goes up a few notches! :thumbsup:
  5. Jul 8, 2013 at 1:29 PM
    ReddingtonTRD
    ReddingtonTRD Well-Known Member
    Sean
    Orange County
    2024 Tacoma TRD Pro, white/black
    I've been seeing more and more posts about reverse becoming a bit of a pain :(. How bad is it?
  6. Jul 8, 2013 at 2:19 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    It's not that bad. Takes a bit more effort but still worth it IMO.
    Norton likes this.
  7. Jul 8, 2013 at 3:01 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Can someone describe why the shortshifter is so much better, & why mpg improves.
  8. Jul 8, 2013 at 3:07 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    It cleans up the throws, It reduces the chances of getting lost while rowing through the gears and takes less time in between shifts.
    For the reverse issue noted above... I didn't notice it getting anymore difficult on my truck, However on my friends truck it is harder to get into reverse.
    We both have a URD shifter, but the difference is our knobs... He has a long thin OBX knob and I have the TRD ball knob, With each knob we have to hold them differently and it's just enough more uncomfortable to use the extra force to get it into reverse as opposed to a ball in my hand.
  9. Jul 9, 2013 at 6:12 AM
    newfieDan
    newfieDan [OP] Well-Known Member
    St John's
    13 Tacoma TRD Sport
    How does one take the first 1.5" of play out of the clutch? I despise the clutch on my 13 TRD Sport. When I took it into Toyota they said it was "self adjusting" and that was the way it was.
    As for "How hard is it to put into reverse with the SS installed? Honestly, it is so minor that I can't even imagine someone actually complain about it. There has to be SOME trade-off for the shorter throw. You give the shifter a little knock and in it goes. It is less than a non issue for me. I can't speak for the URD but that's how it is for the TRD.
  10. Jul 9, 2013 at 7:23 AM
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    You can remove the "fudge" from the pedal by putting some spacers on the front stop of the pedal. It's a little green plastic bushing attached to the pedal. I just added some hard plastic to the green bushing so the pedal doesn't come as far forward just be careful not to put in so much you end up riding the clutch. When you push the pedal it's pretty obvious what's "fudge" and what is actually engaging the clutch. You can see it pretty easily by looking at the back of the clutch pedal. It's not real fancy, but it gets the job done. I also added just a little to the pedal thickness too so the clutch is easier to press to the floor. (I have kinda stumpy legs :anonymous:)
  11. Sep 15, 2016 at 1:30 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    think i just added short throw to my list of tacoma mods still to do...had one in my wrx and noticed a huge difference wonder if the taco will be the same.
  12. Sep 15, 2016 at 2:17 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I ordered one this week and it'll be delivered tomorrow. You can find them just under $300 delivered with a Google search on the part number (I used PTR04-35052). Looks like I got a weekend project...
  13. Sep 15, 2016 at 2:42 PM
    TL82
    TL82 Well-Known Member
    Northern California
    2006 Silver PreRunner RC SR5
    Putting this on my list of future mods.
  14. Sep 15, 2016 at 2:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does this shifter literally change the fulcrum point of the shift mechanism, or is it just a shorter handle? Or is it a combination?
  15. Sep 19, 2016 at 9:44 AM
    #35
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I installed my TRD kit over the weekend and changes the fulcrum point by about 3/4" (higher). This equated to about 1 5/8" shorter overall throw. I didn't measure the shift ball height but it feels about the same. So far in two days driving, I noticed that the third gear synchro bump grind has gone away. The shifter has a tighter, notchy feel with positive engagement. Reverse is a bit harder but not too bad at all.
