TRD rims not fitting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tmctaco, Jan 17, 2023.
  1. Mar 11, 2023 at 7:38 AM
    #61
    burgershot
    burgershot Well-Known Member
    It’s slang, Mr. internet gatekeeper. What a cringey post.
    Nonamesleft4u and Junkhead like this.
  2. Mar 11, 2023 at 7:39 AM
    #62
    burgershot
    Not even the same wheels this post is about.
  3. Mar 11, 2023 at 7:52 AM
    #63
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    One time I told my wife I was buying some new wheels. She sure was surprised when I came home in a new Jeep.
  4. Mar 11, 2023 at 7:54 AM
    #64
    CaptainBart45
    Bart
    Work in progress...
    What kind of uh "wheels" are those? I like those wheels on that truck.
  5. Mar 11, 2023 at 10:58 AM
    #65
    burgershot
    You want the uh “part number” or uh “what”?
    CaptainBart45[QUOTED] likes this.
  6. Mar 11, 2023 at 11:08 AM
    #66
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Search the forums dude. This is a know issue with a simply fix. You need to chamfer the rear hum with a grind wheel. Takes like 3 minutes. And no, won't cause a vibration. But yes, the aftermarket look alikes are better - you can get them at ZERO offset and they are slightly wider.
    burgershot likes this.
  7. Mar 11, 2023 at 2:28 PM
    #67
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    OP it looks good! glad you got it worked out
  8. Mar 11, 2023 at 3:24 PM
    #68
    Domeimazn
    Domeimazn Well-Known Member
    Henro
    2020 tacoma pro
  9. Mar 11, 2023 at 4:55 PM
    #69
    CaptainBart45
    Bart
    Work in progress...
    That would be cool. I could probably find them myself if you know who makes them.
  10. Mar 12, 2023 at 12:16 AM
    #70
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Are the SEMA wheels not being made anymore? Why aren't people getting the SEMA wheels, I believe its a different part number that the new wheels.
  11. Mar 12, 2023 at 4:53 AM
    #71
    burgershot
    You might have heard of them, they are made by a small little company called Toyota.
  12. Mar 12, 2023 at 6:41 AM
    #72
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I have to partly agree with Sungod on this one... When I read the title of this thread, I thought OP was having an issue with the tire bead area. Slang is only useful when context is given; only after reading the OP, is it conveyed what the actual problem is.
    I say "partly" because, what Sungod has referred to as the "rim", is better described as the inner and outer flange. The rim is the interior surface of the flanges the tire bead bears against when mounted and inflated.
    If the title had been "TRD wheel will not seat fully on hub", it would have made it clear and a good searchable title for other members.
    Yeah, I'm kind of anal about these things...sue me. :duh:
    BC Hunter and cloudbnd like this.
  13. Mar 12, 2023 at 12:29 PM
    #73
    CaptainBart45
    Bart
    Work in progress...
    burgershot[QUOTED] likes this.
  14. Mar 12, 2023 at 2:16 PM
    #74
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    :eek:
    OMG! You had to read the first post and not just the title? What type of insane asylum are we living in?
    :rofl:
    Silly splitbolt, nobody is using the search function. If they had, they'd be aware of this problem and the solution.
    Lt. Dangle and Skydvrr like this.
  15. Mar 12, 2023 at 3:26 PM
    #75
    splitbolt
    NW Arkansas
    Or...they use too much slang.:p
    cloudbnd likes this.
  16. Mar 13, 2023 at 6:13 AM
    #76
    Sungod
    Sungod Well-Known Member
    St Augustine
    It depends on the context of the use of the word rim. You are using it correctly in your description, but as we know about words, they can be used differently when used as a noun or adjective by definition. As I used it a noun to the name of a part used in an assembly that when combined it is known as a wheel. With most wheels they are single piece that you cannot separate the individual components. That doesn't mean they don't exist. They are just a solid piece. However, you can still get 2 and 3 peice wheels. Mostly they are used in off road and specialty cases. In any case, this is exactly the part that is knows as a rim -
    You will hear this part also sometimes referred to as a barrel or in 3 piece wheel a lip. Those are still acceptable and not considered slang.
    Interestingly you will never hear a split rim referred to as a split wheel. It just doesn't make sense because it doesn't correctly describe the parts.
    #76
  17. Mar 13, 2023 at 6:29 AM
    #77
    Sungod
    St Augustine
    No question it is slang. Straight out of the flatbillers mouth. Undoubtedly started by ignorance. Really not a lot different than walking into a gun store and saying you want to buy a gat or a jammie.
  18. Mar 13, 2023 at 6:47 AM
    #78
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  19. Mar 13, 2023 at 7:55 AM
    #79
    splitbolt
    NW Arkansas
    Yeah, but you're coming way out of left field bringing that into a Tacoma forum; way out of context.
    Here's today's word-of-the-day; "pugnacious".
    #79
    burgershot and Lt. Dangle like this.
  20. Mar 13, 2023 at 9:11 AM
    #80
    Sungod
    St Augustine
    Not really sure what you are talking about. You seem to have taken what I stated and interjected confusion. In the context of what I stated, it was pretty clear. Using the word "Rim" to describe a wheel is flat-biller slang derived from ignorance.
